Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Mar 26, 2024 at 1:42 PM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
    many thanks! :thumbsup::thumbsup:
    Im sure there is a labor discount if you work it too. :luvya:
    303tacoma[QUOTED] likes this.
  2. Mar 26, 2024 at 2:33 PM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    You know I'm a big fan of this mod, and would be happy to help.
    If you don't care about 2lo and want to leave the j shift, you don't even have to open up the case. We can pretty much just pull your center console, cut a hole for the shifters and it will bolt right up. @Nazupag524 can provide insight on the cooky bends for the shifter on the auto. I know it requires some notching of the plastic and a u-shape. That's probably the worst part.
    I assume you'd also want to delete the ADD, since I know you were troubleshooting that last year. That certainly adds to the cost if you're sourcing new, but there are other options to lock the ADD and leave it that way, or wire it up.
  3. Mar 26, 2024 at 2:48 PM
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    What's going on with yours? I've been followong you more on trains and 3 d printing lately. Yours is a vibration?
  4. Mar 26, 2024 at 3:07 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Grinding/growling noise from underneath. Not sure if it's rear wheel bearings, which are about due anyway, or something in the transfer case. Does not make noise when in the air, only on the ground. It's louder when coasting, a bit quieter on acceleration. Already did the driver front CV bushing and the carrier, it's neither of them. I can hear it echo off the neighborhood houses and people walking stop and stare, so it's obviously there.
    Hoping tomorrow I can have a friend drive it while I walk beside it or hang under it to pinpoint it.
    Transmission is fine, no codes and transfer case shifts as it should and the noise does not change in 4x4 or 4x2. Maybe it's just the rear wheel bearings.
  5. Mar 26, 2024 at 3:15 PM
    fromTacoma
    fromTacoma Active Member
    SW CO
    2019 Cavalry Blue TRD OR DCLB
    Heya! I'm located on the western slope and someone slammed into my front passenger side wheel (and along the whole passenger side ) on a icy night. I need to get my steering and suspension fixed on that side. I'm thinking I might use this as an opportunity to upgrade while I'm at it. Does anyone have a shop that they love in Montrose, Grand Junction or Durango?
    I'm also working on finding the right body shop as well- hoping to get into Mylars in Montrose.
  6. Mar 26, 2024 at 3:24 PM
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    Take a look at u joints?
  7. Mar 26, 2024 at 3:38 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Yep, they are good. Had it on stands, checked pinions, kicked/shook all 4 wheels. A bad rear bearing may not necessarily have play or be leaking right away.
    Dropped the carrier bearing that I replaced last year just to check, it's fine. Brakes are good, not dragging. In have been under it a half dozen times in the last two days just to recheck.
    On a side note, when i had rear bearings fail before, they sounded like marbles in a steel coffee can rolling down the street.
    This sounds like raw metal on metal grinding away.
  8. Mar 26, 2024 at 3:53 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    What i was thinking is leaving the ADD locked( sliding the sleeve and unplugging it , ii that a wise thing to do?
    i do not care about 2lo
    Just 4hi and 4lo
    Im stuck in 4H right now and gotta pull the ADD to unlock it ( I Hope)
    CO MTN Steve and Nazupag524 like this.
  9. Mar 26, 2024 at 4:15 PM
    Kappes03
    Kappes03 [OP] Legend of the UG
    Colorado
    2014 Tundra CM
    Yeeeeah mod daaaay
  10. Mar 26, 2024 at 4:23 PM
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    I wired my front actuator to a switch. 2 lo comes in handy more than I thought.
  11. Mar 26, 2024 at 4:50 PM
    303tacoma
    Rebecca
    Ahh a switch,Good idea.
    So do you use the same actuator that's on the tacoma?
    2lo for me meh. I cant see me using it really.
    You guys do a lot of recreational stuff that i dont do.
    So if i understand correctly i can just have the j shift and not a dual shift?
    I just want something I know will shift.
    Im gonna go and start reading the fj thread, see what im getting into.
  12. Mar 26, 2024 at 5:05 PM
    Nazupag524
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Yes I replaced the actuator on the front diff when it went out. Sealed it up good before I installed it. The t case I bought came with the harness and switch for the front actuator. I don’t have the twin/triple sticks. I just have the FJ t case which is manually shifted. Much much better.
  13. Mar 26, 2024 at 5:21 PM
    303tacoma
    Rebecca
    Thats sounds like exactly what i need!
  14. Mar 26, 2024 at 6:23 PM
    Kappes03
    Colorado
    2014 Tundra CM
    I picked @Littles brain a few years ago about. I just never acquired the FJ case before selling my Taco
  15. Mar 27, 2024 at 4:34 AM
    303tacoma
    Rebecca
    I have actually thought about just fixing it and selling, but shoot its paid for, I love my truck, ive leaned alot working on it.
    Frame is starting to riust.
    Figure ill just send it before it breaks in half :D
    I still gotta tear out the front actuator, get it out of 4H and see what happens from there, im just grateful i have another car.
  16. Mar 27, 2024 at 9:53 AM
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    That's become a more popular method of bypassing the ADD because it's free. I know there are plenty of people on that FJ swap forum who have done it that way, and I have never heard of an issue.
    You weren't able to rule out the ADD actuator with the one I gave you?
  17. Mar 27, 2024 at 10:01 AM
    Kappes03
    Colorado
    2014 Tundra CM
    Wonder if he's on here.. Not a good look Screenshot_20240327_105903_Facebook.jpg
  18. Mar 27, 2024 at 10:07 AM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
  19. Mar 27, 2024 at 10:09 AM
    Kappes03
    Colorado
    2014 Tundra CM
    I mean he said he wanted to camp so might as well camp until it melts haha
  20. Mar 27, 2024 at 10:30 AM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    I was wondering when this would make its way over here. What a bozo.
