Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Dec 20, 2017 at 5:09 AM
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Was there better and worse years of the early 2nd gen tundra? Say 07-10 if anybody has some knowledge of them @thefatkid
    Stig likes this.
  2. Dec 20, 2017 at 5:23 AM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    :spy:
  3. Dec 20, 2017 at 5:34 AM
    Stig
    Brandon
    Ta no mo
    CO MTN Steve likes this.
  4. Dec 20, 2017 at 6:37 AM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Yup, well deer atleast :D
  5. Dec 20, 2017 at 6:40 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Anyone good at troubleshooting brake lights on a 1st gen.
    I’ve had this problem for a while but it’s time to get it fixed.
    So when I turn on the head lights my driver side brake light comes on but my passenger side and one over the cab doesn’t.
    When I press the brake the passenger and cab one comes on but the driver light goes off. o_O
    I already replaced the bulbs.
  6. Dec 20, 2017 at 6:40 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Local grocery store has dry Ice, and I have an empty freezer. How much? :D
    3378jakesr5[QUOTED] likes this.
  7. Dec 20, 2017 at 6:52 AM
    3378jakesr5
    jake
    littleton colorado
    Sorry already turned into all the bad things like steaks, roasts, jerky and summer sausage :(
  8. Dec 20, 2017 at 6:57 AM
    Iamraiderpower
    you act like that cant be shipped!
  9. Dec 20, 2017 at 7:00 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    You know they will need a Conastoga wagon with multiple Oxen teams to get this too his place? Or just throw it off in a field and he will find it come spring :D
  10. Dec 20, 2017 at 7:01 AM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    FYP
    CharlieCafe[QUOTED] likes this.
  11. Dec 20, 2017 at 7:12 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    check the ground connections. Very common problem with anything bearing a chevy/gmc label, or any vehicle prone to excessive rust for that matter...
    sparseowl117 likes this.
  12. Dec 20, 2017 at 7:16 AM
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
  13. Dec 20, 2017 at 7:20 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    You know me I’m clueless with wiring . So when you say check grounds I’m assuming anywhere I have a ground wire touching the for a ground to check and make sure I have clean contact. I’ll just need to trace my grounds because I don’t know where they are all at.
    Deathbysnusnu[QUOTED] likes this.
  14. Dec 20, 2017 at 7:24 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    start with battery ground to body, make sure its clean and the wire looks good.
    then check/clean the body to frame connection, and the engine to frame connection, which is generally on the passenger side on the rear of the motor.
    After that, pull the tail light housings, the grounds are direct to bulb on these trucks, just pull the bulbs and make sure the contacts are clean.
  15. Dec 20, 2017 at 7:24 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    The light over the cab is only a brake light and doesn't turn on with the headlights, so it sounds like that one's working properly.
    SilverGhost[QUOTED] likes this.
  16. Dec 20, 2017 at 7:27 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Oh @Star-Lord Where I did the tie in to move the battery to the rear. The ground that was there isn’t there. I also moved it to the back of the truck.
    Should I add a ground wire at the junction box to where the origianal ground was? Or is that not needed?
  17. Dec 20, 2017 at 7:30 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    prolly wouldn't hurt but it sounds like the problem may be at the tail light housing itself.
    Past experience has shown that dirty, rusty grounds , either at the connection or internally in the wire can cause weird electrical issues. Could be a short in the wiring too. Not one that causes a seat fire but one that causes lights to turn on.
  18. Dec 20, 2017 at 7:38 AM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    What everyone else said. And if all that checks out, try the stalk itself. My father in law had a similar issue in his car (it was some domestic sedan, I don't remember), but we took apart his turn turn signal stalk and all the contacts in there were gummed up and the copper was tarnished. We cleaned it up and it worked after that.
  19. Dec 20, 2017 at 7:45 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Cool. Will do.
    Didn’t know that. Thanks
    Yeah I was rear ended and had to splice my wires back together in both sides of the tail lights. I used the light blue waterproof heat shrink connectors. Maybe one of the wires got tugged on. I’ll start with the grounds. To check the wires is there a way to test from where the harness plugs into the tail light and main harness connection that’s under the seat? How would I do that?
  20. Dec 20, 2017 at 7:47 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Start here. :)
    I bet one of those has come loose or shorted out.
