Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Nov 5, 2013 at 5:56 PM
    COBOUNDTACO
    COBOUNDTACO Well-Known Member
    Denver
    2014 DCLB 4x4 TRD Sport Pyrite Mica
    Hi Fellas,
    I was directed to this thread. I'm moving to CO from TX in January, trading in my diesel for another TACO. 2014 TRD. I hear y'all don't like TX transplants but what can I say, been trying to get to CO for a while. Anyway, can someone point me to some good trails to wheel a bit and take the family camping. Truck will be stock for a little while, also I'll be living on the west side of Denver. Probably Golden. Hope to meet some of you soon.
    Thanks!
  2. Nov 5, 2013 at 6:09 PM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    You should have moved further south. You are still too close.
  3. Nov 5, 2013 at 6:12 PM
    Gramps
    Gramps
    07 TRD DC 4x4
    What part of TX you coming from? I have family in Dallas and will be there in 2 weeks. Check out this site for the best trail info.
    Www.traildamage.com.
    A bunch of us run all levels of trails throughout the season. Check out the Upcoming Colorado Events Thread.
  4. Nov 5, 2013 at 6:13 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Don't be jelly, or you can't come sit by the pool this summer. :)
  5. Nov 5, 2013 at 6:22 PM
    Gramps
    Gramps
    07 TRD DC 4x4
    Not so worried about sitting by the pool. You cut me off from smoked meats and we will have a problem.
  6. Nov 5, 2013 at 6:26 PM
    COBOUNDTACO
    Denver
    Thanks, Canyon Lake
  7. Nov 5, 2013 at 6:34 PM
    Hoyal
    Devin
    2013 Tundra
    Smoked meats go along with beers and days at the pool.
  8. Nov 5, 2013 at 9:40 PM
    Hollywood0027
    Hollywood0027 Well-Known Member
    Brad
    Denver, CO
    '95.5 3RZ
    9/2/14 Edit: 4.3 Vortec installed, NP3500, custom NP233 transfer case, high pinion dana 44 SAS with ARB, 4.88 gears, bobbing the bed, 5" lift, boxed rear frame, custom s10 fuel tank mount, etc. 12/16/13 Edit: Currently tearing down a 2000 Blazer to transplant the 4.3 Vortec and 5spd manual transmission (NV3500 I believe) into the Taco. It'll pass CO emissions when done. Planning to post a thread once complete. E-Locker, budget CAI and exhaust, Warn Powerstation, Addicted Off Road bumper, ToyTec OME w/AAL lift, aftermarket stereo w/10 inch subwoofer (only cool when you realize how I fit it in a reg cab truck), dual lexus horns, roll bar, off road lights, CB radio, Powertrax Lock Right locker (front diff), ejecto seat, laser/phaser/ion ray gun, oil slick, heat seaking missles...
    Usually the halo is lit by an LED which should have a resistor to cut the 12V to around 3V. Maybe your resistor is going bad? Or any chance you have condensation in the light? You might try to blow it out with compressed air, otherwise you'd probably have to split the housing to get to the internals which could get messy.
  9. Nov 6, 2013 at 6:47 AM
    Gramps
    Gramps
    07 TRD DC 4x4
    :pout:
  10. Nov 6, 2013 at 6:48 AM
    Gramps
    Gramps
    07 TRD DC 4x4
    See Sean I knew there would be an expert to chime in. And a local one.
  11. Nov 6, 2013 at 8:18 AM
    csuviper
    csuviper Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    Sean are the halo rings LED or CCFL? I thought yours were CCFL. If they are typically bright during the day then they are CCFL. If they are then it could be a problem with the tube or gasses.
  12. Nov 6, 2013 at 8:19 AM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I have epoxy around the lights to prevent moisture, but then again water can almost always find a way in...no noticeable condensation.
    PM sent.
  13. Nov 6, 2013 at 8:21 AM
    T-Rex266
    Elon
    That's a good question...they are bright in the day time if I turn them on (halos)
  14. Nov 6, 2013 at 8:26 AM
    csuviper
    Brian
    Broomfield, CO
  15. Nov 6, 2013 at 8:32 AM
    T-Rex266
    Elon
    But what if that's not the issue?
    And if it were, I'm not sure my skills are advanced enough to replace a halo ring...but if you know how to diagnose it...I know where you live =)
  16. Nov 6, 2013 at 8:36 AM
    csuviper
    Brian
    Broomfield, CO
    I might be able to tell the difference between the two but not sure if i could take it further than that. Especially if Chris already looked at it.
    I dont mind taking a look if your free tonight after 7pm. Swing on by.
    If LED we could find the resistor and replace them after a quick run to RadioShack that is near me.
    http://www.youtube.com/watch?v=tZfzEivtRdw
  17. Nov 6, 2013 at 8:54 AM
    T-Rex266
    Elon
    Chris thinks I have the CCFL ...if that makes a difference.
  18. Nov 6, 2013 at 10:09 AM
    csuviper
    Brian
    Broomfield, CO
    There is not fixing a CCFL tube. Would need to be a replacement of either the tube or the headlight. Check pricing on replacement tubes or if the company you bought from will send a new tube that we can replace.
  19. Nov 6, 2013 at 10:34 AM
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    hey devin, if your down in the denver area you should go get the sammich from hops and pie as soon as possible.
    Artisan Sando of the week: Fried Chicken, Aged White Cheddar, Spicy Ranch, Sliced Tomatoes, Applewood Smoked Bacon, Jalapeno & Green Apple Slaw on a House Roll
  20. Nov 6, 2013 at 10:36 AM
    wuzzy121
    wuzzy121 Well-Known Member
    Colorado Springs
    05 AC 3" lift
    ARB front bumper w/ Warn M8000 winch and lights, 3" lift, Tire gate tire carrier, All-Pro Expedition leaf springs, weather tech floor mats.
    What place is this at, sounds good.
