Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Mar 15, 2013 at 7:19 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    They're both AWD.
    Thanks man. My Typhoon was a great example of the trucks and showed the effort put into it. The engine bay was easily the cleanest engine bay I've ever owned and looked brand new at any angle. I swapped out the air to water intercooler for the air to air (saves weight, eliminates pumps and liquids, increases consistency and reliability.. you can see all the plumbing & the front mount I made though the grill) swapped in a t3/t4 hybrid turbo and added a methanol injection kit (2nd windshield washer reservoir holds methanol and the steel braided line runs from a pump underneath that's gravity fed across the firewall to the intake elbow where you see the nozzle). With this setup I could run full boost (~25psi) on pump gas w/zero degrees of knock and the truck was incredible. Without the meth I was only able to run about 14psi in the winter and 15psi in the summer before getting knock activity. The ignition systems on these trucks SUCK and you need to play to change the cap/rotor & plugs every couple thousand miles or less and they're a PITA. Plug wires will need to be changed every few plug changes too. Even with an MSD it was SO hard to keep the spark strong with this thing. The driveline was also a PITA and they liked to chew up transmissions and if you did an R400 conversion it would start destroying transfer cases.
    But man what a ride.
    The feeling you get during a boost launch (leave the line at about 12psi under the slightest bit of wheel spin) was incredible. The boost launch itself was an art form on these trucks. Some guys did a rotor swap in the rear but I left the drums because they offer more surface area for clamping power (not as good at actual braking as rotors mind you) which you need with higher boost. The procedure is as follows: From a stop & with the truck in park or neutral you want to stand your left foot on the brake as hard as you can. Give the truck a couple of good revs which will pull vacuum from the brake system and give you more clamping power (this step is necessary or the truck will start creeping forward at around 7-8psi) as you feel the brake pedal sink to the floor. Let the revs settle (foot still firmly on the brake) and put the truck in drive. Now, give the truck gas and watch the boost build as the revs climb. As the boost gauge gets to 12psi you drop the brake peddle and then mash the gas to the floor. If you get it right all four wheels will spin a couple revolutions, the back will squat while the front points skyward and you will be pinned to the seat as the truck hurtles past 60mph in a couple of short seconds. I shit you not, this is the most violent launch in the automotive industry. Even the stock trucks are intense out of the hole but this one was nearly twice as fast. I always warned people to sit back against the seat and hold their head against the headrest and they thought I was kidding, especially given the look of the vehicle.
    Sometimes I miss that truck.
  2. Mar 15, 2013 at 7:21 AM
    Ostrichsak
    Jer
    I just took delivery of two fishing poles/rods for the wife and I for this summer. I can't want to re-learn how to fish and teach her to fish for the first time. Might have to plan something up at your crib. :cool:
  3. Mar 15, 2013 at 7:30 AM
    Tonto27
    Tonto27 We came, we saw, we kicked its ass!
    Joey
    Denver, CO
    2004 double cab
    A bumper here, some tires there..... you know, stuff.
    Spin cast or fly?
  4. Mar 15, 2013 at 7:31 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Yeah boost launching is awesome. I had a 2 step in my wrx and I would leave the line around 20psi with little to no wheel spin.
  5. Mar 15, 2013 at 7:56 AM
    NativeTaco
    NativeTaco Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    You and the wife are more than welcome up there Jeremy! As long as you guys can deal with our infant daughter and the noise she makes when she gets up to eat in the EARLY a.m. (that is, if you two decide to spend the weekend with us, staying the night). Spinning and baitfishing for trout is one of the easiest ways to get into fishing. If I pick up a canoe or raft at some point that is another fun thing to do. Having access to private lakes takes out the boring frustration of getting skunked.
    I have never fly fished, but I am interested in learning, possibly this summer.
  6. Mar 15, 2013 at 7:58 AM
    Hoyal
    Devin
    2013 Tundra
    Fly fishing is fun. I'm no good but I like to try. :)
    I had a fishing raft that I just have away. It was awesome to fish out of. I would have given it to you. It was a 5 person but held 2-3 with gear and beer really nicely. :)
  7. Mar 15, 2013 at 7:59 AM
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    That's all that counts Dev. I suck at a lot of the stuff I love to do, but I still do it.
  8. Mar 15, 2013 at 8:28 AM
    Ostrichsak
    Jer
    Spin cast. Got a couple of these bad boys in 6' 6" two-piece flavor. Got a smokin' deal (basically got two for what they are normally priced at for one) and that was the only option left. Should suit our needs just fine. :cool:
  9. Mar 15, 2013 at 8:30 AM
    Ostrichsak
    Jer
    I was running Firestone Firehawk all season tires so anything north of 15psi and the traction was in question. Now, on the track with fresh VHT... that's a different story (20psi is no problem) but I'm talking street conditions which can vary greatly.
  10. Mar 15, 2013 at 8:32 AM
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    hate you, i havent been shooting in forever
  11. Mar 15, 2013 at 8:32 AM
    Ostrichsak
    Jer
    I don't sleep too much so that's not a problem for me. The wife is a little bit more picky about her rest (probably why she's so beautiful and I'm... not :D) but in that setting it's not like you sleep super late anyway.
    I've never fly fished but always wanted to try it. It just seemed like a time-consuming and expensive hobby to get into and took a lot more dedication than spin fishing. Maybe someday...
  12. Mar 15, 2013 at 8:57 AM
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Well we go up almost every weekend, and we are having a great time entertaining people up there. Weekends are the only option though, so hopefully that works for you guys.
    Just let me know of a weekend you would like to come up with us and we can make it a plan. If you would rather wait until it gets nicer so we can go fishing, wheeliing, hiking, etc. I don't blame you, but I hike every time I'm up there, I just wear gaiters to keep snow out of my boots. THe wheeling trails that are super close are closed for the season but should open up in a month or two. Fishing is all ice fishing right now, and since I don't have a hut, it would be pretty chilly. Not the kind of fishing to get into the sport.
  13. Mar 15, 2013 at 9:12 AM
    Hoyal
    Devin
    2013 Tundra
    Yeah I forget what tires I ran. But I ran them all the time. They didn't have much tread life.
  14. Mar 15, 2013 at 9:22 AM
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    ice fishing = drink beer and dangle string in water
    go home only when out of beer...
  15. Mar 15, 2013 at 10:22 AM
    Hoyal
    Devin
    2013 Tundra
    I better not get a speeding ticket anytime soon from this minim van. Ill send them the pic of its tail light out.
  16. Mar 15, 2013 at 10:42 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
  17. Mar 15, 2013 at 10:44 AM
    PS78
    Rancher
    2011 DCSB TRD OR
    BAHA HAHAHHAHAAHA, just cause its about women they show nothing but boobs!!!!
  18. Mar 15, 2013 at 10:49 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
  19. Mar 15, 2013 at 11:02 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    GENIUS!!!
  20. Mar 15, 2013 at 12:17 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
