Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Apr 4, 2016 at 12:43 PM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    I was gonna guess UPS "smart" post. It's this "genius" idea that Amazon often uses where UPS deliveres the item from the seller all the way to the local post office where it usually sits for 2-3 days while the USPS figures out how to get it to your house.
    ebbs15 likes this.
  2. Apr 4, 2016 at 12:43 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Well I have a really large lift. So I had a set given to me and I wore them down in a month. :homer:
  3. Apr 4, 2016 at 12:45 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I'm so :jellydance: right now! I love mex food. Have you seen my skin?
    Red Baron and thefatkid like this.
  4. Apr 4, 2016 at 12:56 PM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Yes, the alignment does change when changing rear lift height. Caster will change because of the relationship of the upper and lower ball joint relative to the front/back change. Also, toe can be effected resulting in the steering wheel off center due to a rear toe change because you never get the rear axle back to where it was exactly at before.
    Now, that being said. If you just change rear lift height your alignment will not change any wear angles. It might just drive/feel fucky.
    dgilbert2006, CC33 and odomandr like this.
  5. Apr 4, 2016 at 1:04 PM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Lol can't say that I have
    SilverGhost[QUOTED] likes this.
  6. Apr 4, 2016 at 1:09 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    What's the difference in those and 16?
  7. Apr 4, 2016 at 1:13 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    If you maximize caster in the front a rear lift should not affect the truck negatively to the point of needing a new alignment. Just add the caster back in next time you get it aligned
  8. Apr 4, 2016 at 1:19 PM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    17's require a 1" larger diameter rim:evil:
    3378jakesr5 likes this.
  9. Apr 4, 2016 at 1:20 PM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    :facepalm::bananadead::bowdown:
  10. Apr 4, 2016 at 1:20 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You can mathematically figure out any tire size if you know that there's 25.4mm to an inch.
    285mm section width = 11.2"
    75 is the aspect ratio of the sidewall, so 11.2x.75= 8.4"
    8.4" x 2 (to account for the sidewall on both sides of the wheel) = 16.8"
    16.8" + rim diameter = tire height
    So a 285/75/17 is exactly 1" taller than a 285/75/16.
    Slightly narrower and a little taller than my 295/75/16s. And I like Tundra split spoke 17s....
  11. Apr 4, 2016 at 1:21 PM
    TacoVio
    Kolton
    CO/WY
    Well thanks for that captain obvious :p
  12. Apr 4, 2016 at 1:22 PM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    It's Capt. Planet per @mr optimist
    mr optimist and SilverGhost like this.
  13. Apr 4, 2016 at 1:27 PM
    Tacoma SS
    Denver
    I just got a new client at work
    Score! :cheers: :burp::drunk:
  14. Apr 4, 2016 at 1:28 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Oh shit I totally forgot about getting showered by those rocks.
  15. Apr 4, 2016 at 1:28 PM
    TacoVio
    Kolton
    CO/WY
    Thank you for that! I was wondering the math and sounds like a pretty perfect tire! Is the closest to that in a 16 a 295/75r16?
  16. Apr 4, 2016 at 1:29 PM
    TacoVio
    Kolton
    CO/WY
    Planet? Why is this lol!
  17. Apr 4, 2016 at 1:29 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    You had to be there.....
    TacoVio[QUOTED] likes this.
  18. Apr 4, 2016 at 1:31 PM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    I can remind you if you'd like...
  19. Apr 4, 2016 at 1:32 PM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    there's a video around here somewhere. let's just say I was a little heavy footed... and my Toyo M/T's throw bolders
  20. Apr 4, 2016 at 1:33 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Ha! No! Hey Ray stand here and take pics while I spray rock with my tires!
