Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Aug 9, 2016 at 8:33 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Have you lifted the tire and grabbed at 9 and 3 and push/pulled opposite of each hand. (idk if that makes sense)
    Stig[QUOTED] likes this.
  2. Aug 9, 2016 at 8:38 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Hadn't done it off the ground until tonight, but did that, as well as 12 and 6 and nothing on either.
  3. Aug 9, 2016 at 8:41 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Ask for the service manager.
  4. Aug 9, 2016 at 8:44 PM
    Stig
    Brandon
    Ta no mo
    Yeah, guess I should've. Instead of sleeping in a little, I get to head down there to have them figure out what john boy did to it. I'll have to find a level area to check fluid levels prior to going in.
  5. Aug 10, 2016 at 5:17 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    So I am not sure if Stevenson works the same as Groove, but you need to get the card of thr Service Writer that has Jace on his team. That would be a sure fire way to get Jace. You call just that service writer and not the main number. But even at Groove if you are in for just a tire rotation and oil change they typically don't go to the Master Tech's to do that.
    BTW Jace is out on his honeymoon right now so request Keith or Evan there.
    303tacoma and Stig[QUOTED] like this.
  6. Aug 10, 2016 at 8:56 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    It worked. :cool:
    My only regret is not making the handle longer. With the preload tension, the handle will snap back with gusto and I'm pretty sure it will draw blood someday. It made a dent in the bedliner... And as the handle is not removeable, I may just have to add some material to it to make it a little safer. I bet it will sting like a bitch on cold fingers in the winter if it ever gets me.
    CharlieCafe, alee891, JDM and 7 others like this.
  7. Aug 10, 2016 at 8:59 AM
    lobsterbait
    lobsterbait The Wall
    Not Paul
    Parker CO
    Goose
    Just a couple things
    I grimaced when I read that. Might need to stuff. Rag in your mouth when you open it in the winter
  8. Aug 10, 2016 at 9:00 AM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Maybe put a tennis ball at the end of it!!!
  9. Aug 10, 2016 at 9:00 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    it may or may not have tagged the palm of my hand already.
  10. Aug 10, 2016 at 9:01 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I was thinking liberal amounts of Plasti Dip. Build up a thick layer.
  11. Aug 10, 2016 at 9:02 AM
    3378jakesr5
    jake
    littleton colorado
    Or i have an old shock that you can have and rig it up as a shock absorber so it cant just punch down.
  12. Aug 10, 2016 at 9:12 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    So I could add like 3"+ to the end, it would give more leverage for opening and closing and maybe keep fingers out of the way, especially if I added a tactile section as a warning.
    Or I could cut it and weld it back at 90 degrees so that it folds over the main bar when latched. But this will kill the leverage. It's fairly stout now to lock down, it ain't going anywhere.
    Another thought is that with the weight of the tire and the rest of the build, it may be enough to take some of the preload off and it could be a non issue. I won't do anything until the tire is on it.
    CO MTN Steve likes this.
  13. Aug 10, 2016 at 9:33 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Plan B, version 2.0 will be implemented. After looking at it and removing the main bar, then remounting it with the locking handle hanging down, the tension goes away about 1/2" below the tube it's hitting now.
    So my plans are to cut the handle short and weld a section back in place that will be parallel with the main bar when it's locked. The cantilever effect should be okay for operation. This will open up several options...
    I can then drill the handle on the end and weld a loop to the main bar that a padlock or bolt or what ever can be inserted into so the handle can not release on it's own.
    With the handle able to drop below the tubing, it will act as it's own safety catch if it should ever come open on it's own.
    In the end, I don't want anything that may remove a finger. I would be extremely pissed off if that handle were to smack either hand during hunting season.
  14. Aug 10, 2016 at 9:33 AM
    2016spicytaco
    2016spicytaco Spicy Kitty
    Al
    Denver, Colorado
    Turd Gen for Life
    Man people in the trading post got me all twisted up...time to chug down some decaf coffee....I will be back in 30mins to do some data dumping on this thread unless of course unless if I get busy with work
  15. Aug 10, 2016 at 10:46 AM
    OdinBow
    OdinBow Just an idiot out wandering around CO.
    Mitch Cumstein
    Erie, CO
    2011 Timberland Mica T|X Pro
    None, but willing to learn.
    Like. Necessity = the mother of invention!! :thumbsup:
    Deathbysnusnu[QUOTED] likes this.
  16. Aug 10, 2016 at 2:00 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    much improvement. I gave it 7/8" gap so as not to pinch my fingers on the flip side and still be able to get a gloved hand under it. I don't have to pre-wince before opening it now :rofl:
  17. Aug 10, 2016 at 2:26 PM
    lobsterbait
    Not Paul
    Parker CO
    Goose
    Looks nice man
  18. Aug 10, 2016 at 2:33 PM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    It's what poor saps pay because they feel the need to buy locally. Find an out of state dealer that'll sell for a good price. Then after the price is agreed upon buy a cheap airline ticket and do a fly and drive it home. I've saved a ton of money doing this for motos, I'm not sure why more people don't do it for trucks too.
    2016spicytaco[QUOTED] and Gramps like this.
  19. Aug 10, 2016 at 3:55 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Thank you! Some paint will make it even better.
    Yous guys with the swing outs..is your spare nice and vertical and plumb with the tailgate?
    or is it tilted top to the front of the truck in a sporty manner?
  20. Aug 10, 2016 at 4:01 PM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    Mine is tilted
