Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jan 12, 2025 at 6:17 PM
    Kappes03
    Kappes03 [OP] Legend of the UG
    Colorado
    2014 Tundra CM
    Piece of trash thieves stole a brand new Forest River Shasta Oasis trailer from my brother's RV lot in Kiowa at about 6am this morning. Ford F250 likely stolen I'm sure but had some pretty visible front fender damage
    CO MTN Steve likes this.
  2. Jan 12, 2025 at 7:20 PM
    ShiftyShank
    ShiftyShank Oof
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    I'm so sorry to hear that.
  3. Jan 13, 2025 at 8:46 AM
    EnBoo
    EnBoo Well-Known Member
    Nathan
    Denver, CO
    2018 DCSB Quicksand Sellout
    Hoping someone can help. Drove the truck all over the state on Saturday for a hunt without any issues at all. This morning I drove about a block and noticed at the stop sign significant shaking and vibration. I pulled over, put the truck in park and the shaking stopped. I noticed this is only happening when the truck is in drive or reverse and the brake is pressed. I had to take the wife's car to work and didn't have much time to diagnose. The check engine and TRAC OFF lights came on when I drove the truck the block home.
    2018 Sport
  4. Jan 13, 2025 at 9:16 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I’m guessing related to the lower idle when in gear and stopped with brake (more fluid getting pushed through the torque converter recycling and not spinning the transmission.
    But why the sudden lower idle related shaking/vibration? Hm. It’s not super cold today or anything where I would point to that environment variable.
    EnBoo[QUOTED] likes this.
  5. Jan 13, 2025 at 9:22 AM
    eurowner
    eurowner Duke Sky
    Scoty
    When was the last time you filled up with fuel?
  6. Jan 13, 2025 at 9:38 AM
    EnBoo
    Nathan
    Denver, CO
    Yeah was thinking it could be the cold but it was also in the garage since Saturday. I did notice the fluid reservoir for coolant was empty so I topped it off. Not sure if anyway that's related
    The weekend prior, so about a week. Drove it down to 1/4 tank on Saturday.
  7. Jan 13, 2025 at 9:50 AM
    calzonical
    calzonical Without the 2nd, there is no 1st.
    2018 Taco TRD OR DCSB A/T
    Are you able to pull the Codes?
    Guesses: Could be condensation/water in gas tank.
    Fuel Pump failing.
    Serpentine belt broke and fell off.
    Aliens.
    None of the above
    Deathbysnusnu and EnBoo[QUOTED] like this.
  8. Jan 13, 2025 at 10:04 AM
    eurowner
    eurowner Duke Sky
    Scoty
  9. Jan 13, 2025 at 10:42 AM
    EnBoo
    Nathan
    Denver, CO
    Not right now but I'll do so later tonight when I get off. I was also thinking fuel pump too but wouldn't I have power issues while driving?
  10. Jan 13, 2025 at 10:47 AM
    JasonLee
    15 TRD OffRoad
    Isn't there a low pressure and high pressure fuel pump in the 3rd gen? I don't know how that could/would cause the issues that your seeing though.
  11. Jan 13, 2025 at 10:58 AM
    eurowner
    eurowner Duke Sky
    Scoty
  12. Jan 14, 2025 at 8:15 AM
    EnBoo
    Nathan
    Denver, CO
    Update.
    Did some more research and the likely suspect was a bad VVT.
    Got home last night and I had quite a bit of oil in my catch can. Checked the oil level and it was low but still fine. Did an oil change for good measure. Problem persisted for a little bit but then no more vibrations or shuttering. Got the codes from OReilly (P0019 and P0300) showing most likely solution to change VVT.
    I also have the fuel pump recall scheduled for next week.
    Thanks for everyone's help!
    JasonLee and eurowner like this.
  13. Jan 14, 2025 at 12:28 PM
    Kappes03
    Colorado
    2014 Tundra CM
    I saw a plate today with the stickers on the front... that was a new one. Reminded me of this
    472856878_18481443178034666_733344217392_47177cbf65caf5b2b993d126722eeba3b5417a39.jpg
  14. Jan 14, 2025 at 2:50 PM
    JasonLee
    15 TRD OffRoad
    I saw stickers on the front a few days ago as well. I definitely had a wtf moment.
  15. Jan 14, 2025 at 5:32 PM
    JasonLee
    15 TRD OffRoad
    And I saw an undocumented one today. Right side only.
  16. Jan 14, 2025 at 5:43 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Ha
    My sister went and got tags for her new vehicle.
    Hmmmmm “i asked her where is your month tag?”
    Her reply “They only gave me the year”
    WTF
  17. Jan 14, 2025 at 6:02 PM
    JasonLee
    15 TRD OffRoad
    The year tag is part of the paper registration. The month is a separate one they pull out of a drawer and paperclip to new registrations cause they don’t matter as much. The years are all printed with your license plate on them.
    She should be able to walk in and get a month one from the counter without hassle
  18. Jan 14, 2025 at 6:44 PM
    Breknraj
    Breknraj Well-Known Member
    Roger
    2017 Tacoma TRD Off Road
    Eibach mild lift Relentless Stingray low profile bumper w/ Warn 8000S Warrior Products Roof Rack RRW Sliders
    The part about the plate registration stickers that truly blows my mind is that the damn things come in an envelope that has a handy little diagram of where to put them!
    Makes me roll my eyes every time!
  19. Jan 15, 2025 at 4:15 AM
    303tacoma
    Rebecca
    Ya i know how it works:D
    you would think without a hassle!!!
    Bahahaha i know my sister itll be like that for awhile!!
    JasonLee[QUOTED] likes this.
  20. Jan 15, 2025 at 4:43 PM
    Winkle99
    Winkle99 Don't Look Back
    David
    CO
    99 XCab 3.4 Manual 4x4 TRD SR5
    I just got plates for the 87 pickup. The woman at the DMV stuck the stickers on the plate for me before handing them over. She probably figured I’d screw it up.
    I did remember to install the plate with the stickers on the rear bumper. :cookiemonster:
