Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Mar 9, 2016 at 7:03 AM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    There is a specific break in procedure for differentials. The gears must be heat cycled in a specific order/time.
    SilverGhost and 3378jakesr5 like this.
  2. Mar 9, 2016 at 7:04 AM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Id ask you to do that for my truck then but then i would be worried i would have to buy new tires afterwords
  3. Mar 9, 2016 at 7:09 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    I have used the meguiars interior cleaning solution for all of the dogs boogers and slobber, stuff has worked great.
  4. Mar 9, 2016 at 7:12 AM
    WillT
    WillT Well-Known Member
    Colorado
    '21 Colorado ZR2 Bison
    I find if I lay the windex on really generously and then use roughly a roll of paper towels, that film will finally go away. If I'm sparse on the windex or I use a rag instead of paper towels, it just smears it around.
  5. Mar 9, 2016 at 7:23 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I was reading up on this for break-in/heat cycling preparing myself.
    http://eastcoastgearsupply.com/files/PDF Files/break-in-procedure.pdf
    A lot more complicated then just going easy on it for a bit. Was wondering what this meant for the front diff though.
    SilverGhost, Gramps and 3378jakesr5 like this.
  6. Mar 9, 2016 at 7:46 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  7. Mar 9, 2016 at 7:49 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    Seriously this is the best glass cleaner I've ever used. No streaks and cuts through whatever is on the windiest, no problem. Walmart carries it and it's not expensive.
  8. Mar 9, 2016 at 7:50 AM
    Wulf
    rock raisin
    Don't use this on film tined windows!
    It turned mine purple
    Blacktacoma23 likes this.
  9. Mar 9, 2016 at 7:51 AM
    Detective_Dan
    Colorado Springs
    Weird. I've used it for a long time now on my tint and it's done nothing but clean them perfectly.
  10. Mar 9, 2016 at 7:55 AM
    CO Ryan
    CO Ryan Well-Known Member
    Colorado
    13 TRD Offroad
    stuff
    I use that to clean EVERYTHING.
    3378jakesr5 likes this.
  11. Mar 9, 2016 at 7:56 AM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    It's funny you suggested this product because this is what I was using before windex and neither did the job. I figured this one didn't work cause it was cheap which is why I switched to windex.
  12. Mar 9, 2016 at 8:09 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Or just stay behind him. :D
    3378jakesr5[QUOTED] likes this.
  13. Mar 9, 2016 at 8:11 AM
    3378jakesr5
    jake
    littleton colorado
    way way behind him!!!!
  14. Mar 9, 2016 at 8:51 AM
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    Downside: Coworker put his 2 weeks notice in and they company is letting him go tomorrow.
    Upside: I get his job, and maybe a raise
    Downside: I'm looking to leave the company soon and have to wonder will they honor the two weeks notice or not......
  15. Mar 9, 2016 at 8:55 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Every where I worked, once a 2 week notice is put in they must be paid for it, even if they say pack up and go.
  16. Mar 9, 2016 at 8:56 AM
    thefatkid
    Brian
    Colorado
    2004 thingy
    Sorry, I got busy at work and didn't have time to post that link. I recommend that for everything other then the gear oil (80-90 works). I also like to do 3 heat cycles with over an hour between rather then 20-30 minutes. I have measured diff temps over 160° on the housing while breaking in, I like it to be completely cool before I drive again.
    for 4wd, either pull the rear drive shaft or only run with the t-case engaged when going straight.
    Keep top speeds below 55ish MPH for break in, I try for 45 top speed.
  17. Mar 9, 2016 at 9:08 AM
    Squeaky Penguin
    Brett
    I think I'll just take a whole day and a network of dirt county roads and break them in in 4WD. Spending this much money I want to make sure the break in is done as good as possible.
    Gear oil selection any different given the front ARB? I thought I read that they recommend 85-140 too.
  18. Mar 9, 2016 at 9:09 AM
    crolison
    Ar vah da, CO
    POS
    Unfortunately not at my company :(
    Luckily if I put my two weeks in my company has to rush to fill my position and get someone trained as there are only two people that do my job at my company and we are both 100%+ billable
  19. Mar 9, 2016 at 9:57 AM
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Good sound deadening that isn't crazy expensive?
  20. Mar 9, 2016 at 10:07 AM
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    lama fur? a bunch of your dogs fur you brushed out over the years? ha ha ha, i don't believe a product exists, most of the sound deadening product I've seen has been pretty pricey
    @Gramps you just installed some was your material on the cheaper end of sound deadening product?
    kashtyaatsi and 3378jakesr5 like this.
