Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Oct 19, 2016 at 8:02 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Gotcha, I was hoping to find something a little less used...more able to do moving and shooting and other type of things.
    Coop68[QUOTED] likes this.
  2. Oct 19, 2016 at 8:03 PM
    Stig
    Brandon
    Ta no mo
    And everyone can sleep without worry... No way I'm going outside, it's freaking cold out there. Yogi shall go on as a mystery creature.
    CharlieCafe likes this.
  3. Oct 19, 2016 at 8:03 PM
    lobsterbait
    lobsterbait The Wall
    Not Paul
    Parker CO
    Goose
    Just a couple things
    Shenanigans
    Stig[QUOTED] likes this.
  4. Oct 19, 2016 at 8:03 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    You have less backspacing too, hmm..
    I saw @Ice Horse had hers mounted down on the front of the frame.
    I wonder if they could be mounted on top of the frame, but in the rear behind the coil bucket. Since i removed some of the brake lines, I might have room now.
    Do they have the same stroke as the OME or Bilsteins? They look like they have a short stroke.
  5. Oct 19, 2016 at 8:09 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    We had called ADS and talked to them directly.
    We couldn't find really any spot to put them other than forward against the frame. Tucked them in there nicely. Did have to modify the washer fluid reservoir on the passenger side. They get rubbed just slightly by my tires at full lock, but my wheels don't have much offset.
    Deathbysnusnu[QUOTED] likes this.
  6. Oct 19, 2016 at 8:11 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    So is it correct to assume that King's might/would rub too? I see the common denominator here is lack of room.
    Ice Horse likes this.
  7. Oct 19, 2016 at 8:13 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    -12mm offset. As you've learned, as have I, backspacing is a terrible way to compare wheel fitment across different wheel width.
    First setup was with the resi where Lauren's are. That was way worse in terms of rubbing, but hey, everyone can see your resis, so you've got that going for you, which is nice.
    I tried to mount them on the top of the frame in front of the coil bucket. Cut a bunch of sheet metal away but ended up needing a shorter hose and some different fittings. I've got a set of TC coil bucket gussets sitting in the garage, will be welding those up this winter and trying to attach the resi to those.
    As far as stroke, not sure, you'd have to call them. I did gain like 3/4" of droop travel though, I don't know how much was attributable to the UCAs though. Stock UBJ was the limiting factor on downtravel before.
  8. Oct 19, 2016 at 8:13 PM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    The snap on guy who comes to my shop rents and sells the bikes and conversion kits.
    Toby Till 303-519-3222
    The Resi can go wherever you want as long as it fits, doesn't hit the tire, and the hose doesn't rub and get a hole in it.
    1st gens are a short stroke shock regardless of brand, most are only 5" to 6" ish. I would run a long hose and put it way up in the fender almost near the top. Gets it out of the way and easy to P clamp the hose out of harms way.
    I Have most of the parts to add a resi to my 'Burg(SAW/aFe) bolt ins. The funny part is the resi would the 3-4" longer than my shocks now. Extreme overkill, but hey why not.
  9. Oct 19, 2016 at 8:19 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Thank you sir.
    Can hoses/fittings be changed and the shock not lose it's charge or oil? or is it no problem to refill or charge afterwards?
  10. Oct 19, 2016 at 8:20 PM
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Boo!
  11. Oct 19, 2016 at 8:50 PM
    Stig
    Brandon
    Ta no mo
    I would have to get out of the hammock and go to the corner of the porch to see where it would be searching for food, and it looks hella dark out there to boot. So I'll enjoy my warm'ness inside.
    But if you want to donate a game cam to the cause, we can see what lurks in the dark.
  12. Oct 19, 2016 at 8:51 PM
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    Hmmmmm
    Kappes03[OP] likes this.
  13. Oct 19, 2016 at 8:52 PM
    Stig
    Brandon
    Ta no mo
    :lalala:
    haha. I want, but really dont need.... but probably will end up with sooner or later.
  14. Oct 19, 2016 at 9:46 PM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    You will need to drain and refill oil and nitrogen if you change the resi fittings. Easy to do, for me anyway.
    Honestly, the wheeling you and most of us do, you don't need a resi. A 2.5 with internal ifp holds enough oil that you will not over heat it that the oil breaks down or the seals melt out.
    JDM and Deathbysnusnu[QUOTED] like this.
  15. Oct 19, 2016 at 11:39 PM
    Ice Horse
    Lauren
    Florida
    But...you can do sweet jumps bro! :D
    Someday I will hopefully get around to getting my rear end to match the front as far as ride quality lol.
    Deathbysnusnu likes this.
  16. Oct 20, 2016 at 3:53 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Thank you for that. I wondered if a resi might be overkill if you're not desert wheeling.
    CO MTN Steve likes this.
  17. Oct 20, 2016 at 3:54 AM
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
  18. Oct 20, 2016 at 3:58 AM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Jigsaw
  19. Oct 20, 2016 at 4:00 AM
    tacot0wn
    CO
    hows the new gig?
  20. Oct 20, 2016 at 5:38 AM
    Tacoma SS
    Denver
    Going great so far, glad I made the switch. This job came with a pretty decent pay bump too so I can't wait to start seeing paychecks :thumbsup:
