Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jun 15, 2016 at 7:32 AM
    Kappes03
    Kappes03 [OP] Legend of the UG
    Colorado
    2014 Tundra CM
    You quoted me before I fixed it.. typo. Either way you knew what I meant pssh
  2. Jun 15, 2016 at 7:33 AM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    ninja fast!
  3. Jun 15, 2016 at 7:36 AM
    Stig
    Brandon
    Ta no mo
    Yeah, when I start bringing in the paychecks again, I'll definitely have to upgrade and I am sure it wont be cheap. Figured I would run the 5100s until then, but if they have their own problems, its probably not worth the trouble.
  4. Jun 15, 2016 at 7:48 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    You are taking one more step down going 5100. I would be on the look out for a used set of something to get you through until you can pull the trigger on a good set.
    Stig[QUOTED] likes this.
  5. Jun 15, 2016 at 7:50 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Keep an eye out for used set of shocks, I can rebuild them for you. Same with the upper arms. 1" uniballs are pretty cheap and easy to replace.
  6. Jun 15, 2016 at 8:16 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    what jace said...ran OME for many years...took a lot of abuse and was a great setup for what i needed...
    i moved to different setups as my budget allowed and my need for more travel increased
    the BP51 would be a bad ass setup to have...probably similar travel issues though as the aussies tend to play conservative on the compressed side which will limit your extended lengths.
    alee891 likes this.
  7. Jun 15, 2016 at 8:23 AM
    50 amocaT
    50 amocaT Well-Known Member
    Jeremy
    H.Ranch Co
    Curious to know if you can you wrap the TRD Sport hood with the scoop?
  8. Jun 15, 2016 at 8:25 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    How much does it cost to cover the hood and fenders? Rough estimate?
  9. Jun 15, 2016 at 8:32 AM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Now your budget is saying you need more travel. :boink:
  10. Jun 15, 2016 at 8:43 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    I'm curious how well they sealed the external adjusters from the elements and if they anodized the back sides to keep corrosion down.
    I'm not an ARB fanboy and so far i'm unimpressed with the OME setups as a whole. But then again I might be a little biased to a "real" shock setup.
  11. Jun 15, 2016 at 8:52 AM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    I have external compression and rebound adjusters on my dirt bike suspension and have no issues with all the mud, dirt, dust, and water crossings that I run through.
    What I meant to say is external rebound and compression adjustments on suspension is not a new thing. It's not too hard to do it right.
  12. Jun 15, 2016 at 9:10 AM
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    Jeff Beckett @sn0wrunner but is never on here, PM me and ill give you his information. He just did Dylans 4R in green
    Stig and CO MTN Steve like this.
  13. Jun 15, 2016 at 9:15 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Ohlins?
    They have been building shocks for a long time and know what they are doing. Not that ARB doesn't have the R&D to do it right but I would be very sceptical of these new IBP shocks.
  14. Jun 15, 2016 at 9:16 AM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Has anyone heard of, or purchased a audio head unit that is more of a tablet then your typical audio unit? Looking for a head unit that will display apps (like the Torque app) and toggle to audio functions. Ability to download an external app for navigation off road would also be a requirement. Not sure if that is a thing yet.
    Is this what I'm looking for? It kinda looks like it but I'm not too sure.
    https://www.amazon.com/Android-Capa...06498&sr=8-10&keywords=pure+android+car+audio
  15. Jun 15, 2016 at 9:22 AM
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Why not put an actual tablet in?
    CO MTN Steve likes this.
  16. Jun 15, 2016 at 9:22 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I got one for my GX470 that I really like so far. this is the one I got. https://www.amazon.com/gp/product/B0157ZYR2O/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
  17. Jun 15, 2016 at 9:42 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    I have seen a write-up or 2 on putting tablet with radio (buried behind in dash). I will see if I can find.
    Edit: Found this but recall many ipad/ mini ones in TW.
    https://www.youtube.com/watch?v=iW165hO7Okw
  18. Jun 15, 2016 at 9:54 AM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
  19. Jun 15, 2016 at 9:57 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    whenever you compare the higher end products to the budget options, you will never be satisfied.
    all depends on what your needs are and what you can afford
  20. Jun 15, 2016 at 10:00 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    By the time a bought 5100, nitrochargers, 3 different sets of coils, and my time to swap it out over and over, I was most of the way to a set of coil overs.
    Do it right or do it twice....
    ....or three or four times.
