Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Dec 18, 2017 at 6:52 PM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Maybe they do and those that should not wear them simply stretch them. :eek:
    Deathbysnusnu, CharlieCafe and Stig like this.
  2. Dec 18, 2017 at 7:03 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Thats why I like them so much.
    No matter how much I eat, they still fit perfect!
  3. Dec 18, 2017 at 7:06 PM
    Gramps
    Gramps
    07 TRD DC 4x4
  4. Dec 18, 2017 at 7:21 PM
    Impulse05Taco
    Impulse05Taco Well-Known Member
    Colorado
    05 Tacoma V6 TRD Offroad
    The mounting surface is already bent, according to the shop I just got it back from (had a lady turn left in front of me less than half a car length away) the frame is in good shape. So adding the plate will give that area more strength and assure it is square. The bumper I have will not allow the use of brackets that tie back to the frame. Just trying to give myself peace of mind. The bumper also needs to be shimmed to give enough clearance. Seems like solid plate beats stacking washers. Also removed all that foam :thumbsup:
  5. Dec 18, 2017 at 7:38 PM
    Gramps
    Gramps
    07 TRD DC 4x4
    Ok. Now I understand more of your story. What bumper does not allow you to use ties back plates? Sounds like a design flaw in the bumper itself. Those plates help to keep the bumper from bending down upon a hit or while winching. If you are adding the plate to the ends you might consider plating the front of the Frame as well if you cannot use bolt on plates.
  6. Dec 18, 2017 at 7:43 PM
    Impulse05Taco
    Colorado
    The money to replace the stock bumper covered the price of the infamous Ebay bumper. The gusset blocks the edge the brackets would wrap around. Plating the frame isn’t a bad idea, but then I have to buy a Dana 60 lol
    lobsterbait likes this.
  7. Dec 18, 2017 at 7:51 PM
    Gramps
    Gramps
    07 TRD DC 4x4
    Interesting. Never heard of that bumper so I will be curious to see it when you get it installed. If I were you and adding the plate to the front mounts, why not add some plate to the frame as far back as you can without removing more stuff? That should suffice to the side plate mounts.
    Impulse05Taco[QUOTED] likes this.
  8. Dec 18, 2017 at 8:27 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I'd either figure out a way to fabricate a frame tie- in or don't ever winch from it. You'll just pull it off.
  9. Dec 19, 2017 at 5:16 AM
    Martyinco
    Martyinco Well-Known Member
    Sounds like a thermostat to me, that would also be the least expensive piece in the puzzle that could be bad.
  10. Dec 19, 2017 at 6:19 AM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Good morning steaks
  11. Dec 19, 2017 at 6:37 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Man I need a restock for the freezer. Did you bag one? :D
    Stig[QUOTED] likes this.
  12. Dec 19, 2017 at 8:07 AM
    Stig
    Brandon
    Ta no mo
    Nope. :angrygirl:
  13. Dec 19, 2017 at 8:07 AM
    r2oh
    r2oh Well-Known Member
    Denver Colorado
    2010 white tacoma trd sport
    Fox 2.5 factory series dsc coil over Fox 2.0 dsc Total chaos uca Total chaos lower control arms Ome dakar Toytec extended break lines Scs stealth 6 gunmetal grey wheels bfgoodrich a/t ko2 tires 285/70/17 Quick stop drilled & slotted rotors Trd cold air intake (1st gen) Trd exhaust Optima yellow top battery Rigid 40" led bar and 4 pods & 20" Retrofit masters custom headlights Rci front,transmission,transfer case skid plates Pilfreybuilt front bumper single hoop Smittybuilt 9000xrc comp winch Factor 55 fairlead InSain fabrication cmc and sliders Total chaos weld on cam tab guests U bolt flip kit Prinsu roof rack Cvj axels Jersey hubs wheel bearings Ecg needle bearing Cvj rack and pinon
    Hilux and tacos left and right
    CO MTN Steve likes this.
  14. Dec 19, 2017 at 8:12 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Where you at?
  15. Dec 19, 2017 at 8:18 AM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    Brought home a little project to work on this winter :cool:
    lobsterbait and SilverGhost like this.
  16. Dec 19, 2017 at 8:19 AM
    r2oh
    Denver Colorado
    Guadalajara jalisco mx lot's of 2wd tho
    CO MTN Steve[QUOTED] likes this.
  17. Dec 19, 2017 at 8:20 AM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Enjoy! We are freezing up here this week.
  18. Dec 19, 2017 at 8:24 AM
    Iamraiderpower
    Damn! Anyone bag one this year in this group?
    3378jakesr5 likes this.
  19. Dec 19, 2017 at 8:33 AM
    Martyinco
  20. Dec 19, 2017 at 8:47 AM
    Impulse05Taco
    Colorado
    Seems like it’s always too warm during third rifle, gonna have to stop hunting winter range.
