Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Apr 19, 2016 at 7:11 AM
    WillT
    WillT Well-Known Member
    Colorado
    '21 Colorado ZR2 Bison
    @Wes0311 Changing the diff oil is stupid simple.
    1) Unscrew plug near top of diff (fill hole)
    2) Unscrew plug at bottom of diff (drain hole)
    3) Wait for puddle on ground to stop getting bigger, or you could be responsible and use some kind of drain pan
    4) Put bottom plug back in
    5) Fill diff case with diff oil until it starts spilling out of the fill hole, you should be able to stick the tip of your pinky finger into the fill hole and touch the top of the oil (check owner's manual for oil to purchase)
    6) Put top plug back in
    7) Wipe off all excess oil/gunk from diff case
    Drained diff oil should look like used oil, if it looks like milk/mud you had water in there.
  2. Apr 19, 2016 at 7:34 AM
    Madjik_Man
    Colorado Front Range
    You're fine. We have one way valves on the differential to act as a breather. Let's hot air/gas out, but no water in. At least on the 1st gens, we do. Don't know about the 2nd gen.
    I've driven through tons of water crossings in my truck's lifetime and my rear diff fluid has always been fine.
    That said, add this mod to the list of "getting around to it" projects I have on my work bench.
  3. Apr 19, 2016 at 7:37 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Don't know if it's different on the first gens, but the second gen diff breather is one way only. It only lets pressure out.
    When the diff cools (like it would in water) a vacuum is created because the breather won't let air back in to the diff.
    The problem is water being sucked in through the axle seals when this vacuum occurs, causing seal failure and water in the diff.
    ebbs15 likes this.
  4. Apr 19, 2016 at 8:32 AM
    Wes0311
    Wes0311 Well-Known Member
    Wes
    Denver, CO
    '13 SR5
    Toytec BOSS loft kit, add-a-leaf, AntennaX 13" antenna, 285/75's on MB wheels, and more to come
    Alright. Thanks for the info everyone! Definitely helped put my mind at ease there. When the semester is over and I have more free time I'll work on those!
  5. Apr 19, 2016 at 8:57 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I'm staying out of this rear diff oil talk. :p
    Night Eagle likes this.
  6. Apr 19, 2016 at 10:34 AM
    sbchero
    sbchero Wheeler
    Garrett
    Brighton CO
    14 TRD Sport 4x4
    TC L/T, King shocks/bumps, F/R ARB's, RCV Shafts, glassworks fenders/bedsides.
    milkshake oil is great for bearings.
    SilverGhost likes this.
  7. Apr 19, 2016 at 10:53 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
  8. Apr 19, 2016 at 11:57 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    The diff breather is just a metal cap with a spring and a rubber disc. The spring holds the rubber disc against the breather outlet. When pressure from heat builds up, it forces it's way out past the disc, overpowering the spring. When the pressure goes back to normal, the spring/rubber disc close the opening.
    Where it gets fucked up is when the spring stops working, rusts away, gets jammed because the truck was run in mud too often, etc...
    \If you don't have a breather, you will blow the oil seals, that's when you get a leaky pinion or axle seal.
    I've heard talk of the possibility of water getting past the oil
    seals, I don't subscribe to that theory though.
    The breather design is the same for all vehicles, regardless of make or model. The breather on the Tacoma is the same as is found on Dana axles, aside from the screwy metric threads. They've been around for decades.
  9. Apr 19, 2016 at 12:13 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
  10. Apr 19, 2016 at 12:31 PM
    Hoyal
    Devin
    2013 Tundra
    Go to work and leave those there so I can steal them. :D
    T-Rex266[QUOTED] likes this.
  11. Apr 19, 2016 at 12:48 PM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    The sad thing is he is just building tire swings with them. :D
  12. Apr 19, 2016 at 12:50 PM
    Hoyal
    Devin
    2013 Tundra
    Haha!! Nooooooo!! I'll need them in like a month. :p
  13. Apr 19, 2016 at 12:52 PM
    hendo808
    hendo808 Well-Known Member
    2016 TRD OR Access Cab Barcelona Red
    Interior Phillips LEDs Diodedynamics LED reverse lights HIDs for lows and fogs VLED's V3 Tritons front and rear TEQ TRD Bedside Decal 35% Tint
    I guess my first post could be here. Wife and I will be moving out to Fort Collins in a few months for her to finish her PhD. So in light of this, I just picked up a TRD Off Road access cab in barcelona red. Looking forward to the move and our first Tacoma.
  14. Apr 19, 2016 at 12:53 PM
    hendo808
  15. Apr 19, 2016 at 12:53 PM
    Hoyal
    Devin
    2013 Tundra
    Lots of us in northern Colorado. Let us know when you get here.
    VLocos24 likes this.
  16. Apr 19, 2016 at 1:46 PM
    sbchero
    sbchero Wheeler
    Garrett
    Brighton CO
    14 TRD Sport 4x4
    only one? do you have to wait 4 days for 4 tires? :luvya:
  17. Apr 19, 2016 at 2:02 PM
    T-Rex266
    Elon
    5 :p
  18. Apr 19, 2016 at 2:05 PM
    sbchero
    sbchero Wheeler
    Garrett
    Brighton CO
    14 TRD Sport 4x4
    5 days? or 5 tires? at least your a smart one and actually bought 5 tires.
  19. Apr 19, 2016 at 2:11 PM
    T-Rex266
    Elon
    5 tires
    Tires are probably taller than my arm length
  20. Apr 19, 2016 at 2:11 PM
    sbchero
    sbchero Wheeler
    Garrett
    Brighton CO
    14 TRD Sport 4x4
    not tire related but i was at the glamis sand drags once and there was a retarded huge f350 with 42's and he got stuck. had 4 wheel drive but the 20" wheels he had hub covers. couldnt lock the front end in. i offered to hack off the dumb plastic covers for him, he said he didnt want to mess up his truck. i told him to get a jack then and take off the tires.
    i left after that.
