Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jul 24, 2016 at 12:16 PM
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
    I dont think you'll fit the 35s without cutting/tubbing unless you only drive straight. I could be missing something here though.
  2. Jul 24, 2016 at 12:20 PM
    Kappes03
    Kappes03 [OP] Legend of the UG
    Colorado
    2014 Tundra CM
    They're in Lakewood off Colfax. Jason is my better half's cousin.
  3. Jul 24, 2016 at 12:41 PM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    He is a first genner so he has to cut a good 2-3 inches out of his fire wall and weld in a new plate.
    jubei and tacot0wn[QUOTED] like this.
  4. Jul 24, 2016 at 12:54 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    I had a similar sound, turned out to be those long UCA bolts
    Lakewood. But worth the drive.
  5. Jul 24, 2016 at 1:00 PM
    3378jakesr5
    jake
    littleton colorado
    Ok i have a question, those of you that have popped a tire on the trail, has it ever been so bad that you could not patch and re inflate to get back home? Where the spare was the only option?
  6. Jul 24, 2016 at 1:04 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    What Jake said ;). After hearing both he and Tim weigh in, I've decided to get the alignment after I get done tubbing.
    Thanks, fellas! This forum, and the Colorado forum has been a huge help. I really appreciate it!
  7. Jul 24, 2016 at 1:06 PM
    3378jakesr5
    jake
    littleton colorado
    @TimF does he need the bumps for the shocks or just to stop up? When we did @alee891 we didnt change bumps and only had to hammer in a little bit to make it clear on stuffing.
  8. Jul 24, 2016 at 1:12 PM
    jubei
    NoCo
    Stuff. Also things.
    Not to speak for Tim, but my take is that the cut down bumps, when used with the coilovers removed to determine rubbing, add a little bit of margin to the gap that you create while tubbing. I think it's a good idea, and my stock ones are coming off anyway for a set of Super Bumps once the tubbing is finished. That said, I'm a neophyte with this stuff, so I defer to you guys!
    3378jakesr5[QUOTED] likes this.
  9. Jul 24, 2016 at 1:14 PM
    tacot0wn
    CO
    Yeah when i first got the truck, I took it out on the shitty dunflops and got a sidewall puncture, had to spare it
  10. Jul 24, 2016 at 1:15 PM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    Not personally, but have been on group rides where someone else did. *Sidewall puncture, that is.
    *By saying "popped", do you mean popping the bead? Have seen that too where there was so much mud/rocks/crud between the tire and wheel where it leaked so bad after popping the tire back on that the spare was put on. Be sure to clean that area really well before reseating a bead.
  11. Jul 24, 2016 at 1:44 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Were yours ever removed/reinstalled to make the noise? I've never touched mine other than making sure they were torqued down from the factory trying to find loose stuff.
  12. Jul 24, 2016 at 1:51 PM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Anyone here have experience with the Gopro Hero 4 Black? I see the new Hero 4's have a Night Photo setting that bumps up exposure time and seems to put out some quality night photos.
  13. Jul 24, 2016 at 1:56 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    that's all I've ever seen on the trail. and I've seen it about 8 or 9 times (sidewall puncture) 1 of those was me :D
  14. Jul 24, 2016 at 1:56 PM
    3378jakesr5
    jake
    littleton colorado
    I mean just got a flat due to a puncture in the tire. I have unseated 4 beads and have been able to reseat them all with oba or co2 i have also put a branch through the side wall and was able to plug it enough to get home and ran it for an extra week tell i got new tires. I just have yet to have one where i NEEDED to get the spare out. I think that i would rather try patching a tire first and seeing if that works before grabbing the spare incase i really NEED the spare. I know that if the tire gets punctured its getting replaced so i might as well do what it takes, with in reason. To make that tire work rather then pulling a good tire and run the risk of popping that tire too..
  15. Jul 24, 2016 at 1:56 PM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    If you don't need the action-cam ness of the gopro you can get a really nice mirrorless DSLR for $500-600. Just syn2k.
    alee891 likes this.
  16. Jul 24, 2016 at 1:57 PM
    3378jakesr5
    jake
    littleton colorado
    Do you have a more close up of your puncture other thwn the one provided at the top of the page? :luvya:
  17. Jul 24, 2016 at 1:57 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    death of the michelin
  18. Jul 24, 2016 at 1:58 PM
    alee891
    Austin
    Black Hills
    Tacomaless
    I'm definitely checking out mirrorless cams as well (which would likely be better for night photos). Just curious how the Hero 4 Black performs with the new setting. Haven't fiddled with the Gopro in over a year and brought it out yesterday. I forgot how convenient that thing is
  19. Jul 24, 2016 at 2:24 PM
    Stig
    Brandon
    Ta no mo
    Only thing i've heard about the GoPro 4's is more people having freezing issues with them. There are a bunch of very cheap knock-offs depending on how much quality of a picture you need.
  20. Jul 24, 2016 at 2:26 PM
    Stig
    Brandon
    Ta no mo
    Thats what you should do IMO... attempt to patch and/or repair the tire thats got the hole. If it cannot be fixed, then you swap to the spare and head back to the trailhead before you end up with only three good tires and a $1k tow bill.
