Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jan 18, 2018 at 6:17 AM
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    Working on a proposal this morning that’s involves the rental of pontoon boats..... 19x 3 hour cruise....
    Who wants to be my Gilligan?
    Stig and Martyinco like this.
  2. Jan 18, 2018 at 6:26 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    You're gonna want to take a nice long lunch somewhere...Denver at 5 ain't pretty.
    I'd shoot for 7ish.
    Stig and CO MTN Steve like this.
  3. Jan 18, 2018 at 6:48 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Hands down go for your Bathroom heat go with Electrical radiant heat in floor.
    Coop68 likes this.
  4. Jan 18, 2018 at 6:55 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  5. Jan 18, 2018 at 6:57 AM
    Martyinco
    Martyinco Well-Known Member
    So popular right now, I'd say 85% of my bathroom bids want heated floors.
    CO MTN Steve[QUOTED] likes this.
  6. Jan 18, 2018 at 7:13 AM
    Madjik_Man
    Colorado Front Range
    Definitely intend to do that. My friend has it in their bathroom and it's soooo nice.
    I'm more concerned with cooling it during hot days.
  7. Jan 18, 2018 at 7:46 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I went and had the truck checked yesterday at auto zone. Nothing but the old codes. The throttle position sensor is all one unit with these throttle bodies from what I understood from Brian. I’ll reset the ECU and change the plugs then clean the MAF this weekend. Truck ran fine this morning tho. Hopefully it was just a glitch..... :D
    oh good I was hoping for a pic to see where your stuck. Glad you got it
    CO MTN Steve likes this.
  8. Jan 18, 2018 at 7:52 AM
    acidchylde
    acidchylde Well-Known Member
    Fort Collins, CO
    07 Sport AC, black, still pretty much stock
    My former roommates installed the miniduct things on the upper floor about two weeks before I moved out (the two events are not related) to replace a central swamp cooler. They're functional, and probably pretty efficient, I'll grant you that. The neighborhood doesn't have gas, so everything is electric, hence all baseboard heating. The miniduct system lets you do the same thing baseboard does - keep the temp control in the room you want vs the entire house. Unless of course you have any kind of open floor plan. But I didn't like them and probably would never use them given a real choice. For starters, there's a large (twoish by threeish foot by sixish inches) unit up high on the wall in every room, which granted isn't much different than a window or in-wall unit. Then there's the noise. The units themselves are relatively quiet in terms of blowing air, but the problem is that the compressor or whatever on the outside of the house is mounted in relatively close proximity to the wall units on the inside. Which means up on the wall instead of down on the ground. And that outside unit runs when any of the inside units connected to it do, sometimes more. The result was this low frequency hum/vibration that sounded like some kind of industrial unit running. Now, part of that was the exterior unit happened to be mounted outside my room, and it wasn't as noticeable in others (so don't put it on your bedroom wall).
    All in all I wasn't terribly impressed. He always complained with central air about the noise of the central unit kicking on and then air blowing through ducts. The swamp cooler was far worse than that, and the miniduct things are pretty similar to your typical hotel room hvac unit - definitely not as quiet or unobtrusive as central. They solve a problem and they do it efficiently, but imho they're not ideal.
  9. Jan 18, 2018 at 8:25 AM
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    Blue Valley Energy replaced our furnace, and added A/C (replacing a swamp cooler) to our house last spring. Very tidy installation, no issues with either since the install, and good service. They originally quoted us for a 4" filter setup and that info didn't make it from the estimator to the installers. The didn't have one in stock on install day, and sent over a foreman to install it a few days later.
    Make sure you check with Xcel energy for possible rebates as well. Between the upgraded furnace and new A/C, we got around $1100 back in rebates. We could have gotten even more, but we weren't replacing an old A/C, so missed out on that option.
  10. Jan 18, 2018 at 9:15 AM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    Here's where I was 'stuck'. I got the screws out with the little screwdriver ratchet. And then once I got the screws out I realied I was being dumb and that little brace only attached the dash to itself. 20180117_164320.jpg 20180117_164613.jpg 20180117_164429.jpg
    SilverGhost[QUOTED] likes this.
  11. Jan 18, 2018 at 10:44 AM
    Madjik_Man
    Those are similar complaints to what I've heard as well. If I go ahead with this addition I might also consider just adding another zone/furnace/AC compressor for the new space and simple duct work running off of it.
  12. Jan 18, 2018 at 11:13 AM
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
  13. Jan 18, 2018 at 11:13 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    small potbelly stove and an open window will regulate temps fairly well.
    Martyinco likes this.
  14. Jan 18, 2018 at 11:17 AM
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    24 Tacoma TRD Offroad Premium 4x4
    Plethora of "useless" shit
  15. Jan 18, 2018 at 11:18 AM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    You're doing a pole barn?
  16. Jan 18, 2018 at 11:20 AM
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
  17. Jan 18, 2018 at 11:21 AM
    thefatkid
    Brian
    Colorado
    2004 thingy
    26992073_1219128848220365_56472491343948_894d5e141b5e2d542d94f9947cc28849971f5d39.jpg
  18. Jan 18, 2018 at 11:22 AM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Seen people build there own and use a 110v winch from harbor freight
    It’s a hard shell why not just leave it on full time?
    Coop68[QUOTED] likes this.
  19. Jan 18, 2018 at 11:23 AM
    Martyinco
    I'm a make my own kinda guy
    Stig and Coop68[QUOTED] like this.
  20. Jan 18, 2018 at 11:24 AM
    Nazupag524
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Yessir
