Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Mar 30, 2016 at 7:00 PM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    WhAt ?!?!
  2. Mar 30, 2016 at 7:01 PM
    2016spicytaco
    2016spicytaco Spicy Kitty
    Al
    Denver, Colorado
    Turd Gen for Life
    my old jeep did that because of the drain plugs under the floor board. I couldn't find any type of drain holes when I lifted the carpet. I tried the dryer sheet trick and that didn't help.
  3. Mar 30, 2016 at 7:02 PM
    3378jakesr5
    jake
    littleton colorado
    Get some gun vault dehumidifier thingys. Or take up a collection for thise little packets:confused::rofl::boink:
  4. Mar 30, 2016 at 7:06 PM
    2016spicytaco
    Al
    Denver, Colorado
    Turd Gen for Life
    No seriously, I have to use the flipping ice scrapper on the inside of the windshield sometimes
  5. Mar 30, 2016 at 7:19 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Yeah I've never had that problem on my Tacomas.I had an old civic that did that though...
  6. Mar 30, 2016 at 7:22 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    Leaking heater core?
  7. Mar 30, 2016 at 7:22 PM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Do you have rain guards on your windows? If so try cracking the window open overnight.
    2016spicytaco likes this.
  8. Mar 30, 2016 at 7:25 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Unless it's windy and snowing....
    I had 2" on my seats once when I left the windows cracked 1/2" :rofl:
    ebbs15, Stig and 3378jakesr5 like this.
  9. Mar 30, 2016 at 7:43 PM
    Gramps
    Gramps
    07 TRD DC 4x4
    Huh. Never had that problem and I leave mine cracked all the time.
    Oh wait...garage! :D
  10. Mar 30, 2016 at 7:49 PM
    3378jakesr5
    jake
    littleton colorado
    :facepalm:
  11. Mar 30, 2016 at 8:50 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Yeah, that's been my truck the last two storms. Go to get in and both times the passenger side was nice and snowy inside.
  12. Mar 30, 2016 at 9:52 PM
    acidchylde
    acidchylde Well-Known Member
    Fort Collins, CO
    07 Sport AC, black, still pretty much stock
    It depends, and has less to do with the rim and more to do with the tire. I don't know about the 3rd gens, so everything that follows will be 2nd gen. There were at least two different stock alloys to start, a 16 and a 17. Both will fit any 2nd gen with no issues. However no 15 will fit a 2nd gen (won't clear brake calipers) and some aftermarket 16s won't depending on design. Also, width is semi-independent from diameter. For instance those 2nd gens are 16x7 and 17x7.5. The Xrunner came with 18x8. The FJ TRD wheels I run are 16x7.5. What matters on rim width is if the tire has a range that includes that width. Generally, the larger the tire the wider the rim you need. As for diameter, again it's mostly what tire you want to run. Some tire models or sizes only come in certain rim diameters. If you're keeping roughly the same tire size, then changing rim diameter affects how much sidewall you have. I believe the 2nd gen Sport and OR came with the same diameter tire so the difference was in the sidewall for the two different rims - ie 265/65 on the 17s and 265/70 on the 16s. Obviously you can't run a 17 on a 16 rim and vice versa.
    Lifts and spacers are directly related to tire diameter and rim backspacing. You generally add spacers if the tire/rim combination you put on is too wide/close to suspension - most specifically the UCA. Doesn't matter if they're 16s or 17s, just what their backspace is. Lift is for stuffing bigger tires but clearing wheel well (so is cutting, as too large a tire will rub on the back of the fender and cab mount when turning) and possibly increasing suspension travel.
    What people do, or need to do, depends on what they're trying to do. The parts can/do affect each other, so there's no one answer without knowing the total picture of what's changing.
  13. Mar 31, 2016 at 9:23 AM
    2016spicytaco
    Al
    Denver, Colorado
    Turd Gen for Life
    Dude you are amazing. Don't tell Jake that.
    3378jakesr5 likes this.
  14. Mar 31, 2016 at 9:24 AM
    2016spicytaco
    Al
    Denver, Colorado
    Turd Gen for Life
    I don't have rain guards...I haven't tried cracking a window at night time.
  15. Mar 31, 2016 at 9:27 AM
    2016spicytaco
    Al
    Denver, Colorado
    Turd Gen for Life
    Its snowing in Lakewood! Woo Hoo
  16. Mar 31, 2016 at 9:28 AM
    3378jakesr5
    jake
    littleton colorado
    NO THIS F$&@ing SNOW NEEDEDS TO STOP!!! I am getting really tired of working in this sh$t!!!!
    CharlieCafe, ebbs15, Stig and 3 others like this.
  17. Mar 31, 2016 at 9:30 AM
    303tacoma
    Rebecca
    I'm with Jake on this snow is getting old!!!
  18. Mar 31, 2016 at 9:30 AM
    2016spicytaco
    Al
    Denver, Colorado
    Turd Gen for Life
    Dude calm down!!! Don't be having a meltdown like I do every other week.:ohsnap:
    3378jakesr5[QUOTED] likes this.
  19. Mar 31, 2016 at 9:32 AM
    3378jakesr5
    jake
    littleton colorado
    I can do a rant every now and then!!! Also let me take your truck away for two weeks and then we will see how your doing....
    Red Baron and 303tacoma like this.
  20. Mar 31, 2016 at 9:33 AM
    303tacoma
    Rebecca
    :ohsnap:
    Red Baron and CO MTN Steve like this.
