Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. May 8, 2017 at 9:33 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    Yep, it was the only way to do it. I could bolt in the rear, and leave them loose, but then the front was off by 1/4" or so. After all the stuff I dealt with, the skid holes not lining up sucked.
  2. May 8, 2017 at 9:52 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Ice didn't last any longer then the Igloo cooler that also was holding beverages for everyone.
    I don't recall size but it will barely fit in passenger seat foot-well if you push the seat all the way back
  3. May 8, 2017 at 9:58 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    I did notice that when reading the Pelican description it says "does not retain ice longer." While the Yeti's and the Cabela's have a rubber seal which keeps everything colder. Does the RTIC you have close like an Igloo with no rubber seal?
  4. May 8, 2017 at 10:04 AM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Steel bar for a handle?
  5. May 8, 2017 at 10:55 AM
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    Come out, we're going early
  6. May 8, 2017 at 11:15 AM
    Firebird
    Firebird Notorious Member
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    MOVE DAY MOTHAH FUCKAHS! :bananadance::bananadance::bananadance:
    @lobsterbait when we meeting up, man!?
    lobsterbait and jubei like this.
  7. May 8, 2017 at 11:17 AM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Correct
  8. May 8, 2017 at 11:18 AM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    There is a rubber seal but no difference between igloo & my RTIC regarding beer temp.
  9. May 8, 2017 at 11:44 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    its all about the type of ice you use. If you use larger blocks it lasts longer than cubes which lasts longer than the amazing crushed stuff at restaurants. I have put a block in and put drinks in as they got removed and everything was ice cold for 5 days.
    Gramps likes this.
  10. May 8, 2017 at 11:55 AM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Again, I said I was disappointed and here are facts:
    • Beer and ice came from exact same source and simultaneous loaded into coolers.
    • Neither was opened until following evening and
    • results were pretty much the same (no thermometer was used to judge) all ice had melted.
    • It was assumed that the RTIC stored Beverages would be "cooler".
    Maybe that area of the Arkansas river/ Texas Creek is the Bermuda triangle of RTIC coolers but no advantage was found in this pure use test with zero scientific measurement.
    Thus, my disappointment comment was made.
  11. May 8, 2017 at 12:00 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    My RTIC 65 works great. Just received a rtic 20 and using a flashlight you can see the light shining through the side of the cooler. Big cooler you can't see the light but it also has thicker walls than the little cooler.
    BYJOSHCOOK and BigRedToy like this.
  12. May 8, 2017 at 12:07 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    The light coming through will causing heating issues, this is a good thing to check. I've never heard anyone mention this before.
  13. May 8, 2017 at 12:15 PM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
  14. May 8, 2017 at 12:29 PM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
  15. May 8, 2017 at 1:04 PM
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    image.jpg image.jpg Thoughts on this flippac hinge?
  16. May 8, 2017 at 1:32 PM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Looks like it hit something or something tried to tear it off.
    CO MTN Steve likes this.
  17. May 8, 2017 at 1:34 PM
    crolison
    Ar vah da, CO
    POS
    A
    A commen problem with them is the actual hinge breaking. So the owner made some out of steel to replace the aluminum ones.
  18. May 8, 2017 at 1:34 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Their torsion rod obviously failed. I've never owned a Flippac but I suspect deleting the torsion rod in lieu of plain pivots will make it slam open and closed.
    Sway-A-Way is making replacement torsion rods for them so it could probably be returned to original if you could find or remake the original hinge brackets.
    On the good side it doesn't look like the worst solution, seems well made and beefy enough in concept. Could do with with some better fiberglass work.
    PottMatter likes this.
  19. May 8, 2017 at 1:39 PM
    crolison
    Ar vah da, CO
    POS
    Yeah the owner uses a pole to open close. There are some threads on deleting he torsion bar before sway made the replaxement
  20. May 8, 2017 at 1:42 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I have owned several WilderNests and without the springs (they have a pair of springs inside that like to break) you have to really watch your fingers when closing it. It's not a show stopper but there is a reason for the lid springs on these campers.
