Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Feb 22, 2018 at 7:44 AM
    COSD
    COSD Well-Known Member
    Denver Metro
    2017 MGM DCSB OR
    @thefatkid sorry but I didn't see a reply so I didn't know if you missed this or not. Thanks in advance.
  2. Feb 22, 2018 at 7:46 AM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    No where specific for this question so I'll ask you genius'.
    When towing a vehicle on a flatbed trailer where should you attach the straps on the vehicle on the trailer?
    I've done this before and research showed to strap the axles using axle straps.
    I'm asking because I saw two tow rigs hauling large, lifted trucks putting the straps through the openings on the rims. They were also using microfiber washcloths to protect the high dollar rims from the straps.
    They appeared to be 'professional' haulers as they had DOT info on their doors of their 3500 tow rigs. The towed rigs were also 2500s. One with a huge lift and low profile tires. The other looked like it was in the process of becoming the other. It had a mild lift and similar low profile tires.
    I guess I just need to know if this is a proper way to secure a truck to a trailer. Or if I'm just being "judgey".
  3. Feb 22, 2018 at 8:06 AM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    I'd say none of them are ok, just because I'm no expert. I've seen enough go south that they have no appeal to me
    COSD[QUOTED] likes this.
  4. Feb 22, 2018 at 8:18 AM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Frozen junk build up on top of sliders that is contacting the body when you hit bumps. :thumbsup:
    Frankenstuff likes this.
  5. Feb 22, 2018 at 8:22 AM
    Stig
    Brandon
    Ta no mo
    I don't see an issue with it as long as they are properly tightened down. I think they have tire straps meant for just that purpose. And lowered vehicles you likely can't access an axle, especially when it's independent suspension.
  6. Feb 22, 2018 at 8:22 AM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    This is definitely a possibility cause my sliders definitely have significant ice buildup on them. Something tells me you ran into this before.... Thanks! I will try scraping that off and see if the noise goes away.
    Stig[QUOTED] likes this.
  7. Feb 22, 2018 at 8:24 AM
    Stig
    Brandon
    Ta no mo
    Yup, first few times i was worried. I also had a rock wedge itself between the pinch weld and slider when there wasn't frozen crap to blame the noise on. Took me a bit of poking around to finally see the little rock and pry it out. But the ice knock culprit is usually at the front of the slider in my experience.
  8. Feb 22, 2018 at 9:56 AM
    Jefes Taco
    Denver, CO
    The ones I'm aware of go around the actual tire, not through a hole in the rim. I don't recall that style. But then again, the rims I was using wouldn't really allow for through the rim, so it's possible I just overlooked them as "not for my use" and I'm not recalling that style. Still seems awkward and possibly causing damage to the rim. But that's why I'm asking.
  9. Feb 22, 2018 at 10:15 AM
    Jefes Taco
    Denver, CO
    Did some Googling and it appears to be perfectly acceptable. Even advised in certain situations.
  10. Feb 22, 2018 at 10:17 AM
    Martyinco
    Martyinco Well-Known Member
    Just set the e-brake, call it a day
  11. Feb 22, 2018 at 10:21 AM
    Stig
    Brandon
    Ta no mo
    Yeah I've seen autocross vehicles do it before, including race setup new Porsche GT3s.
  12. Feb 22, 2018 at 10:42 AM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Anybody have any experience with these things? Truck won’t pass emissions so I’m looking for a fast cheap fix until I get around to finding out what I’m gonna do for cats
  13. Feb 22, 2018 at 10:50 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    why cant you put the back cats on and pass emissions......
  14. Feb 22, 2018 at 11:14 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Mine does that too
    Last year I sprayed out my wheel wells of all the ice and it stopped
    And could be what Brandon said,
  15. Feb 22, 2018 at 11:22 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    One beautiful tasty thing about still living in Texas...yuuuuuum
  16. Feb 22, 2018 at 11:24 AM
    Stig
    Brandon
    Ta no mo
    It's like a Texas in-n-out correct?
    Edit: is there one in DFW? I'll have a lunch time layover there.
  17. Feb 22, 2018 at 11:25 AM
    Tacoma SS
    Denver
    I still have all my cats, one or two of them is just bad and is throwing up a check engine light
  18. Feb 22, 2018 at 11:25 AM
    Martyinco
    So much want :(
  19. Feb 22, 2018 at 11:31 AM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    Cool, I've had that, Blake's Lottaburger, In-n-out, Crave, Habit Burger, probably a ton I can't think of right now and they were all 'pretty good'. Idk what the big fuss is about them, but since they are pretty good, I'll usually have one if I find myself in the area.
  20. Feb 22, 2018 at 11:35 AM
    Stig
    Brandon
    Ta no mo
    Last time I was influenced into having some in-n-out... It wasn't until after i ate it that i was informed that it'll be in and right out. :facepalm:
    CO MTN Steve likes this.
