Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Oct 4, 2015 at 7:34 AM
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    You can give rocky Mountain driveline a call. They did a great job fixing my driveshaft after I bent the crap out of it. They are on the north side of denver.
    303tacoma[QUOTED] likes this.
  2. Oct 4, 2015 at 7:38 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    trust me i agree with your rant I think thats what im gonna do double cardan.I just need some guidance on what to ask for and a place to go Im not well versed in this area and dont want to get taken advantage of so any help is appreciated.
    Thanks Brett
  3. Oct 4, 2015 at 7:39 AM
    303tacoma
    Rebecca
    thanks Leo
  4. Oct 4, 2015 at 7:41 AM
    FtApache
    FtApache Well-Known Member
    2019 Raptor
  5. Oct 4, 2015 at 7:45 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    Wrong thread this is the state of Colorado bull shit thread not bs about the truck
    CO MTN Steve, T-Rex266 and 303tacoma like this.
  6. Oct 4, 2015 at 7:45 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Hmm... nearly 4"s of lift in the rear on mine and almost 90k miles with no issues still.
  7. Oct 4, 2015 at 7:47 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    :thumbsup:
    303tacoma likes this.
  8. Oct 4, 2015 at 7:59 AM
    303tacoma
    Rebecca
    Maybe it has something to do with the weight in back.. Mine has no weight in back.Its a take off and 20-30mph no high speed. it was gone for awhile.
  9. Oct 4, 2015 at 7:59 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Geez what a rant!
    Nobody cares about your cardigan sweaters old man.
    Gramps likes this.
  10. Oct 4, 2015 at 8:01 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Fucking fanbois. :luvya:
    :D
  11. Oct 4, 2015 at 8:10 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I don't know if it will help you or not Rebecca, but there's some information here : http://www.4xshaft.com/
    I've heard good things about tom woods
  12. Oct 4, 2015 at 8:14 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    This is what 2nd gens have.
    please read the last paragraph.
    Two Piece Drive Shaft[​IMG]
    Our Two Piece Drive Shaft is used in many applications where it would be impossible to run a single drive shaft because of an obstruction. In essence, wherever the drive shaft has to go around a corner. Common applications are the more extreme built Jeeps or rock buggies with an automatic transmission.
    We believe our design to be the best for the following reasons:
    • Rigid center support bearing. This eliminates lateral flexing of the drive shaft which occurs when using a soft, resilient center support bearing.
    • Each section of the drive shaft has a provision for compression and extension. Regardless of how rigidly you mount your engine to your frame, there will always be some flexing of the frame, motor and mounts. This will equate to a minor length change between the transfer case and the center support bearing. Even if this is only a few thousandths' of an inch, this needs to be accounted for.
    • The spline section between the transfer case and the center support bearing is a 1.375" diameter spline hardened to automotive specifications. All other components are “off the shelf”.
    Available in 1310, 1350 & 1410 series. Or any combination of these joint sizes.
    As shown in the photo, the D2-2nd section can be made with our ultimate travel drive shaft. For applications which require a long stroke in the drive shaft.
    We suggest that you obtain the pillow block/center support bearing and mount it to your vehicle then take the appropriate measurements. The bearing used is a standard 1.375" diameter, 2 bolt, pillow block bearing, with a set screw type locking - such as the Browning brand shown at this link.
    We have a similar bearing available for $40.00.
    The information required to order is the universal joint size required at each location and the length measurements which are the D2-1st, D2-2nd and the D2-OA.
    Please keep in mind that with this type of drive shaft, it will be impossible to maintain good drive shaft geometry. You will experience some vibration issues. The amount of vibration cannot be determined prior to installing the drive shaft. Minimal joint angles will net the smoothest operating drive shaft. It is for this reason that we highly recommend this be for low speed applications only such as off road only or in a vehicle with locking hubs so the drive shaft will not be turning at a high rate of speed.
    For more information or pricing please feel free to contact us via phone, fax or E-mail.
  13. Oct 4, 2015 at 8:17 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    Rebecca, we have exhausted hours and tons of money trying to fix that take off vibe in the tacos with auto trans... it's freakin ridiculous how difficult it is. Toyota engineers were at my shop for a few days trying to fix one truck. Couldn't do it completely.... lifting it only makes it worse. I tell most people, if u lift it... its a characteristic youll have to live with
    Gramps and RockyMtnTRD like this.
  14. Oct 4, 2015 at 8:22 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    But it sounds like Rebecca's problem is a slow speed "take off" issue rather than a high speed vibe? :notsure:
    Could she be experiencing axle wrap or something?
  15. Oct 4, 2015 at 8:23 AM
    303tacoma
    Rebecca
    So are you saying adding a double cardan would be a waste of money?
  16. Oct 4, 2015 at 8:25 AM
    FtApache
    2019 Raptor
    :D
  17. Oct 4, 2015 at 8:28 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    No, what they are saying is that this type of design is prone to vibrations when angles start to increase. I've watched her truck leave my driveway more that a few times, axles rides solid. She is a mellow driver too.
    That two piece style shaft with the 3 single joints was originally meant to mimic a single, straight driveshaft. At highway speeds or off road, the center joint gives some articulation as the suspension flexes. Most vibes are minimal, at stock height, and most will not notice them, but trust me, they are there.
    When you lift it that center joint now has to match both the front joint angle and the rear joint angle in equal but opposite degrees. Ain't gonna happen. This is where all that shimming here and there comes into play is an attempt to make those angles play well with each other. You end up chasing the vibration from one end of the spectrum to the other. You have to decide what you want to live with, take off vibe or 60 mph vibe, for instance.
  18. Oct 4, 2015 at 8:28 AM
    303tacoma
    Rebecca
    Yes at low speed and take off never felt at high speed.. Stock no vibes at all.. Same rims tires before and aft lift..Same vibe with aal and Dakars original leaves 2+1
  19. Oct 4, 2015 at 8:31 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    No he's not saying that. You NEED a double cardan joint on a two piece driveshaft to make it work right.
    Hell, I have a double cardan shaft on the front of my Scout, single piece shaft. The double cardan is needed to alleviate extreme driveline angles during full droop as well. It also runs down the interstate vibe free at any speed. The key to these joints is that the dumb end has to be in line with the pinion.
  20. Oct 4, 2015 at 8:43 AM
    303tacoma
    Rebecca
    ok so can they add a double to my diveshaft where the center u joint is and they would need to shorten the small piece?
