Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Aug 29, 2016 at 3:55 PM
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
    Awesome, thanks man! good looks
  2. Aug 29, 2016 at 4:09 PM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Sounds like 6 more people need to buy in
  3. Aug 29, 2016 at 4:19 PM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    How do you choose how much weight over stock to have the leaf packs built for? The max weight you will ever carry? The weight you typically carry? A random number you pull out of your ass?
    303tacoma likes this.
  4. Aug 29, 2016 at 4:32 PM
    Madjik_Man
    Colorado Front Range
    It's not on this new Gazatteer I bought from Costco. I swear half the trails I know aren't even on this POS. Let me dig up the old one.
    tacot0wn[QUOTED] likes this.
  5. Aug 29, 2016 at 4:36 PM
    Madjik_Man
    It's on the old one but not marked with a number. Like I said in the previous post, if you follow those directions you'll get there.
  6. Aug 29, 2016 at 4:39 PM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    I am going over my typical summer load (the heavier of the two) im ok with a slightly stiffer ride with how much roll i have. And thats going to be the most used. If your planning on getting springs then eventually getting more things down the road i would plan for down the road.
    In terms of figuring weight out i need a stock truck to weigh the rear wheel weight and then we can use that as a base line. We can use my metal yards scale or ask rokmen really nicly about using their single wheel scales.
  7. Aug 29, 2016 at 4:40 PM
    tacot0wn
    CO
    wrote em down :thumbsup:
    Deciding what mountain to hike on saturday now..Between kit carson/challenger point, blanca, or some local 13er.
  8. Aug 29, 2016 at 5:29 PM
    cmanhonor
    cmanhonor Well-Known Member
    Artem
    Colorado
    21 Tundra DC
    Auto..The people who are reporting their transmissions 1~1.5 qts. Low on fluid were the same guys saying there was no grease in their u-joints. My u-joints had nearly no grease in them so I assumed the same for my transmission.
  9. Aug 29, 2016 at 5:31 PM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    What about travel numbers for these things? I'm assuming higher capacity = less flex?
  10. Aug 29, 2016 at 5:39 PM
    3378jakesr5
    jake
    littleton colorado
    More leafs=more flexability. Thats why dakars can flex more then stock and those have 500lbs over stock.
    CO MTN Steve likes this.
  11. Aug 29, 2016 at 5:44 PM
    3378jakesr5
    jake
    littleton colorado
    And erics seem to do just fine. You can even make them longer and get even more travle with less work on the springs. And you can go spring under if you want.
    I think im going spring under and do an orbit ball to help the springs with the travel.
  12. Aug 29, 2016 at 5:48 PM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    I think I'll need to sit this one out. There are quite a few variables in play for me since I would want these to work with a shackle flip and shock relocate, and I don't know where to begin to figure out the specs for the springs that I would need for that. Then of course I would need new rear shocks (probably King) for the relocate, and then my OCD would dictate that I need to change the fronts to match as well.
    Red Baron likes this.
  13. Aug 29, 2016 at 5:51 PM
    tacot0wn
    CO
    Why do people do SUA?
  14. Aug 29, 2016 at 6:01 PM
    3378jakesr5
    jake
    littleton colorado
    You can do all that stuff afterwords too....
  15. Aug 29, 2016 at 6:02 PM
    3378jakesr5
    jake
    littleton colorado
    In my case i like the hight i have and that is with my springs flat/negitive. So mine would be helping the pack and there is a thousand other reasons as to why and why not just google it.
  16. Aug 29, 2016 at 6:05 PM
    tacot0wn
    CO
    Forsure. Ive done a little bit of reading about it but curious why someone with a setup like yours would do it. thanks :thumbsup:
  17. Aug 29, 2016 at 6:15 PM
    3378jakesr5
    jake
    littleton colorado
    Mines just because of ride hight and the ton of weight i have in my truck.... It will get rock rashed more but i still need to talk to Bill more as he is the spring guy so he will tell me what i need.
  18. Aug 29, 2016 at 6:46 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Have you ever wrapped a truck before? You'll need an extra set of hands and a lot of patience.
  19. Aug 29, 2016 at 6:55 PM
    tacot0wn
    CO
    Nope, wrapped many a motorcycle but I can imagine a truck would be much more annoying.
  20. Aug 29, 2016 at 6:58 PM
    2016spicytaco
    2016spicytaco Spicy Kitty
    Al
    Denver, Colorado
    Turd Gen for Life
    Helloooooooooooooooooooooo Cooooooooooooo looooooooooooooooo raaaaaaaaaaaa doooooooooooooooooooo!
    Martyinco likes this.
