Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Feb 17, 2015 at 4:38 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    Who needs that when you have lightning bolts on the tires
  2. Feb 17, 2015 at 4:43 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    All these cam bolt and bushing horror stories are making me want to pull mine and anti seize them.
    I have a lifetime alignment with Firestone so.....
  3. Feb 17, 2015 at 4:48 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes
  4. Feb 17, 2015 at 5:00 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Your truck is a 2012, too late, already seized. :p
    Lol, with a lifetime alignment, pull 'em and give a coating and get another alignment. Mark your cams so you can at least get them close when you re-assemble.
    3 of the 4 on mine are seized. I imagine the 4th is seized by now.
  5. Feb 17, 2015 at 5:04 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Just coat the entire bolt or what?
  6. Feb 17, 2015 at 5:14 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    4:05 shows the cam assembly. The bolt usually rotates fine, it's the sleeve (outer surface as well as inner) that he shows that needs anti seize.
    https://www.youtube.com/watch?v=9wh_qqCTeaE
    I think you have to pull the lca off to get at these but I'm not sure. Maybe it's the sleeves that need removed in order to get the lca off. I've never done one myself. :notsure: I always hear that when they are seized, the Sawzall comes into play to remove them.
  7. Feb 17, 2015 at 5:39 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    it wasnt a question... it was a statement.
    eric, take the bolt out. then tap the cam out. antiseize the shit out of the cam. reinsert it. antiseize the bolts, reinsert. done, move onto the next one then have them align it.
  8. Feb 17, 2015 at 6:33 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I'm going to have to pull the coilover aren't I Jace?
    Or If I do them one at a time can I get away without it?
  9. Feb 17, 2015 at 6:35 PM
    OZ-T
    Peter North
    British Columbia
    ?sorry bout that?
  10. Feb 17, 2015 at 6:39 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    you're supposed to put the first ? upside down.
    Like this ¿
  11. Feb 17, 2015 at 6:40 PM
    OZ-T
    Peter North
    British Columbia
    He didn't
  12. Feb 17, 2015 at 6:43 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  13. Feb 17, 2015 at 6:44 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Well he's Jace.
    And he do what he want.
    Cuz he has this hat.
  14. Feb 17, 2015 at 6:47 PM
    M3DIC
    M3DIC Active Member
    Nebraska
    14' Supercharged TRD Sport
    Procomp Stage 1 3" URD MK3 Exhaust
    From Mountain States Toyota to me...
    I wanted to give a quick status on your Tacoma. Based on what I know right now, we still are messing with this. At this point, it does not seem like your issue is fuel related, we have tried to run the vehicle on fresh gas in efforts to try and see if that would have any effect, and we have checked fuel pressure, which indicates that the fuel pump is working completely normally right now. We also have tried to make sure that the injectors were operating properly, and it appears that they are, so it doesn’t appear to be a fueling issue. We have been through most everything spark related, so I don’t believe it to be a spark issue either. What we are wondering now, is if there is something that may be causing a compression issue under certain circumstances. We are going to be running compression, as well as most likely leakdown testing on the engine here shortly in order to determine if there is an issue that may be related in that way.
    I apologize that I don’t have more information at this point, but I wanted to keep you advised as to where we are. I will let you know as soon as I hear more.
  15. Feb 17, 2015 at 6:59 PM
    odomandr
    Andy
    Fort Collins, CO
    Progress is a slow process. The fact that they have done that nd are doing more men's they acknowledge an issue. Hope they get it figured out
  16. Feb 17, 2015 at 7:01 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    And this is why I'm looking forward to bringing my taco to Jace to have the alignment done. Plus I think he's going to have a good time test driving it. :D
  17. Feb 17, 2015 at 7:04 PM
    M3DIC
    M3DIC Active Member
    Nebraska
    I still think it is the supercharger even though they say it sounds normal :-|
  18. Feb 17, 2015 at 7:23 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    damn straight.
    sounds like they are making headway. ruling out the obvious things first. im wondering if you have a mechanical problem, burnt valves, bad rings plugged exhaust. something like that. although it is very odd with a newer truck to have these problems. you said it ran like a top when u bough it used?
  19. Feb 17, 2015 at 7:25 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    haha well thanks man! looking forward to it! with a pre runner, im gonna get u a shit ton of caster! should be fun
  20. Feb 17, 2015 at 7:26 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Dafuq U doin in here, Candian?
