Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Apr 14, 2017 at 8:36 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Lmao. It's so funny whay people ask. Just paid $18500 for a 2012 DCSB 4x4 Tacoma sr5. Yes it has 50k more miles but damn.
    Stig likes this.
  2. Apr 14, 2017 at 8:44 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    I'm not a "her" and I don't need an aluminum anything.
    CO MTN Steve and Stig[QUOTED] like this.
  3. Apr 14, 2017 at 8:44 PM
    RockiesTaco
    RockiesTaco Well-Known Member
    Bart
    PHX
    2021 JLUR
    :stirthepot::anonymous:
    JayRolla likes this.
  4. Apr 14, 2017 at 8:55 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Skid removal didn't change anything unfortunately.
    Decided to play with tire pressure. It was a bit high! 38r/37f.
    Dropped it to 34r/32f with no change in ride
    Then decided to try the 4wd. I have read the threads and most say that jacked up bushing makes noise, I've never heard anything even trying to listen. And when this happens I'm usually in traffic or on a curvy road.
    It definitely seems to eliminate the vibes when in 4wd. Currently making laps up and down coal Creek off 93, flat, straight, and good condition road.
  5. Apr 14, 2017 at 9:12 PM
    Stig
    Brandon
    Ta no mo
    False positive. Did a few more laps and it's back.
    It's more "muffled" because of the lower tire pressure, but still as shitty of a ride as always. :pout:
  6. Apr 14, 2017 at 9:46 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Bushing makes vibrations.
    Never felt it in the wheel though.
    Didn't you say you're feeling yours in the wheel?
  7. Apr 14, 2017 at 9:54 PM
    Stig
    Brandon
    Ta no mo
    Oh yeah. Steering wheel shakes side to side... At anything over 50-55. Which is why I'm pretty certain it's something up front.
    I was thinking I'd be able to see if it was play in the steering rack by the tie rods moving in the video but they seem pretty solid.
    The biggest issue is with it being there since new. If it happened suddenly or over time due to wear... It would help narrow stuff down.
    About a year ago when I had the first alignment at big o in Glenwood, they didn't torque the LCA bolts down, so I could see that causing an issue since it took me a minute to realize it (hard to notice vibrations on top of existing vibrations).
  8. Apr 14, 2017 at 10:07 PM
    Stig
    Brandon
    Ta no mo
  9. Apr 14, 2017 at 10:43 PM
    Stig
    Brandon
    Ta no mo
    Are those complete axles?
    I'm thinking about swapping one at a time or both out tomorrow just to eliminate it as a possibility since nothing else worked tonight. I guess it could make sense that one or both were out of balance from the factory...
  10. Apr 15, 2017 at 6:10 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    Yeah cvj has rebuilt 1 pair already and the other pair are oem toyota but still need a rebuild. I'm a few weeks out still with my leg before I can do anything to my truck with them, if you wanna try them let me know
  11. Apr 15, 2017 at 6:38 AM
    odomandr
    Andy
    Fort Collins, CO
    I question the bushing on the steering column. Not the rack bushings
  12. Apr 15, 2017 at 6:39 AM
    odomandr
    Andy
    Fort Collins, CO
  13. Apr 15, 2017 at 6:50 AM
    Stig
    Brandon
    Ta no mo
    I found similar posts and checked that when it was new and first trying to diagnose the issue. It had/has slop in the steering assembly the whole time I've had it. This is "normal in a truck" according to Toyota.
    The feeling is identical to three GM vehicles I've owned that had over a combined 500k miles, thankfully it's an easy/cheap fix on those. Their issues come from wearing out after lots of mileage... Toyota duplicates it right off the assembly line. :rofl:
    But I'll check it again when I go down there.
  14. Apr 15, 2017 at 6:50 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Well that rules out that out. I thought maybe if you ran upwards of 40psi normally that could be your issue. My truck rides like a dense brick anything over 35psi.
    Stig[QUOTED] likes this.
  15. Apr 15, 2017 at 7:43 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Mine doesn't and has never had slop.
    There's the joint in the steering linkage, the rack, the mounting of the rack, and the tie rods.
    I didn't see any movement of the tie rods in the video so I'd be checking all that other stuff.
    Need a second person to rotate the wheel back and forth (just to the extent of the slop) while you look at everything.
  16. Apr 15, 2017 at 8:01 AM
    odomandr
    Andy
    Fort Collins, CO
    I had a gmc, at about 100k it got some play in the wheel. My Tacoma still doesn't at 110k
    Stig likes this.
  17. Apr 15, 2017 at 8:06 AM
    Stig
    Brandon
    Ta no mo
    Yeah, it's that same exact slop feeling that you felt is what the taco has had since i first got behind the wheel. On the Silverado, Tahoe, Escalade, that i fixed you just added some grease to the shaft once and it was good as new.
    Done with my first breakfast, gonna go to the garage before i want to make breakfast number two.
    jubei likes this.
  18. Apr 15, 2017 at 8:26 AM
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
  19. Apr 15, 2017 at 8:30 AM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Do you see mine around there?!?
    Coop68[QUOTED] likes this.
  20. Apr 15, 2017 at 8:39 AM
    lobsterbait
    lobsterbait The Wall
    Not Paul
    Parker CO
    Goose
    Just a couple things
    Yea. I took a leak on them yesterday to mark my territory
