Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Aug 8, 2018 at 5:46 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Alpine Loop. :notsure:
    sparseowl117[QUOTED] and Littles like this.
  2. Aug 8, 2018 at 6:43 PM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    @Martyinco
    Just think of all the time I can save :D
    Marty I need a quote on doing this, spare no expense!
    @Stig will probably steal this for his place too.
  3. Aug 8, 2018 at 7:03 PM
    Stig
    Brandon
    Ta no mo
    Oh yeah...it'll be easier to put in the shower since you can move the drain wherever you want the shitter.
    Multi function shower head doubles as a bidet.
    Aww yeah.
  4. Aug 8, 2018 at 7:41 PM
    Stig
    Brandon
    Ta no mo
    Lesson to use professionals for your home projects...
    Homeowner wanted to order material through Home Depot because they had a credit card through them. We told them to expect issues since it was stuff that wasn't regularly stocked but they figured it shouldn't be a problem.
    Order took a full day for me to order 4 separate items. I think it was four phone calls and three emails, i had item numbers and quantities prior to first calling them. This was on the 13th of July with an expected delivery to me in 14 days. HD would call me when items arrived to them in Vail and to schedule a delivery.
    I had to call a few times after not hearing anything after the expected arrival at the store. Was told they didn't know where the order was, then they'd call back, etc.
    Order finally was delivered today, two weeks late... And one of the items (48 of them) were delivered in tan instead of brown to match the rest. Order invoice says brown, delivery ticket says tan.
    This was through the "pro" desk so you'd think they have a tiny bit more knowledge and give a shit...but...that's what you get with a big box store.
    On the other hand, we design a new deck in the morning on a project that we're doing other work on from the lumber yard, have all the correct materials delivered by 2pm the same day. And it's cheaper than HD. Granted it was in stock items, but still.
  5. Aug 8, 2018 at 7:42 PM
    Tom Servo
    Tom Servo Dickweed
    Thornton, CO
    2013 DCSB TRD Sport
    Conveniently located grab bar...
  6. Aug 8, 2018 at 7:47 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Not that it helps most of you guys but I can do crimps up to 4/0. I usually have up to 2/0 terminals around, location is Grand Junction, though.
    Coop68 and SilverGhost[QUOTED] like this.
  7. Aug 8, 2018 at 7:55 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Yep. Usually better using local supply companies.
    Building question. What's better for the money. Insulated concrete forms or stick built with spray foam? This would be for a 1200sf home so not a mansion.
  8. Aug 8, 2018 at 8:11 PM
    Stig
    Brandon
    Ta no mo
    Not going to say I am an expert or to have a ton of experience with each enough to say for fact... but I'd say for the standard build, ICFs are a much denser material that'll hold temps better and pretty easy to do (at least for small foundation walls). You could of course go with thicker walls and more insulation to get a similar output. As far as money, always depends on where you're at and how good the builders are in your area. If they specialize in something and do it well, fast, you might get it cheaper to make either a better option as far as dollars.
    For mi casa, I'm leaning towards the foundation walls in ICFs so the crawlspace has good insulation. The rest will be stick built and very well insulated. Materials usually arent too much of an issue, its the labor quality is. Construction workers as with most skilled labor trades are quickly going away... so quality isnt cheap, and theres less and less of it each year. Its also why prices keep going up.
    JDM and w.adventures[QUOTED] like this.
  9. Aug 8, 2018 at 8:20 PM
    w.adventures
    Nowheresville, SC
    Was also thinking I could do ICF on the lower level/garage and do living level stick built on top but not sure on two stories anymore. Going to talk to a builder and see what they say. Also depends on how flat the lot is.
    Stig[QUOTED] likes this.
  10. Aug 8, 2018 at 8:24 PM
    Stig
    Brandon
    Ta no mo
    Yeah the site will usually determine the cost benefits of up vs out. After working on a 'barndomonium' that was a 50x70 garage with living area over it... on i think 40 acres, it was really dumb to not just go wide or build a house next to the garage. Going up and down the stairs to live above a garage that has ~18ft ceilings... no thanks. Granted, they'll likely spend less than two weeks a year there and it'll just sit vacant for the rest, so the climb up the stairs wont be too bad. I have plenty of room so I tossed around the two story idea but quickly nixed that.
    w.adventures[QUOTED] likes this.
  11. Aug 8, 2018 at 8:28 PM
    w.adventures
    Nowheresville, SC
    One of my previous clients built their vacation home on the side of a hill. Has a total of 64 stairs with about 7 different landings with the living room and kitchen on the upper level. The kicker is they put a wood fireplace in the living room. That's a lot of stairs to climb carrying up firewood.
    CO MTN Steve and Stig[QUOTED] like this.
  12. Aug 8, 2018 at 8:32 PM
    2016spicytaco
    2016spicytaco Spicy Kitty
    Al
    Denver, Colorado
    Turd Gen for Life
    Hellooooooooooooooooooooooooooooo Colorado!!!! Its hump day!!
  13. Aug 8, 2018 at 8:34 PM
    2016spicytaco
    Al
    Denver, Colorado
    Turd Gen for Life
    We have contacted the customer relations manager at Stevenson Toyota West to address your 2017 Toyota issue
    The customer relations manager, Jeff Tossie or a member of the dealer’s management team will contact you by the end of business 8/8/2018.
    If you wish, please feel free to contact the dealer at (303) 277-0550 and request to speak with the customer relations manager.
    In the event you do not receive contact from the dealer by this date, please contact us and reference case # 1808063130.
  14. Aug 8, 2018 at 9:34 PM
    Stig
    Brandon
    Ta no mo
    What'd you break?
    CO MTN Steve likes this.
  15. Aug 8, 2018 at 9:34 PM
    Stig
    Brandon
    Ta no mo
  16. Aug 8, 2018 at 9:59 PM
    Kappes03
    Kappes03 [OP] Legend of the UG
    Colorado
    2014 Tundra CM
    No more waffle stomps
    BYJOSHCOOK and Martyinco like this.
  17. Aug 8, 2018 at 10:03 PM
    Stig
    Brandon
    Ta no mo
    I'm not hip enough to have known what that was. Google says thats naaasty.
    :rofl:
    I always just take the drain grate off when i move in. :D
  18. Aug 8, 2018 at 10:04 PM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
  19. Aug 8, 2018 at 10:05 PM
    Kappes03
    Colorado
    2014 Tundra CM
    Hahaha oh man I can only imagine what came up in Google.
  20. Aug 8, 2018 at 10:13 PM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Coastal, made the most money sense.
