Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Feb 26, 2025 at 2:19 AM
    Operator8
    Operator8 Well-Known Member
    Woodland Park, CO
    2005 White Tacoma TRD OR
    SAS INW
    Definitely wasn't the goal to go wider than the standard 05+ SD width, but the 15/43-17 Mickey's made the fit too tight. Main trails I'm concerned about now are the ones down in the Quray/Silverton/Telluride area, haven't made it down that way yet, so I'm not too familiar with the width of the trails down there.
  2. Feb 26, 2025 at 2:23 AM
    Operator8
    Woodland Park, CO
    SAS INW
    I was already pretty wide even for IFS, so I'm used to the ride, and since I don't daily the truck street friendly is pretty low on my list, but it's still on the list, as I do drive to the trail.
  3. Feb 26, 2025 at 4:01 AM
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Why such a big/wide tire?
  4. Feb 26, 2025 at 4:11 AM
    Operator8
    Woodland Park, CO
    SAS INW
    Didn't really have the funds to get the slightly smaller (less wide) but more expensive 42" Trepadors, and didn't really want to go to the Boss M/T's after running the Pro XS's the past couple years, so I didn't have too many options. And I've really like the Baja's so I stuck with that model. I don't think I'll be too negatively impacted, but like I said above, I wouldn't feel comfortable doing Schofield again, not saying I wouldn't fit, but it'd be tight. But I can't think of any other trails I've run where it would be an issue.
  5. Feb 26, 2025 at 8:20 AM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Anybody have experience with electric tankless water heater? Good, bad, ugly? Would be for a 1 bath, 1 occupant home under 1000sqft
  6. Feb 26, 2025 at 9:08 AM
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    I had a tankless combination boiler / water heater installed about 9 months ago, replacing a 30 year old model with a tank. For domestic hot water, it's great, I haven't ever run out of hot water. The interaction between domestic hot water usage and space heating wasn't what I was expecting though.
    My domestic hot water uses a separate pump to circulate water in the hot water loop, annnnd, when domestic hot water is in use, it gets priority and I don't get water circulating in the space heating loop. I figured this out a month or so ago when we had a week of high temps in the single digits, and the house wasn't getting heated because the domestic hot water loop was running all day. This was "fixed" by programming the external pump to only circulate water in the domestic hot water system for 30 minutes, then off for 1.5 hours so the space heating loop could heat the house. You can get hot water out of a faucet or the shower whenever you want, but if the pump on the domestic side has been off and the space heating loop has been running, it might take a minute.
    Hope that makes sense.
    TLDR: If its only heating domestic hot water, no complaints so far. If you are also using it for space heating (in floor radiant heat, baseboard radiators, etc), YMMV, make sure you research how the unit works.
    Edit: and I just saw the Electric part, I'm using natural gas, so who knows if my experience applies.
  7. Feb 26, 2025 at 9:53 AM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Thanks for this! It was helpful!
  8. Feb 26, 2025 at 10:47 AM
    Madjik_Man
    Colorado Front Range
    I had an electric tankless water heater and would have stuck with it but I have more than one occupant and noticed it couldn’t keep up with multiple appliances/faucets that well.
    Given one occupant I assume it will work out fine for you.
    Just FYI: with my gas tankless, it takes significantly longer to get hot water to the faucet (same run length) than the conventional tank.
    So much so that I don’t even bother washing my hands in warm water anymore and tend to use cold water most of the time for everything. Otherwise the water is running for 45 - 60 seconds before it gets warm. To me that’s a waste of time and water.
  9. Feb 26, 2025 at 11:03 AM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    This is also helpful! Thanks!
  10. Feb 26, 2025 at 12:04 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    I stuck with a gas tank when I replaced my heater a few years ago. The main reason was the cost to retrofit a PVC vent (as required by modern high-efficiency water heaters) into an old house. In hindsight, I wish I had just spent the money, if nothing else it would have freed up floor space in my basement.
    Venting probably isn't a concern with an electric heater though, so I might just be rambling
  11. Feb 26, 2025 at 1:10 PM
    Kappes03
    Kappes03 [OP] Legend of the UG
    Colorado
    2014 Tundra CM
    @mreimann put one in his off road trailer build haha
  12. Feb 26, 2025 at 1:44 PM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Thats called a mobile home south of the tracks where i grew up
    Kappes03[QUOTED][OP] likes this.
  13. Feb 26, 2025 at 3:57 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Girl Scout cookie season is happening.
  14. Feb 26, 2025 at 4:05 PM
    Breknraj
    Breknraj Well-Known Member
    Roger
    2017 Tacoma TRD Off Road
    Eibach mild lift Relentless Stingray low profile bumper w/ Warn 8000S Warrior Products Roof Rack RRW Sliders
    AKA The Little Green Pushers!
    Deathbysnusnu[QUOTED] likes this.
  15. Feb 27, 2025 at 6:40 AM
    xxTacocaTxx
    Best Slope CO
    Is it just me, or does it seem like the price keeps going up, while the quantity keeps going down? Eating a "whole box" of GSC isn't what it used to be.
  16. Feb 27, 2025 at 6:57 AM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    The CEO of Girl Scouts of the United States of America, Bonnie Barczykowski receives a total compensation package of $687,756 in pay and $44,376 in other compensation (probably thin mints). it comes from taking advantage of the society’s heartstrings and the feel-goodness of helping kids that are panhandle pushing cookies.. not by giving us more cookies after we have already been swindled.
    RockiesTaco and Deathbysnusnu like this.
  17. Feb 27, 2025 at 7:07 AM
    6P4
    Colorado Springs
    That's pretty modest pay for the CEO of an organization with 2.5 million "employees".
  18. Feb 27, 2025 at 7:50 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
  19. Feb 27, 2025 at 8:52 AM
    Kappes03
    Colorado
    2014 Tundra CM
  20. Feb 27, 2025 at 9:25 AM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    What a time to be alive
