Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Mar 14, 2015 at 10:44 AM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    Wobble followed the wheel over to the other side. Had a loose nut on one of the wheel spacers too. Not the axle I don't think, because the wobble went away from the driver side with the swap.
    Gonna do a simple remount and balance for the wobbly one, and if it doesn't balance then the wheel is fubar'd.
  2. Mar 14, 2015 at 10:47 AM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
  3. Mar 14, 2015 at 10:53 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    There is alot going on...... progressing nicely keep up the good work....:D
  4. Mar 14, 2015 at 1:58 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Good job on eliminating one problem. Sounds like it'll be a cheaper fix than an axle, no?
  5. Mar 14, 2015 at 2:21 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Point b
  6. Mar 14, 2015 at 2:36 PM
    303tacoma
    Rebecca
    Much better!!!!:bananadance:
  7. Mar 14, 2015 at 4:04 PM
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    To anyone who has sold used tires in the past.... Have you had any luck. I'm thinking about pulling the trigger on some MAXXs and selling my Duratrac 285/75/16s with about 1/4" left. The Coopers have a rebate right now too...
  8. Mar 14, 2015 at 4:47 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Craigslist
  9. Mar 14, 2015 at 5:28 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Maybe we could try this method next time :D
  10. Mar 14, 2015 at 5:33 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Easiest is to loosen that retention nut (show w/box-end wrench applied in that photo) while still on the truck. Just jack up the truck & put on stands. Then support the lower portion of the suspension system w/jack after removing wheel/tire. Then loosen the retainer nut on top & slowely lower jack holding suspension system & pressure is relieved from your compressed spring. Reverse order for installation. Easy peasy.
  11. Mar 14, 2015 at 5:33 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Pretty productive day...
    We got Jeremy's lift on. The bilsteins he bought had 886x springs on them. The perch on the driver side was set on the third clip up and the passenger side was set on the 2nd clip up. :eek:
    Apparently the guy he bought them from blew up his CVs in less than 3k miles.. Well yeah!
    Anyway, I talked him out of putting the 886s on at all for now with no bumper/winch. We put his stock springs on the bilsteins with perch at the top instead and he can swap in the 886s when he gets a bumper.
    I swapped my old leaf pack w/AAL for his leaf pack rather than take them apart.
    He also had a 1/4 trim spacer that we put on the driver side. Funny thing is, he ended up with 1/4-1/2 lean to the passenger side! (opposite of the infamous taco lean)
    It'll be interesting to see when things settle out if that changes at all.
    All in all, he gained about 3" up front and 2" in the rear. I think he's pretty happy with it.
    Got Noah's wheels swapped.
    Then we decided to anti-seize my cam bolts. It wasn't too bad really. The rear bolt on the driver side was the only one with any significant corrosion.
    The front passenger bolt looked brand spanking new. At any rate, they all got a good coating of anti-seize so they should be good to go. :thumbsup:
    TL;DR
    Had fun, got a lot done. We didn't let Ray make ANYTHING out of PVC.
  12. Mar 14, 2015 at 6:47 PM
    T-Rex266
    Elon
    X2
    Sold my last set there in a week
  13. Mar 14, 2015 at 6:54 PM
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    I went over to gramps, drank beer and broke a head off a carriage bolt!!! Fun day :D
  14. Mar 14, 2015 at 7:10 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    I got some heckling in. Tried to stay out of the way, moved an item, stopped a socket from rolling away, and gave the jack a pump one time. And now the baofeng is programmed
  15. Mar 14, 2015 at 7:15 PM
    ffemt2987
    Austin
    Golden
    Cool. price suggestions anyone?
    Thanks!
  16. Mar 14, 2015 at 7:20 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Nice!
    Forgot, I pulled my LCA skids off and I think I found out why it was hitting.
    The passenger side wasn't hitting. It also had about 1/2" of shims under one of the bolt holes that weren't present on the drivers side.
    Ray took them and I think he's going to see if he can fix them with PVC or something.
  17. Mar 14, 2015 at 7:44 PM
    JPC
    JPC Well-Known Member
    JPC
    Highlands Ranch, CO.
    2011 DC SB TRD 4X4
    5100s front & rear, 2"AAL, KMC XD wheels, Hecuules Tera Trac AT II 265/65/17 tires, ARE Color Matched Topper, Thule Roof Rack, Alpine INE-W940
    You did a damn fine job sir!
  18. Mar 14, 2015 at 7:50 PM
    JPC
    JPC
    2011 DC SB TRD 4X4
    I am super happy with the Altitude Adjustment and can't get over how smooth the truck rides now. It was a damn good day fellas!
    Sway bar, we don't need stinking sway bars...
    Eric you are a hell of a guy, thanks for helping me out buddy!
    it was great getting to meet and wrench with everyone today, looking forward to the next mod day.
  19. Mar 14, 2015 at 7:52 PM
    M3DIC
    M3DIC Active Member
    Nebraska
    14' Supercharged TRD Sport
    Procomp Stage 1 3" URD MK3 Exhaust
    Update for those who have been monitoring my Tacoma's issues...
    Picked up my Truck yesterday from Mountain States. As you remember, or if just now reading this I have had it in the shop for nearly a month plus now. Two weeks ago picked it up, and broke down again with crank shaft sensor failure code.
    At any rate, they replaced the sensor and said it was running as designed again... (they said this two weeks ago when I picked it up) even though they told me in person that it was no longer misfiring, but yet paperwork said different. So, made it back to Nebraska with no obvious engine issues, however while on interstate I noticed it was still not shifting like it should, longer delays to downshift, or hard shifts into higher gears after it had powered up hills. This also concerns me because it has never had to shift down for these hills before during travel. The supercharger always was able to boost and never had to shift. The supercharger itself is way louder inside the cab as it was when problems started happening... It used to be very smooth and unnoticeable during idle and only had the typical "whine" when accelerating. So... I am really at loss for what to do next. I barely got Toyota to cover anything on this because they blamed me for putting poor quality fuel in it. I think unfortunately I may have to trade it in and get away from it. Driving it is stressing me out.
  20. Mar 14, 2015 at 7:59 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    A quick weld should get it done.
