Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Mar 22, 2015 at 4:08 PM
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    I was told from center of hub to bottom of fender was 23" to achive 3" of lift. That is with shocks loaded of course.
  2. Mar 22, 2015 at 4:26 PM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Not the answer I was looking for but thanks for playing.
    We have some parting gifts for you from our sponsors.:D
  3. Mar 22, 2015 at 8:22 PM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    I was in Eagle Pass, TX. It's a couple hours S/SW of San Antonio. Basically out in the middle of nowhere.....
    I was surprised I didn't see any of that :eek:
  4. Mar 23, 2015 at 6:37 AM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
  5. Mar 23, 2015 at 7:19 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    I am a bit late but you will have to call Toytec as I have never fully gotten an answer to this myself. As Phil states they typically tell you the center of hub to bottom of fender measurement. And I know you can only have a max of 2"s of thread showing on the bottom.
    I think the "turns" on the adjuster might vary based on you front end weight and the spring you have installed on the coil overs. So there might not be one clear answer.
  6. Mar 23, 2015 at 7:39 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Seems funny that they would reference such a non-technical measurement.
    The fender's aren't flat and level, so that lends itself to differences in interpretation of the measurement.
    Also, that all goes out the window when you trim your fenders right?
  7. Mar 23, 2015 at 8:00 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    This is how they measured to see if my rear leaf pack was in spec.
  8. Mar 23, 2015 at 8:21 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    what was the verdict on that?
  9. Mar 23, 2015 at 8:25 AM
    odomandr
    Andy
    Fort Collins, CO
    Still awaiting an answer. I told them I didn't expect an immediate fix so when they get it they will contact me
  10. Mar 23, 2015 at 8:51 AM
    PS78
    Rancher
    2011 DCSB TRD OR
    when thats the only answer i know of thats what i offered up!!! you can't just turn them like 3 turns and expect to get exactly the measurements your looking for, you will have to have the truck suspension loaded and then crank em up, drive it to jostle the suspension and then take a measurement. If that didn't work then crank the wheels all the way in one direction to gain access to the rings and crank up again, or down again and start the whole process over. If your not willing to do that then id suggest calling toytec and have them tell you the same thing. :p
    eric (michelin man) is correct as well that once you cut your fenders that measurement goes out the window
    Good luck
  11. Mar 23, 2015 at 9:15 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I mean in terms of them being in spec or not? Did they have an answer for that?
  12. Mar 23, 2015 at 9:20 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    Did that guy with the supercharger problem ever get it worked out?
  13. Mar 23, 2015 at 9:47 AM
    Jefes Taco
    Denver, CO
    Got through a few minutes ago. It's all dependent on thread pitch used and they have used several thread pitches. He thought that 1 turn would equal ¼" but based on my notes and measurements, it looks like the thread pitch I'm working with works out to 1 turn equals ⅛".
    I ended up going too high yesterday and need to bring them down a bit. I'll see if I can come up w/ some sort of rough estimate for future reference.
    I did 20 and 23 turns and ended up going up almost 3". That roughly equates to ⅛" per turn, roughly. When I had measured on the actual threads and backing the lock nut 1 turn it measured about 1/16" so I used that for my rough estimate. 20 turns would equal approx. 1 ¼". The Toytec tech did state that it wouldn't translate from 1" to 1" on the threads to lift ratio.
  14. Mar 23, 2015 at 9:57 AM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    You guys must be talking about the BOSS Coilovers?
    Because on my Toytec ultimates we only had to crank them 4 or 5 times for an inch, because 1/2" up on the threads was equal to 1" more lift.
  15. Mar 23, 2015 at 5:01 PM
    odomandr
    Andy
    Fort Collins, CO
  16. Mar 23, 2015 at 6:13 PM
    Gramps
    Gramps
    07 TRD DC 4x4
    Hell yeah man. I gained 2"s of lift when I trimmed my fenders. :p
  17. Mar 23, 2015 at 6:40 PM
    odomandr
    Andy
    Fort Collins, CO
    I've only lost inches lately, more mods less lift
  18. Mar 23, 2015 at 7:01 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Random question but do any of you guys have a best buy movers coupon they aren't going to use? Thinking about buying a new tv and the 10% coupon would really help.
    Thanks,
    Charlie
  19. Mar 23, 2015 at 7:03 PM
    Madjik_Man
    Colorado Front Range
    Happens to the best of us, my friend.
  20. Mar 23, 2015 at 8:05 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    I've been in touch with them for sliders for EXACTLY the same reason. Well, I still want them jack-strong so my budget is a bit more. They are around $500 for a double cab, bolt-on as is, or drill a couple holes in your frame and make it jack-strong. I haven't found anything cheaper unless you get into nerf bars. If you're willing to bolt it on, that's probably what you'd pay for cheap sliders AND to have someone weld them. And you'd have to prime/paint/Herculine or whatever yourself. This is my next purchase after the tonneau cover.
