Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. May 27, 2018 at 4:14 PM
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    All the family have gone back to their respective states!!!!!! :eek::amen:
  2. May 27, 2018 at 5:00 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    w.adventures[QUOTED] likes this.
  3. May 27, 2018 at 5:04 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Giving them a call tomorrow morning. If they are open I will head down to check it out.
    Stig[QUOTED] likes this.
  4. May 27, 2018 at 5:21 PM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Have about $2-3k in savings for when the injectors and pumps go out. I think that is past the perpetual overheating while towing model. Not sure though.
    Stig, Wulf and w.adventures[QUOTED] like this.
  5. May 27, 2018 at 5:29 PM
    w.adventures
    Nowheresville, SC
    2006 and early 2007 are the years to own with the Duramax it seems. Has the newer injector design so they are easier to replace. Correct on it being past the overheating problem while towing. Has the 6 speed Allison tranny. Don't plan on tuning it, going to keep it stock. Dodge is tempting but I have always been a Chevy fan.
  6. May 27, 2018 at 6:58 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Looks pretty clean. I'm a little more cautious about buying a diesel from a dealer, especially if they don't know about the injectors being done.
  7. May 27, 2018 at 7:00 PM
    w.adventures
    Nowheresville, SC
    Yeah, we shall see when I talk to them. I wouldn't buy one from a dealer if it had a lot of previous owners. Since this one is single owner I am hoping for the best but not getting my hopes up.
  8. May 27, 2018 at 7:05 PM
    w.adventures
    Nowheresville, SC
    Looks like from the carfax the fuel filter was replaced every 10k miles doesn't say anything about the injectors being replaced. Also has new tires 8k miles ago.
  9. May 27, 2018 at 8:21 PM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    @Coop68 or @YamaDirtrider can one of you link me to the thread about that battery charging mod? I’m not sure what to search for, but I want to read more about it.
  10. May 27, 2018 at 8:31 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Coop68 likes this.
  11. May 27, 2018 at 8:36 PM
    thefatkid
    Brian
    Colorado
    2004 thingy
    Why are you guys wanting to boost the voltage of the charging system? Looking to overcharge batteries?
  12. May 27, 2018 at 8:43 PM
    mountainmonkey
    Colorado
    Never enough
    I just wanted to read more about it. Supposedly the stock system doesn’t put out enough volts to properly charge an AGM battery.
    Coop68 likes this.
  13. May 27, 2018 at 8:52 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    Not overcharge but get the system to charge at a voltage the batteries want. Odyssey Batteries stayed they want over 14v to charge and 13.5-13.8v float charge. The float charge on the trucks is 13.3. So busting the voltage by .5 gets in the range of what the batteries need. Can do it all without modifying the system. Building a plug and play device.
    This wound be best for any agm battery. A regular wet cell is fine with the stock voltage
    CO MTN Steve and Coop68 like this.
  14. May 27, 2018 at 8:55 PM
    JDR07
    JDR07 Well-Known Member
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    Anyone know of any junkyards with a 3rd gen?
  15. May 27, 2018 at 9:48 PM
    thefatkid
    Brian
    Colorado
    2004 thingy
    Curious, have you measured voltage while running? Most times I've measured voltage while running it sits around 13.8-14.1v. As high as 14.5 when the battery is depleted until maximum current is reached then voltage drops.
    Edit: DVOM measured
  16. May 27, 2018 at 10:05 PM
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    So i was reading and watching somthing that stated that after or around 2006 manufactures changed voltage outputs from alternator to battery. Let me see if i can find it again. I guess this has all come about with all the dual set ups and some people killing batteries and or just fear of destroying a $250-500 bucks worth of batteries. People have been reading what the AGM needs and realizing its not getting charged properly. Cause i guess our trucks 06+ arent designed to run AGM technically. So fare what i have gathered, but still reading into it!
    Edit link to other discussion
    https://www.tacomaworld.com/threads...ttery-system-q-a.468553/page-22#post-17837993
    Video i watched warning very long!
    CO MTN Steve and j-utah like this.
  17. May 28, 2018 at 4:12 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Would upping the Alternator work? I was planing on getting an stock size altenator that was either a 200A or 250A. Still not sure which one to get. @YamaDirtrider this was one of the things I was going to discuss with ya but since you guys are on the subject figure I ask. The plan is to run Dual Odyssey PC-65-1750 In the bed. So that is some distance from the alternator.
  18. May 28, 2018 at 7:02 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
  19. May 28, 2018 at 7:04 AM
    YamaDirtrider
    Josh
    Elizabeth CO
    Up the alt would only increase the amount of amps it puts out. For you, your not adding massive amps and speakers, so I’d say no. Don’t waist your money on upgrading the alt. I’d say get the larger stock size. When you do draw large power it will have to do less work to get them charged back to full
    It is a good distance but like I and other said before, as long as you use a thick wire the voltage drop over 10’ is not substaincal enough to worry about. You can reasurch the wire, but even at 20’ of run with a 0 gauge I wound bet you’ll see less than .05v drop.
    From all the reasurch currently you wound be better of with a voltage booster or relocating the sence wire to where the batteries will be. Personally I’d do the booster just so I don’t have to cut up stock harness.
  20. May 28, 2018 at 7:07 AM
    Coop68
    Coop
    Erie/Dacono, CO
