Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Apr 4, 2018 at 7:09 AM
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Yeah that was definitely a big reason I stopped riding here. Once I get away from all the people I'll feel a little better about riding on the street again.
  2. Apr 4, 2018 at 7:40 AM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Back on winching shut off. Looking at this switch it could possibly be right on the threshold for operation. I might need a friend to go up and help me with some current draw tests. If it is only right at threshold for operation within rated limits a higher amperage switch might be better. It is ok for Toyota starter operation because they only run in the 200 amp range, peak in the 300ish area, not sure about the winch motors as they are larger and load different.
    https://www.amazon.com/Blue-Sea-Sys...sX&pd_rd_wg=8Bmqg&refRID=TME7PXFGF98A8F77MPEQ
  3. Apr 4, 2018 at 7:44 AM
    thefatkid
    Brian
    Colorado
    2004 thingy
    Warn states at full pull my winch draws 500 amps
  4. Apr 4, 2018 at 7:56 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Need this for my truck!
  5. Apr 4, 2018 at 7:56 AM
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    24 Tacoma TRD Offroad Premium 4x4
    Plethora of "useless" shit
    If I recall the one I posted is rated at 600A intermittent for up to 5 mins according to the Bluesea specs, which should be fine for winching since you are typically on/off and never on for 5 mins continuous.
    Edit: just verified, it is 600A intermittent and not 650A
  6. Apr 4, 2018 at 8:34 AM
    RigginsTaco
    RigginsTaco Well-Known Member
    Andreas
    Boring taco with mods
    Stuff...
    Yeah you do but in gray!
    fatfurious2[QUOTED] likes this.
  7. Apr 4, 2018 at 8:35 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Dam, you're ready to come out and Mall Crawl with us for sure with those poser shots! :D
  8. Apr 4, 2018 at 8:36 AM
    RigginsTaco
    Andreas
    Stuff...
    I have a warn 10k straight lined to the battery and have yet to have a problem..
  9. Apr 4, 2018 at 8:36 AM
    RigginsTaco
    Andreas
    Stuff...
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    CO MTN Steve[QUOTED] likes this.
  10. Apr 4, 2018 at 8:39 AM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    It's a very rare problem, but having first hand experience with a run away Winch, it's not fun trying to figure out how to stop the thing before it pulls something through your rig. Just watch the youtube video's of everyone frantically beating on solenoid with whatever they can trying to disable it. But 99.9% of us will hopefully never experience this issue
    Easy solution, few ever think of under the pressure, is pulling the positive off the Battery.
  11. Apr 4, 2018 at 8:41 AM
    RigginsTaco
    Andreas
    Stuff...
    Oh wow never thought that was an issue.... I thought everyone concern was constant power intake.
    That's crazy tho! Never knew there was such thing as a runnaway winch. I have my negative wire connected right beside my winch so if it does happen I can just yank that
  12. Apr 4, 2018 at 8:42 AM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    It might not be getting fuel. How's the tank? I had that issue on an older bike, and it was bits of rust clogging up the fuel lines. I took the tank out, filled it up with old bolts and apple cider vinegar, left it for a few days shaking it around whenever I remembered to and it cleaned it up pretty good.
  13. Apr 4, 2018 at 8:46 AM
    MagicMexican
    Alejandro
    Pueblo, Colorado
    Aftermarket Wheels
    A straight line is no good, you need a fuse or timer something for short circuit protection... I don't remember if it was here or a Ranger forum where a guy did that and his winch caused a fire. He just came outside and the front end of his truck had burnt up.
    RigginsTaco[QUOTED] likes this.
  14. Apr 4, 2018 at 8:52 AM
    RigginsTaco
    Andreas
    Stuff...
    Well has yet to happen to me:fingerscrossed: but this is my third winch all warn. So idk what cause his to catch fire but I know I'm not the only one that ran a winch straight with no problems.
    This is the first time me hearing negative things on wiring winches straight to the battery. Even in the warn manual it doesn't say you need fuse/circuit breaker or what not. So maybe it's smittybilt or superwinches that causes these problems. Idk
  15. Apr 4, 2018 at 9:00 AM
    Kappes03
    Kappes03 [OP] Legend of the UG
    Colorado
    2014 Tundra CM
    That's actually what I first thought, but he said the tank was sent out to get cleaned up. I was surprised though, whoever he had rebuild it there in PWest didn't replace any lines, they are in rough shape
  16. Apr 4, 2018 at 9:19 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I started looking at the ones we use on our heavy equipment. But I haven’t checked what they can handle. These are 24volt systems.
  17. Apr 4, 2018 at 9:22 AM
    P51DeP
    P51DeP Well-Known Member
    Christopher
    San Jose, California
    2008 Single Cab Tacoma 4x4 Super White
    Fog Light Install, BFGK02's, Bilstein 5100's, 4x4 Armor Rear Bumper, Front and Back Light Housings(Euro Black) Sound Deadening Cabin, Tint all around.
    Alright folks. I want to pull the trigger on a OBA set up. Nothing crazy but not bare minimum. Tires are not huge so I'm wondering if a viair medium duty system would be good. What did you guys go with?
    YamaDirtrider likes this.
  18. Apr 4, 2018 at 9:25 AM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Well... there is a group buy on arb single and twins... lol but its on the higher end.
    303tacoma likes this.
  19. Apr 4, 2018 at 9:27 AM
    MagicMexican
    Alejandro
    Pueblo, Colorado
    Aftermarket Wheels
    Weird... I don't know what shops are out in pwest. In Pueblo I used to go to Tote-gote and I know for a fact he has fuel lines, and the cone filters, I've bought a few there, they're on a big spool. But it has been awhile since I was into bikes.
  20. Apr 4, 2018 at 9:27 AM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    In the past when people have asked the two main replies they get are to go all out with an ARB twin or to just use one of the super cheap MV50s. There arent too many people out there using something in between although I have heard of a few who use VIAIR.
    RigginsTaco likes this.
