Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jun 10, 2014 at 11:14 PM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Get a dirt bike. :D :cool:
    I'll offer my services in lessons.
    Braaaaaaaaaaaaaaaap!!
  2. Jun 10, 2014 at 11:36 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I agree completley. Bike is SO much better
  3. Jun 10, 2014 at 11:41 PM
    Husky Driver
    Husky Driver Kyna's chauffeur
    Kipp
    40°35'09.0"N 105°04'38.3"W
    2k T4R3 SR5 (Sport Edition Highlander SX) TRD
    Toytec Ultimate 3" lift susp w/ OME 891 rear coils, Bilstein 5100 shocks front & 5125 rear, ARB 'Roo Bar, Warn VR10k, 0.7, 2 & 11-meter 2 way radios FCC Lic KE0TDD, Nitrogen inflated 33" BFGoodrich All-Terrain T/A KO2s, FlexFuel E-85 conversion, AFe lifetime filter, Savage Offroad rock sliders, Ryno All Terrain 4.5mm skid plates, Line-X coatings on the armor, LifetimeLED & Rigid Industries LED headlights, UltraGauge 1.2, T3q 4.10 eLocker with armor from LROR, AmsOil lubricants used throughout. CBI plate rear bumper with swingaway, SPC Light Racing UCAs, ARB SS170HF Safari snorkel w/ Afrikaans centrifugal pre-cleaner, Tacoma antenna mod, TRD Supercharger w/ URD 7th inj. & URD pulleys, Anti-Dark engine bay lighting system. Having gone 250k, Aug 2016 was the time to replace the original clutch & get the driver's seat rebuilt/stuffed. Front & back Weathertech liners. '05 Tundra front disc brake swap. Full length Rocky Mountain Rack with 40" lightbar, Alternating strobe rear dust lights. I used a warm weekend in March 2022 to finally install my brand new from old stock 2000 4Runner driver's seat. $800 directly from the factory in Sapporo, Hokkaido, Japan.
    Kinda off topic, but I've been mulling the idea of getting a rear elocker & diff from a similar year/mileage 3rd4R or 1sttaco that was totaled in a front end collision from a wrecking yard. Any thoughts, good idea or no?
  4. Jun 10, 2014 at 11:57 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Gonna need the axle housing as well. And abs shafts if your truck doesent have it
    And a regear if it's a different ratio
  5. Jun 11, 2014 at 12:48 AM
    Husky Driver
    Kipp
    Thank G-d it's not cancelled... I already asked for the time off whenever it is. I'd really like to try the Kokopelli trail as an alternative way of getting there & hoping there are a few others that would like to as well.
    http://www.myxj.net/blog/kokopelli-4x4-trail/
  6. Jun 11, 2014 at 3:06 AM
    TheMuffinMan
    Coeur d'Alene, ID
    Though I can see the appeal of those SxS's I just can't get over how pricey they are!
  7. Jun 11, 2014 at 6:52 AM
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    No kidding. My buddy has a RZR 4 900. Great utility to be able to bring 4 people and it does quite well off road but jeebus, it costs almost as much as a new vehicle.
  8. Jun 11, 2014 at 6:55 AM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    You can just get the differential assembly that matches your gear ratio. Then modify your axle housing to fit the new differential.
    This is just a quick search result.
    http://sonoransteel.com/phong/retrofit_electric_locker.html
    I use the ORS harness when I do mine.
    http://www.offroadsolutions.com/products/category/wiring-harnesses/e-locker-wiring-harnesses/
  9. Jun 11, 2014 at 6:55 AM
    TheMuffinMan
    Coeur d'Alene, ID
    20k :eek:
    Just think you could in theory get a brand new base 4cyl manual reg cab taco for less.
  10. Jun 11, 2014 at 7:07 AM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    Damn... just found that my 16" Micky Thompson classic III's are disco'd. they offer one but it's a different BS... need one for my spare, but want to rotate it through rather than keep an unused spare.
  11. Jun 11, 2014 at 7:08 AM
    TheMuffinMan
    Coeur d'Alene, ID
  12. Jun 11, 2014 at 8:12 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I ran the Kokopelli trail following that guys blog into Moab this year. It was a fun trip for sure.
    Only thing I can add is his directions aren't the best, so get some good maps and study up of the bypasses to the couple single track sections. Or just ask me, I just drove it :D
  13. Jun 11, 2014 at 9:00 AM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    How many bypasses did you take? I'm wondering if that's how you finished it so much faster. or if the larger groups really did go that much slower.
    took you what a day and a half?
  14. Jun 11, 2014 at 9:04 AM
    steezemcqueen
    steezemcqueen 4Runner Abuser
    Dylan
    Crawlarado
    1997 4Runner Turbo and 2006 Tacoma
    Unicorn fart injection system
    Did the same thing with mine. You can modify the existing housing to fit the elocker or get a complete axle. Just figure out your current gear ratio and get a elocker that matches. I have a source for elockers so let me know if you need one.
    4Runners are a bit different. The same axle can be used if you just notch the housing and drill/tap a couple holes. Axle shafts are the same too.
  15. Jun 11, 2014 at 9:17 AM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    I used to race dirt bikes when I was little, we've owned an ATV, time to move into the future that is side by sides :D
  16. Jun 11, 2014 at 9:33 AM
    Kappes03
    Kappes03 [OP] Legend of the UG
    Colorado
    2014 Tundra CM
    You guys should see the cost of those mofo's up here in Alaska... Everything is pretty much doubled haha
  17. Jun 11, 2014 at 9:45 AM
    Squeaky Penguin
    Brett
    I followed that guys blog directions exactly. Which had us on the actual trail as much as possible. There's only 2 sections of single track to bypass. We also ran top of the world.
    Started 8 AM Wednesday, set up camp at 8 PM that night. Started at 8:30 the next morning, and we were in Moab at about 3. It was over 150 miles total, I guess we were just efficient and effective. There's no reason that should take 3 days.
  18. Jun 11, 2014 at 10:05 AM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    Sweet ok yeah was thinking of running it on a long weekend if i got a chance and just wanted to make sure I had the time. though I will be taking tons of pics so I imagine it'll take me two full days
  19. Jun 11, 2014 at 10:20 AM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    Me and Matt (Blacktacoma23) were talking yesterday and we were thinking of running a couple trails up in Boulder soon. There's some cool ones, t-33 plane crash, ironclads, bunce school, etc. let me know if you are interested in a day run, most likely on a Sunday
  20. Jun 11, 2014 at 10:25 AM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    There's a separate thread for that, newb!
    =D
    I keed, I keed.
