Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Sep 19, 2017 at 12:18 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I have about 12" travel w shackle flip and relocated top and bottom mounts, 14" shocks
  2. Sep 19, 2017 at 12:23 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I do
    Adventurous[QUOTED] likes this.
  3. Sep 19, 2017 at 12:24 PM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Really only 12??? I would have thought you would have been doing better then that.
    I was measuring about 13.5" of travel with the 12" shocks at the end of the tire to fender
    Then there is the front...
  4. Sep 19, 2017 at 12:31 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Yea might be moor now that the aal is broken in
  5. Sep 19, 2017 at 12:36 PM
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Well I have no idea where you'd go then. A word of advice, I've never heard of anyone going NG after and NOT hating it. At least in colorado.
  6. Sep 19, 2017 at 12:37 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Anybody interested in taco Tuesday tonight?
  7. Sep 19, 2017 at 12:38 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Did you guys actually cycle your suspension, or how are you coming up with actual travel numbers based on these poser shots? :D
    Oh, and your shackle flips are only moving the mounting point of the leafs and don't change travel numbers. :stirthepot:
  8. Sep 19, 2017 at 12:39 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    :rolleyes::bored:
    Deathbysnusnu likes this.
  9. Sep 19, 2017 at 12:40 PM
    3378jakesr5
    jake
    littleton colorado
    But longer shackles do, and how dont they? Im getting more arc travel out of my shackels then a factory setup soooo
  10. Sep 19, 2017 at 12:44 PM
    Squeaky Penguin
    Brett
    Still no. Again, longer shackles are only changing the mounting point. All you're doing is changing the range of motion of the leafs further away from the frame. This assumes you have them bumped correctly as well.
    Length of leafs determines travel, and the stock shackles provide enough range of motion for stock length springs.
    tacot0wn, Gramps, Adventurous and 2 others like this.
  11. Sep 19, 2017 at 12:47 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    :pccoffee:
  12. Sep 19, 2017 at 12:47 PM
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    3378jakesr5[QUOTED] likes this.
  13. Sep 19, 2017 at 12:50 PM
    Giffmann
    Giffmann Well-Known Member
    Giff
    Colorado Springs
    2007 Tacoma DCSB
  14. Sep 19, 2017 at 12:52 PM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    I will have both after this fishing trip
    3378jakesr5 and Coop68 like this.
  15. Sep 19, 2017 at 12:54 PM
    Coop68
    Coop
    Erie/Dacono, CO
    you where either lucky or unlucky when my box showed up that one day. I like it a lot super simple always have my tools, I like the new pack too!
    CO MTN Steve[QUOTED] likes this.
  16. Sep 19, 2017 at 12:56 PM
    3378jakesr5
    jake
    littleton colorado
    I have to disagree, with a more centered location of frame side shackle mounting and longer shackles you will still maintain the same compression of the spring but you will be able to arch your spings more on the droop, yes longer springs will gain more travel but thats because of length of lever arm... no shit it will work better.
    The factory shackel gives you about 30 degrees of travle rear and ~45 degrees forward. Flip them and you can go a full 90 degrees rear under compression and just below tangent of the spring at the springs arch..
    Why do the long travle trucks have 9" + long shackels on the back? If their 63 inch spring pack and full arch under the axle are doing all the work.. the shackles are there to provide the horizontal travle for the springs to move vertically
    Deathbysnusnu and Sub-Zero like this.
  17. Sep 19, 2017 at 12:57 PM
    3378jakesr5
    jake
    littleton colorado
    You need 5000$ of an initial buy in to become a dealer for them :burp:
  18. Sep 19, 2017 at 12:58 PM
    Giffmann
    Giff
    Colorado Springs
    2007 Tacoma DCSB
    OUCH! When John owned Eagle is was like $500
    well, question asked. we'll see
  19. Sep 19, 2017 at 12:59 PM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Someone had posted it prior to that, Just seeing the actually quality at your place sold me on it.
    Coop68[QUOTED] likes this.
  20. Sep 19, 2017 at 1:01 PM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Run a group buy, Colorado alone might get you $5K
    Martyinco and 3378jakesr5 like this.
