Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. May 11, 2024 at 7:37 AM
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Does anyone have a set of Chevy 63s laying around?
  2. May 11, 2024 at 10:43 AM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    I've got an elocked hp 8" with 5.29s ill sell ya
    ShiftyShank[QUOTED] likes this.
  3. May 11, 2024 at 5:33 PM
    ShiftyShank
    ShiftyShank Oof
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    Thanks! You should ask ? Where I got them. ;)
    TMFF[QUOTED] likes this.
  4. May 11, 2024 at 5:34 PM
    ShiftyShank
    ShiftyShank Oof
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    o_O I could be interested.
  5. May 12, 2024 at 8:24 AM
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    Anyone have recommendations/personal experience with detailing a vehicle that has been smoked in? I've tried a few ozone bombs but can't get the smell out to the extent I was hoping to.
  6. May 12, 2024 at 9:36 AM
    calzonical
    calzonical Without the 2nd, there is no 1st.
    2018 Taco TRD OR DCSB A/T
    Soggy Day = Work on Yodas' Day.
    First up T4R, tighten door latches. driver door latch screws way too loose. Next was to fix exhaust leak at cat junction to muffler. Muffler shop did not use a gasket or proper bolts and connector. So I fixed that junk the correct way. No more leak.
    Next up - Oil change and lube front prop shaft on Taco.
  7. May 12, 2024 at 12:50 PM
    calzonical
    Taco Happy - New Oil, Oil Filter, Air filter, Cabin air filter, and freshly lubed front prop shaft.
    Rain and sleet ended. Sol is making an appearance. Time for a Ride.
  8. May 12, 2024 at 6:49 PM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    My weekend project - replace water heater on trailer and move it to an external cabinet in the process
    Used a nema 4x stainless steel electrical enclosure because it was the right size, heavy enough duty for being on the side of the trailer rolling down the highway/trails, and decently priced.
    The annoying part was re-routing the water lines and doing all the test fits, mockups, uninstall, reinstall business, and then fixing leaky fittings.
    I wanted to move it to the outside so I didn't have to have the side door open since the exhaust gets hot, and then I'd have to unhook the propane line to close the door at night or if I was done using it. Plus it frees up some space in the storage area now.
    Winkle99, jubei, RockiesTaco and 6 others like this.
  9. May 12, 2024 at 6:54 PM
    BirchyBoy
    BirchyBoy Well-Known Member
    ‘20 Tacoma SR DCSB
    Has anyone purchased a utility trailer without a title? Is it a red flag if the seller doesn’t have one?
  10. May 12, 2024 at 7:06 PM
    Chadr7858
    Chad
    Colorado
    Got most of the 63 swap finished up on the first gen today. Picked up a built waggy axle for it too!
    Wulf, jubei, RockiesTaco and 2 others like this.
  11. May 12, 2024 at 7:27 PM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Is Denver trying to lose this thing??:annoyed:
  12. May 12, 2024 at 8:34 PM
    ShiftyShank
    ShiftyShank Oof
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    Laundry detergent in a 5 gal bucket of hot water Scrub the carpets seats headliner and everything.
    wet vac to pull that shit out.
    That helped me a ton
    Tacofire98[QUOTED] likes this.
  13. May 12, 2024 at 8:40 PM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    ShiftyShank and eurowner[QUOTED] like this.
  14. May 13, 2024 at 8:38 AM
    ShiftyShank
    ShiftyShank Oof
    Pat
    Northern Colorado
    02' BestGen 5VZFET
  15. May 13, 2024 at 8:52 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I know a few that have installed them on different trucks and very impressed.
  16. May 13, 2024 at 4:02 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    FYI CPW just emailed some info about the new app for wildfires
    Winkle99, Deathbysnusnu and 303tacoma like this.
  17. May 13, 2024 at 4:56 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    eurowner likes this.
  18. May 13, 2024 at 6:05 PM
    eurowner
    eurowner Duke Sky
    Scoty
    :fistbump:
    JasonLee[QUOTED] likes this.
  19. May 13, 2024 at 6:18 PM
    alee891
    Austin
    Black Hills
    Tacomaless
    Uh oh
    ShiftyShank likes this.
  20. May 13, 2024 at 6:59 PM
    ShiftyShank
    ShiftyShank Oof
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    Why tho. What did I miss
