Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jun 11, 2017 at 9:55 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Bind weed. Most effective is to pull it out but you have to get the roots or it will grow back. Its a vine so you need to trace it back to the base to get the entire thing.
    You can spray it too but the grass will suffer a bit.
    Deathbysnusnu likes this.
  2. Jun 11, 2017 at 10:00 AM
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    Thats pretty cool! Saw it when i was going into home depot. Defantly a nice FJ.
  3. Jun 11, 2017 at 10:08 AM
    amalik
    amalik Well-Known Member
    Denver
    Thanks. Is it a sign that I don't water enough? This yard in the back gets hit with a lot of sun.
    I run my sprinklers only a few minutes every couple of days. I think I'll have to do the screwdriver test and get a strategy going.
  4. Jun 11, 2017 at 10:14 AM
    Gramps
    Gramps
    07 TRD DC 4x4
    Most likely lack of water if that is all you watering right now. If the grass is healthy it fills in all the space and keeps weeds to a minimum. Like this:
    Denver Water has a suggested watering guide on their website(they mail a flier too) Breaks it down by month, frequency, and sprinkler head type. I follow that minus a 2 minutes and it works for me.
  5. Jun 11, 2017 at 10:25 AM
    amalik
    Denver
    @Gramps, I'll check it out. Thanks. Nice yard, btw.
    Gramps likes this.
  6. Jun 11, 2017 at 10:58 AM
    acidchylde
    acidchylde Well-Known Member
    Fort Collins, CO
    07 Sport AC, black, still pretty much stock
    As already stated, that's bind/vine weed. It is one of the absolute hardest to get rid of. You can try pulling it, but it's a rhizome based root. That means underground it looks about like it does above ground - long and spread out, like noodles that can go two feet deep or more. It's also one of the ones that breaks off really easy at the surface, and the roots can just keep coming back for ages. I've dug down a foot before and taken every little bit I could find out, and it's still come back from even deeper than that. It's largely impervious to pesticides, which can kill the leaves but are pretty ineffective against the roots. Some places (CSU extension office be the first place to check) have mites you can release that will attack it. The best thing you can do is try to keep it pulled on the surface. Deny it leaves long enough and the roots will eventually die, but it's not a quick process, especially in a decent lawn which yours looks to be. Your mowing can also help. Keep the deck set relatively high and mow every week, taking no more than 1/3 off the top. The taller grass helps shade out the weeds as well as the ground, improving water retention.
    As far as watering, 'a few minutes every couple of days' is kind of a shot in the dark, as is a screwdriver test. What you really need is an irrigation system audit. Many municipalities will do those for free, but you can also do them yourself. It involves getting some little measuring or uniform sized cups, spreading them around, and then running the system for a set time. From that you can calculate how much water the system puts down, and then set your time accordingly. You generally want to water longer less often to encourage root growth, rather than every day for a short time. And by longer, you still want to break it up to give it time to soak in instead of saturating the surface and then running off and doing nothing - to if 20 minutes total, then 10 on, 10 off, 10 on again. Controllers vary, but you can usually create a cycle of shorts and then have it repeat x times. If you're actually in Denver Water, you're under watering restrictions, which means you can only water on certain days and between certain times - which can help you set your schedule, and it's usually based on best times to water anyway. I don't know that they do system audits though. You can find more info at http://www.denverwater.org/Conservation/WaterUseRulesRegulations/SummerWateringRules/ including about for how long to water different things (grass, shrubs, trees, etc.). As gramps said, it's a good starting point, but you do have to adjust for the local conditions and the type of grass. He's got a lot of mature shade trees around there and wouldn't need to water as much as you might with a southern exposure, no shade lawn.
  7. Jun 11, 2017 at 11:36 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Damn dude you're always such a wealth of information:thumbsup::D
    acidchylde[QUOTED] likes this.
  8. Jun 11, 2017 at 11:37 AM
    Madjik_Man
    Colorado Front Range
    Bind weed
    That and cockroaches will be the only things that survive a nuclear fallout.
    I built a shed in November of yesteryear.
    Come the next spring there was bind weed climbing up an interior 2x4. Alive. In zero sunlight.
  9. Jun 11, 2017 at 12:33 PM
    acidchylde
    Fort Collins, CO
    I have my areas of expertise. :D Former landscape architect, and as a renter well-versed in walking the fine line of how little water can I get away with because I'm cheap vs ignorant property owners who think their Kentucky bluegrass lawn should be full and lush in August, in this climate, with southern exposure and no shade.
  10. Jun 11, 2017 at 12:59 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    couple hours of wheeling and it's like it was never buffed and waxed. :rofl:
  11. Jun 11, 2017 at 1:02 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Met up with the @odomandr 's this morning and ran Greer Road.
    This is the only pic I took. Had a great time, we ran the entire network of roads.
  12. Jun 11, 2017 at 2:40 PM
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    Had a nice cool weekend in the Phantom creek area
    uurx, BYJOSHCOOK, jubei and 4 others like this.
  13. Jun 11, 2017 at 4:47 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  14. Jun 11, 2017 at 4:55 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Well that's a change from all the normal beers
  15. Jun 11, 2017 at 4:57 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Bloody Sunday. :thumbsup:
    YamaDirtrider[QUOTED] likes this.
  16. Jun 11, 2017 at 5:04 PM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    There's goes the U2 ear worm...
  17. Jun 11, 2017 at 5:32 PM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Catfish on the rink at 4 min in.
    Let's go Preds. At least lose away.
    lobsterbait likes this.
  18. Jun 11, 2017 at 5:37 PM
    Martyinco
    Martyinco Well-Known Member
  19. Jun 11, 2017 at 6:25 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  20. Jun 11, 2017 at 7:23 PM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Reh5108 likes this.
