Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Dec 6, 2016 at 8:28 AM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    :rofl::pout: Missed you at Christmas caravan.
  2. Dec 6, 2016 at 8:29 AM
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
    bike
  3. Dec 6, 2016 at 8:31 AM
    2016spicytaco
    2016spicytaco Spicy Kitty
    Al
    Denver, Colorado
    Turd Gen for Life
    Okay I am self banning myself....going on a 24hr forum detox :frusty:
  4. Dec 6, 2016 at 8:31 AM
    Martyinco
    Martyinco Well-Known Member
    quitter
    CO MTN Steve and tacot0wn like this.
  5. Dec 6, 2016 at 8:31 AM
    Martyinco
    Huffy :thumbsup:
  6. Dec 6, 2016 at 8:33 AM
    tacot0wn
    CO
    wal-mart special
  7. Dec 6, 2016 at 8:36 AM
    Martyinco
    Spicy rolling down 191 through Moab 7c0d9134-0864-4f89-a85d-2390159a1c77_1.9341d79448f27a77d9630d230f7ddac5.jpg
    YamaDirtrider and PottMatter like this.
  8. Dec 6, 2016 at 8:41 AM
    tacot0wn
    CO
    with a cardboard sign on his back "EXPO OVERLAND OR BUST"
    BYJOSHCOOK and Martyinco[QUOTED] like this.
  9. Dec 6, 2016 at 8:41 AM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    I thought it was agreed upon that it was not a caravan.
  10. Dec 6, 2016 at 8:47 AM
    Stig
    Brandon
    Ta no mo
    Pm me when you want back in and I'll get you 50% off the unbanning fee.
    PottMatter and Martyinco like this.
  11. Dec 6, 2016 at 8:49 AM
    3378jakesr5
    jake
    littleton colorado
  12. Dec 6, 2016 at 9:04 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  13. Dec 6, 2016 at 9:11 AM
    CC33
    CC33 Well-Known Member
    Denver, CO
    1988 4Runner
    Ok, need more advice about my parking brake sticking... I brought it in to Groove last week and they took a look and tore apart the drum (mostly seems like driver rear wheel is not moving) but didn't see anything that could be causing it to freeze. I have only set it once since then (Friday night) but I forgot to go out and check until about noon on Saturday. By that time was much warmer outside so it wasn't very stuck and it freed up after I popped the clutch once. Last night I specifically didn't set it as I knew it was going to be cold today, but when I got to work I spaced out and pulled the brake. Now my truck is basically stuck in my parking space... I can get it to move by burning the clutch/ using 4lo/ engaging diff lock, but just barely and as soon as I get off the gas/ depress the clutch it stops like I just pulled the brake. The weirdest part to me is that I can drive almost entirely normally in reverse- wheel doesn't seem to be locked or anything- it also seems weird that it stuck as soon as I pulled it as opposed to freezing after sitting all night...
    Sorry for the novel, but is there something other than the parking brake I could be missing? Would it be normal for it to drive fine in reverse but not in first? (I know @BDN said it should be easier in reverse, but it seemed weird to me that there seems to be no resistance at all?) And anyone have any suggestions for freeing it up so I can get home? I hit the backing plate with a hammer but it didn't seem to do much good...
    As an aside, when I took it in last week they showed me that the outer layer of the cable sheath had a little nick in it, but it didn't look like it went thru the second layer to the actual cable so we mostly ruled out moisture getting into the cable and freezing there.
  14. Dec 6, 2016 at 9:34 AM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Where do you buy those at?
  15. Dec 6, 2016 at 9:37 AM
    steezemcqueen
    steezemcqueen 4Runner Abuser
    Dylan
    Crawlarado
    1997 4Runner Turbo and 2006 Tacoma
    Unicorn fart injection system
  16. Dec 6, 2016 at 9:44 AM
    Tacoma SS
    Denver
  17. Dec 6, 2016 at 9:48 AM
    steezemcqueen
    Dylan
    Crawlarado
    Depends on how much total lift you are going to end up with. The 2nd gens seem to be happy around 1.5 degrees of correction per inch of lift.
    Keep in mind that the shackle flip will give you some lift but also is going to correct the pinion angle slightly at the same time since its moving the rearmost mount of the leafs down.
    Tacoma SS[QUOTED] likes this.
  18. Dec 6, 2016 at 9:48 AM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Sounds exactly like a frozen cable to me. Try a hair dryer on the cables and see if they un-stick
  19. Dec 6, 2016 at 9:57 AM
    CC33
    Denver, CO
    1988 4Runner
    Ok thanks, I'll do that. So you would guess the problem is that moisture got into the cable and then froze? Is there a fix for that other than replacing it? Also, if it makes a difference, when I pulled the cable this morning the first 90% of the pull seemed normal, and then the last 10% was harder to pull/ sounded slightly "weird" (not very helpful I know...). Out of curiosity, how would it be frozen immediately after I put the brake on?
    Thanks for the reply, I really appreciate the help.
  20. Dec 6, 2016 at 10:01 AM
    thefatkid
    Brian
    Colorado
    2004 thingy
    Think about it this way. You are stronger than the return springs in the drums. You could pull through the added friction but the return springs can't. They might be frayed instead of frozen also. Did you lift your truck?
