Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Nov 27, 2016 at 3:23 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Lift doesn't help clear tires except at ride hide. If you're clearanced right, you can run 35s at stock height.
    jubei and Blacktacoma23 like this.
  2. Nov 27, 2016 at 5:16 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    That's why there are so many setup that way.....
  3. Nov 27, 2016 at 5:31 PM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Andy he is right. Up travel is up travel regardless of lift.
  4. Nov 27, 2016 at 5:51 PM
    odomandr
    Andy
    Fort Collins, CO
    I understand that and I'm waiting for links to stock setups on 35 and above
  5. Nov 27, 2016 at 6:02 PM
    time2getdirty
    time2getdirty Well-Known Member
    David
    2011 Black Access Cab
    Give me a week and I will link you to my build thread.
    odomandr likes this.
  6. Nov 27, 2016 at 6:21 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    our boy needs some coverage
  7. Nov 27, 2016 at 6:23 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Yes. and he also needs to learn how/when to get rid of it.
  8. Nov 27, 2016 at 6:28 PM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    Just out of curiosity why did you chose to go to 35s on stock suspension? Do you plan to lift in the future or are you planning to stay stock height?
  9. Nov 27, 2016 at 6:35 PM
    Squeaky Penguin
    Brett
    Unlikely that someone would spend the time and money properly clearing 35s and not upgrade suspension. Usually suspension precedes larger tires as well. I could easily run my 295s on stock suspension because I've spent the tire to clear them throughout the entire range of travel and lock to lock.
    FWIW, best suspension performance comes from balancing up and down travel, which happens with less lift than most people are going for. 1.5" or so. Hence why I have less lift than most. Regardless when you compress your suspension, you'll inevitably end up at what would be stock ride height at some point. If you're not rubbing then, you won't rub on stock suspension.
    Limiting uptravel is another part of this equation that is another argument entirely. No point in bigger tires is you're loosing wheel travel IMO.
    TLDR: lift height does not mean more tire clearance unless you only ever drive to the mall.
    Stig, CharlieCafe and Deathbysnusnu like this.
  10. Nov 27, 2016 at 6:35 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    :censored::facepalm::frusty:
    Broncos
    Deathbysnusnu likes this.
  11. Nov 27, 2016 at 6:43 PM
    Gramps
    Gramps
    07 TRD DC 4x4
    Damnit so I am screwed! :D
  12. Nov 27, 2016 at 6:48 PM
    time2getdirty
    David
    I choose 35s on stock suspension because I needed to buy new tires and I just want to run 35s till the build begins and don't want to put much money into lifting it because it will all get torn out soon enough.
    I did 35s because I enjoy the benefits of a bigger tire; more flotation and better traction and ground clearance when aired way down.
    Short term plan is that I will most likely do 5100s to level the front out (rear is going to get the shackle flipped).
    As soon as the truck gets payed off I will be doing a 9" front and will probably run 37s or 40s.
    Plus these tiny tires look weird.
  13. Nov 27, 2016 at 6:50 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I had a girl tell me it was a reflection of my penis.
  14. Nov 27, 2016 at 6:52 PM
    PottMatter
    PottMatter Well-Known Member
    CoLoRfUl CoLoRaDo
    2012 Red Baja Taco
    What? dependable and low maintenance unlike most women?:bananadance:
    Deathbysnusnu[QUOTED] likes this.
  15. Nov 27, 2016 at 6:56 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Might as well throw gearing in there too.
  16. Nov 27, 2016 at 6:59 PM
    time2getdirty
    David
    I will rock with the stock gears till its new axle time. No reason to gear and lock these axles if I am to be building 9s soon.
    I have a 5 mile commute, shouldn't bug me too much.
  17. Nov 27, 2016 at 7:09 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I hear ya. I should of mention when I saw you wanted 37-40's, gearing would help. Or a tow pig and trailer. :D
  18. Nov 27, 2016 at 7:17 PM
    mountainmonkey
    Colorado
    Never enough
    I'm not sure I've ever seen a 2nd gen Tacoma with a 9" lift. I'm curious to see what that would look like. Especially with 40s!
    CO MTN Steve likes this.
  19. Nov 27, 2016 at 7:18 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    You know its windy outside when there are whitecaps in the toilet!
    CharlieCafe likes this.
  20. Nov 27, 2016 at 7:19 PM
    Stig
    Brandon
    Ta no mo
    I'm sure someone in TX has done it before. :anonymous:
    Heres 12"
