Color Markings on TRD Offroad Coils
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fitz235, Jul 7, 2015.
  1. Jul 7, 2015 at 3:41 PM
    Fitz235
    Fitz235 [OP] Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Alright, this is probably going to be futile, as I've searched, and it sounds like the colors are constantly changing. But here it is:
    I just got my truck back from a frame swap, they installed a new set of 5100's (now set to 1.75", from .85") with new Offroad coils, along with the new rear leafs, etc.
    My "Before" (5100's @ .85") measurements were:
    Driver Front: 21" center of hub to fender
    Pass. Front: 21" center of hub to fender
    Driver Rear: 22" center of hub to fender
    Pass. Rear: 22" center of hub to fender
    My "After" (5100's @ 1.75") measurements were:
    Driver Front: 21.75" center of hub to fender
    Pass. Front: 22.25" center of hub to fender
    Driver Rear: 21.5" center of hub to fender
    Pass. Rear: 21.75" center of hub to fender
    It looks like there are a couple of things going on here:
    One observation is that I went from 10 year old 2+1 leafs, that sat just slightly higher than the 3+1 TSB leafs on there now (I don't know if the front being higher, forces more weight on the rear, causing them to sag more?). At the least, they are no higher than the old leafs. I was expecting them to be +/- 1" higher from everything I've read. So it looks like an AAL is in my future.
    The other observation, and main point is that the passenger side is now 1/2" higher than the driver's side with a 1/4" spacer on the driver's side.
    I'm thinking the coils are swapped. I called the place I bought the parts from, but they didn't have a set in stock to check. So I figured I would check with the hive mind.
    What's on there now:
    Driver's side: Orange/White
    Pass. side: Pink/White
    So if anyone has an Offroad with matching colors, let me know, otherwise, I guess I'll be calling around.
  2. Jul 7, 2015 at 4:35 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    2005 access cab off road 4x4...mine is marked orange and white on the passenger side. Orange on the second wrap of spring white on third (from the bottom)
  3. Jul 7, 2015 at 4:38 PM
    Fitz235
    Rob
    New Hampshire
    Thanks man.
    It sounds like mine are swapped.
  4. Jul 11, 2015 at 2:01 PM
    Fitz235
    Rob
    New Hampshire
    Anyone else?
    I haven't had much luck calling parts depts. It sounds like mine are reversed, I'll feel a little more confident if I can confirm with at least one other owner.
  5. Jul 18, 2015 at 2:08 PM
    Fitz235
    Rob
    New Hampshire
    The parts guy at my dealership came through, and sent me some pics.
    So, this will probably be more useless information taking up server space, but on the off chance someone can use this, here it is:
    Front Left / Driver's side - P/N # 48131-AD231 - Pink/White
    Front Right / Passenger's side - P/N # 48131-AD221 - Orange/White
    BTW, this confirms that mine were installed on the wrong sides.
  6. Jul 18, 2015 at 4:45 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yup have em swapped, Pretty easy process actually.
