Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Apr 18, 2016 at 8:49 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    yeah sorry thats the PDF Maps app, made by Avenza. I have all CO, UT and some WY/AZ/NM MVUM's downloaded. But sometimes areas are missing. Like for some reason the whole Arches NP area of Moab, I need to grab another for that. But with back country navigator you can set the areas to download the topo maps at a certain level of zooming in. Its kind of a PITA since you can only zoom out so far when you are selecting. I just did it for a huge area and it froze up, think i asked for too much! But on BCN, you can import the GPS tracks so even if you cant see the topo, you still see if you are on a previous track (like the ones from traildamage).
    I was just hoping there was an easier way to download the western part of CO than manually selecting blocks at a time.
  2. Apr 18, 2016 at 8:50 PM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    Ok, comparing me to a Heep driver now are we? Hahaha definitely no mechanical expert over here. But yeah the shoes wouldn't budge and couldn't get the drum back on
  3. Apr 18, 2016 at 8:56 PM
    Stig
    Brandon
    Ta no mo
    You could've popped the lid from the master cylinder and then tried to compress the shoes inward. If it was being a PITA, could've put a ratchet strap around it and tightened it just a little. But, now you wont do it again!
    RockyMtnTRD[QUOTED] likes this.
  4. Apr 18, 2016 at 8:56 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    No time. Soon enough.
  5. Apr 18, 2016 at 8:58 PM
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    No he was giving me shit for doing that to my buddies XJ.
  6. Apr 18, 2016 at 8:58 PM
    Stig
    Brandon
    Ta no mo
    Hah, speaking of XJ's. I went to put the parking brake cables on my last one (had a D44 swapped rear), and when I took off the drum, all the parking brake brackets and such were missing. The reason I wanted it was since I was doing the Alpine Loop (and possibly black bear). Didnt end up doing black bear since I didnt want to die if the crappy brakes didnt work on the way down.
  7. Apr 18, 2016 at 8:58 PM
    Jakers83
    Jakers83 Well-Known Member
    Jake
    Denver
    2.7 base.
    OME lift. Tires and wanting more
    As far as I know that is the best one unless you want to get a real gps. I really like my garmen Montana 680. Spendy but I think it's worth it for sure
  8. Apr 18, 2016 at 9:00 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    They'll only go as far in at adjusting rod/clicker wheel will allow, regardless of how much you compress the cylinder. Could try loosening the clicker wheel if it's being that much of a pain. Just remember to adjust it back up after it's reinstalled.
    In my experience, the drum is a bit tricky to get back on due to a lip that wears on them. The shoes don't contact the full width of the drum, leaving just a bit that's a smaller diameter than the rest.
    RockyMtnTRD and Stig[QUOTED] like this.
  9. Apr 18, 2016 at 9:05 PM
    Stig
    Brandon
    Ta no mo
    Yeah, its great for the MVUM PDF's. And you can add points and pictures to the maps. I would imagine pdf topo files for it would be HUUGE though. Between the three apps I have, I'm sure they do 10x what I need. I just have to sit down and learn them. Just like that dang HAM radio.
  10. Apr 18, 2016 at 9:07 PM
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    Thanks.
    http://youtu.be/CLKWQTePdQY
    Stig[QUOTED] likes this.
  11. Apr 18, 2016 at 9:33 PM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
  12. Apr 18, 2016 at 10:08 PM
    CoBackCountry
    CoBackCountry Well-Known Member
    J
    Colorado
    Needs more Dr. Pepper
  13. Apr 18, 2016 at 11:35 PM
    CoBackCountry
    J
    Colorado
    How come no one wants to B.S. with me in the B.S. thread?
  14. Apr 19, 2016 at 5:20 AM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    This. Most people tend to leave at different times, so it's tough to get a convoy going, but sometimes there's one, but usually only a truck or three at most.
    I'll be headed out there the 27th and staying until the 5th. I imagine if you ask there's people leaving just about every day between the 27th and the 1st.
    alee891 likes this.
  15. Apr 19, 2016 at 6:19 AM
    Wes0311
    Wes0311 Well-Known Member
    Wes
    Denver, CO
    '13 SR5
    Toytec BOSS loft kit, add-a-leaf, AntennaX 13" antenna, 285/75's on MB wheels, and more to come
    So if I might have gotten water in my diff last July would I know by now if there was a problem? And how hard is it to relocate the breather?
  16. Apr 19, 2016 at 6:20 AM
    Jakers83
    Jake
    Denver
    2.7 base.
    It's easy to do. Look up the mod for it. It's also very easy to just change the dif fluid
  17. Apr 19, 2016 at 6:23 AM
    Wes0311
    Wes
    Denver, CO
    '13 SR5
    Ok cool. Should I be worried about changing the fluid asap? I don't actually know if any water would have gotten in.
  18. Apr 19, 2016 at 6:33 AM
    Jakers83
    Jake
    Denver
    2.7 base.
    Before I did my mod I would change it if I thought it sucked water into it. Might be over kill but cheaper and easier then new gears. Just my thought though
    CoBackCountry and ebbs15 like this.
  19. Apr 19, 2016 at 6:38 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    The diff breather is designed to relieve pressure from the diff as heat pressure builds up.
    When they are new they actually do a good job of venting the pressure and still keeping water out. There is some discussion of a hot diff hitting cold water and sucking in water but I only see this as a possibility if the breather itself is fubared.
    Your truck is fairly new and the breather should still be functional.
    I did the diff breather relocate on my truck last year.
    It's 20 years old.
    My breather was still working and I have not had any water enter my diff in the years prior.
    So get it done for piece of mind but it's likely it's just fine.
    Hoyal and ebbs15 like this.
  20. Apr 19, 2016 at 6:43 AM
    Wes0311
    Wes
    Denver, CO
    '13 SR5
    Sweet. Thanks for the advice guys!
