Color Matched Grill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Harley2, Feb 22, 2015.
  1. Feb 28, 2015 at 5:34 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    X2
  2. Feb 28, 2015 at 5:53 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Can't compare knock off Rockauto garbage to a real OEM perfect fit grill. But hey you get what you pay for. People have bought those cheap 39.00 grills and have had fitment and quality issues. Good luck with Rockauto.
  3. Feb 28, 2015 at 9:14 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    those of you who have bought your color matched grille from toyota... have you found that the match to your paint isnt exact? in my case it looks darker. noticeably darker. and im kind of stuck with it since i installed....
  4. Feb 28, 2015 at 9:19 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    That is why you should have bought the " TRD Pro " insert
  5. Feb 28, 2015 at 9:27 AM
    B737
    Kevin
    Jersey Shore
    stock
    i shoulda bought a PRO :(
  6. Feb 28, 2015 at 9:31 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Fuck yeah baby hey do you still have that nice leather owners manual case?
  7. Feb 28, 2015 at 9:32 AM
    B737
    Kevin
    Jersey Shore
    stock
    i do, nobody wants it.
  8. Feb 28, 2015 at 9:34 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    It's new isn't it?
  9. Feb 28, 2015 at 9:37 AM
    B737
    Kevin
    Jersey Shore
    stock
    like new. technically used now. everything inside it is from 2012....
  10. Feb 28, 2015 at 9:51 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Ship dat biatch.
  11. Feb 28, 2015 at 2:25 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Mine looks perfect.
  12. Feb 28, 2015 at 2:33 PM
    T2CR
    T2CR Well-Known Member
    Ventucky
    '15 TRD Offroad 4x4
    I swapped my the first week I had it. Totally worth $187 to me ...
    Before:
    After:
  13. Mar 25, 2015 at 2:59 PM
    Hnikarr
    Hnikarr Member
    North Jersey
    2015 TRD Off Road
    Tinted front windows, 3" pro comp suspension lift, 285 Hankook MT tires, 17" pro comp wheels, color matched grille swap, big country grille guard, aftermarket black housing headlights
    Hey all. I have a new 2015 TRD Off-Road and I absolutely HATED the chrome grille surround. So I just got my $180 color matched grille in the mail today and already swapped it out. I'll be plasti-dipping my badge when I get a chance to buy some this coming week. Sorry about the picture quality!
    Before:
    After:
  14. Mar 25, 2015 at 3:08 PM
    ThomasMore66
    The way God intended it to be. If I just had a scoop...
  15. Mar 25, 2015 at 3:16 PM
    #35
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Mine was perfect in regards to it being matched.I kept the original grill(already color matched)and used the other to do the GrillCraft grill mod/labor myself.That way i have the choice to swap/change them out if i want.
  16. Mar 25, 2015 at 3:31 PM
    #36
    Harley2
    Harley2 [OP] Well-Known Member
    Rick
    Vermont
    15 Super White Double Cab 4x4
    My Super White was a perfect match
