Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Mar 31, 2017 at 7:21 AM
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Same complex. Just the smaller two bedroom unit.
  2. Mar 31, 2017 at 7:26 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Did you clean any exposed threads under the bed?
    You may be trying to force a bunch of dirt and rust back through the threads if not.
    CO MTN Steve likes this.
  3. Mar 31, 2017 at 8:05 AM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    No more roommate?
  4. Mar 31, 2017 at 8:42 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Not sure what you mean by "Cut out" but my preferred method is Drilling out and knocking in an extractor (Not sure of exact name, but see below- never saw bottom one before) bit and attach visescrips to remove or cut a flat head into top and screw driver it out.
  5. Mar 31, 2017 at 9:05 AM
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
    I meant cut out by taking an angle grinder to the top of the bolt and just making it go away, then hammering a punch in there to pop the bolt out.
    I might just weld a bar onto the top of the bolt and use that to pop it loose. It's really rusted/seized. I'll try this extractor
  6. Mar 31, 2017 at 9:22 AM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Since you mention really Rusted/ Seized the extractor might not be best choice unless you PB Blaster the heck out of it for a bit.
    KB Voodoo and CC33 like this.
  7. Mar 31, 2017 at 9:25 AM
    thefatkid
    Brian
    Colorado
    2004 thingy
    Isn't that a T55 not 40? I might give it a try if you are on the south end of town. My bed bolts are seized so I'm buying a t55 impact 1/2" socket
  8. Mar 31, 2017 at 9:26 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    Are you talking about the bed bolt or the bolt that holds the D-ring in the back? The bed bolt is T55 and usually silver. The D-Ring bolt has a short shoulder that allows the D-ring to spin freely. I do have an extra set of the D-ring mounting hardware (Toyota part #PT278-35054) that you can have.
  9. Mar 31, 2017 at 9:26 AM
    CC33
    CC33 Well-Known Member
    Denver, CO
    1988 4Runner
    I'm also always paranoid about breaking the extractor off in the bolt and then really being fucked.
  10. Mar 31, 2017 at 9:32 AM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    I have never seen that before, usually the soft metal of screw gives and Extractor pops out.
    3378jakesr5 likes this.
  11. Mar 31, 2017 at 9:33 AM
    tacot0wn
    CO
    Both are very seized, the T40 holding the D-ring is the one i snapped the tip off.
    The T55 wouldnt budge either.
    I'll gladly take you up on this and throw you some whiskey for you troubles :hattip:
    jubei likes this.
  12. Mar 31, 2017 at 9:36 AM
    CC33
    Denver, CO
    1988 4Runner
    Yeah, I've personally had good luck with them as well, I've just heard stories where guys snapped them and then been really screwed because the extractor metal is so hard. So now I just stop and spray more pb blaster if it feels like it's really not budging.
    CO MTN Steve[QUOTED] likes this.
  13. Mar 31, 2017 at 9:48 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    Like others have said, soak the bolts with PB Blaster, let them sit for a day, and soak them again. For better results, try to soak the threads under the bed.
    I'll be in Longmont this weekend, but I can go as far as Thornton to meet you for the replacement hardware if you need it. Just send me a PM if you haven't been able to get that bolt off by Saturday
  14. Mar 31, 2017 at 10:00 AM
    PottMatter
    PottMatter Well-Known Member
    CoLoRfUl CoLoRaDo
    2012 Red Baja Taco
    I've had success using this stuff on rusted items and the nice thing is you don't have to be careful with it :thumbsup:
    http://www.evapo-rust.com
    CO MTN Steve and tacot0wn like this.
  15. Mar 31, 2017 at 10:01 AM
    tacot0wn
    CO
    I unfortunately soaked the bolts(and threads) as suggested to no avail.
    I'm leaving at lunch today and heading to Crested Butte for the weekend - will be back Sunday evening. If you're not opposed to it, I can drive out your way after work one day next week and grab that hardware from you
  16. Mar 31, 2017 at 10:20 AM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    I have one if you want to barrow it
  17. Mar 31, 2017 at 10:21 AM
    3378jakesr5
    jake
    littleton colorado
    Ive broke three :anonymous:
    CC33 and Fistgar like this.
  18. Mar 31, 2017 at 10:48 AM
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Still do, but it's $100 cheaper and all I lose is the extra Storage room in the basement. My old one had two basement rooms and this just has one with a smaller main area.
  19. Mar 31, 2017 at 10:56 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    Sure, if you want to make the 2-hr drive out here :devil:
    Otherwise I can mail it to you in a flat rate box, or maybe someone in the area can TW express it.
  20. Mar 31, 2017 at 11:00 AM
    dgilbert2006
    dgilbert2006 Well-Known Member
    Dan
    Northglenn, Colorado
    2015 Tacoma 4x4 SR5 DCSB
    5100s, Dakars, D2S Retro, Level 8 MK6 285
    Got this at Fuzzy's. Thought is was appropriate to share.
