Collinite 845 or 476
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magnum922, Jul 11, 2011.
  1. Jul 11, 2011 at 7:57 AM
    magnum922
    magnum922 [OP] Well-Known Member
    2011 DCLB 4.0 tow pkg 4x4
    Has anyone used collinite waxes? How much longer does the collinite 476 double wax compare to the 845 insulator wax? I heared the 476 is hard to work with and the 845 is alot easier.
  2. Nov 9, 2015 at 8:54 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I just ordered some 476
  3. Nov 9, 2015 at 9:13 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I just did my truck in 476, not the easiest stuff to work with but not all that hard.
    NMTrailRider likes this.
  4. Nov 9, 2015 at 9:15 PM
    NMTrailRider
    New Mexico
    Any advice on application/removal? I'll be working by hand. What, in particular, was not easy about it?
  5. Nov 9, 2015 at 9:18 PM
    shakerhood
    Southern Ohio
    Even though I have a PC 7424 I still did it by hand, its really not any different than any other wax just a little harder to buff off after it hazes, you will be fine.
    NMTrailRider[QUOTED] likes this.
  6. Nov 9, 2015 at 9:38 PM
    NMTrailRider
    New Mexico
    Good deal. I put down a coat of 845 this week but I've been curious about the 476. Sounds rocks solid. I've been using Megs ULW for several months but decided to switch it up for the winter. Looking forward to comparing the 476 to the 845/ULW.
    I saw in a couple posts on autogeek that the 476 doesn't stain trim. Did you find this to be the case? That was news to me.
    3coma likes this.
  7. Nov 9, 2015 at 9:47 PM
    shakerhood
    Southern Ohio
    I actually have never used 476 prior to right now, purpose was for a good protection during Winter. As far as staining trim, not sure because I mask everything as I go.
  8. Nov 10, 2015 at 4:12 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    I have used both 476 is not harder to remove just put it on thin. I also use Klasse all in one and it lasts longer than 476
  9. Nov 10, 2015 at 5:00 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Yes, 845 is easier to work with, but 476 isn't "hard" to use.
    476 is more durable, as are most pastes compared to liquids. 476 will also provide a little more depth. For customers having work done prior to the winter, I always applied 845 to white/silver vehicles and 476 to darker colors.
  10. Nov 10, 2015 at 6:29 AM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    Hey Chris(NJ), why 845 to white/silver and 476 to darker colors?
  11. Nov 10, 2015 at 5:20 PM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    I use Collinite products. 845 has a very easy on and off application. I use and really like 476S also, just apply in the shade and to a somewhat cool surface. Both great stuff.
    My favorite is 915. I'll use 915 and two weeks later put a coat of 476S over it.
    Of course the key to a great long lasting wax is to clay the vehicle after washing and before polishing and waxing.
