Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Sep 3, 2018 at 9:34 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Looks like a 6 1/2 ft bed. Only thing it's lacking is towing capacity for the travel trailer
    Stig[QUOTED] likes this.
  2. Sep 3, 2018 at 9:35 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Metal edging can be dangerous for bare feet and paws. So if you do go that route make sure to buy the plastic cap to put on it. There are versions of metal edging that have a rolled cap which keeps it from being sharp but costs more.
  3. Sep 3, 2018 at 9:49 AM
    Madjik_Man
    Colorado Front Range
    Yeah that stuff has a rolled cap on it.
    I still have childhood fears about the razor sharp metal edging my mom put in our landscaping.
    Gramps[QUOTED] and Stig like this.
  4. Sep 3, 2018 at 10:01 AM
    acidchylde
    acidchylde Well-Known Member
    Fort Collins, CO
    07 Sport AC, black, still pretty much stock
    I'm not sure you're reading that price right. $50 for 5x8'=40' so if you need 140' you're looking at $200 with some leftovers. That's not out of line with local suppliers at least up here: https://www.crystallandscapesupplies.com/pricing However, I will make a couple of recommendations. First, I highly suggest springing for the 6" instead of 4". Grass grows under 4" pretty easily. Most people still go with 4", but... Second, I'd make sure to get the rolltop. As @Gramps mentioned, flattop can be sharp. I do not recommend the plastic tops. Shit comes off all the time, or gets torn up by mowers and just degrades in sunlight. I've never seen an install of it that lasted. And rolltop generally isn't any more expensive (at least at the supplier I link to above). Expense comes more with depth and metal type/finish.
    Now, if you really want to be cheap... I might have enough that would cover you that's going to the scrap yard. It is 'pre-patinaed' for you :D but still solid, at least the pieces I've handled so far. It isn't rolltop, it's 4", and it's all the way up here, but it would be free. If you're interested I can take a couple of pictures and get the total length laying out there.
  5. Sep 3, 2018 at 10:39 AM
    Madjik_Man
    Ugh I forgot to multiply by 5 (pieces):anonymous:
    Please take pics of the scraps you have. That could work.
    And it’s not containing or withholding grass. It’ll just be containing the decorative landscape rocks for the path. Which I’d want to be 2-3” deep so the 6” stuff is probably what I need. (Assuming I need to dig in what ever I use?)
    And here’s the preemptive reply to Marty who is about to chime in with witty repartee about my math skills and cheapness...
    :luvya:
    Martyinco, Gramps and w.adventures like this.
  6. Sep 3, 2018 at 12:15 PM
    acidchylde
    Fort Collins, CO
    They're not scraps, they're going to scrap because I didn't think anyone would want it or have use for it. They've been installed for however long and then sitting in the yard for a while after that when they were replaced by timbers which have been there long enough to partially rot. But it's all still flexible and doesn't have any holes in it, it's just pre-aged. Looks like there are 9 pieces out there that are 10' long, so it wouldn't cover all you need. If you cared enough for uniform color, some of that could be cleaned off (ie the white mineral deposits on some of them). But you generally shouldn't see more than the top quarter to half inch of edger on a proper install anyway.
    So you'll have rock (or some other kind of mulch) on both sides, just different kinds? If that's the case 4" should be fine. There's different ways you can do your install depending on how much work you want to put into it and drainage. You could just clear off whatever you're covering and put the rock on the surface (over weed barrier of course to at least try and help) and then even with 3" depth on the rock you'd still just pound the edger down an inch or so. Or you can dig in to whatever depth, you just want to make sure you're not creating back drainage towards a house or blocking something off - water is still mostly going to drain along the surface of the dirt, and if it hits edger that's into the ground it will follow that edger. I'd need a better idea of where and what's on either side to offer any specific suggestions.
    The last major thing I did, we put in a fairly extensive flagstone/crusherfine path and a 'landscape' border around the entire back yard. The parts that weren't going to be grass we sprayed vegetation kill on, waited a few weeks, then rototilled the surface to be able to level things out and make it easier to pound down the edger. I wanted no part of that, so the owner did the edging install leaving half to an inch above the top of the grass on that side and three inches or so on the rock side (so we didn't really dig down and remove any dirt) and then we came back and put down weed barrier and a layer of crusherfines to set the flagstones in, then put those in (think a halfway cross between a full flagstone path and just a stepping stone path) and got them well seated, then filled in around them and leveled it off with more crusher fines. There's a bit of a drop from the edge of the path to what your foot would compress the grass to, but that was intentional rather than have the path flush/lower than the grass.
    Gramps and Madjik_Man[QUOTED] like this.
  7. Sep 3, 2018 at 12:22 PM
    Madjik_Man
    Thanks. 90' won't be enough though. I appreciate it.
    And I'm going to simple on this.
    I was envisioning just shaping the edging to define my path. Putting weed fabric down then covering it in 3" of rock... level to the best ability.
    On either side of the edging will either be mulching, ground cover or perennial plantings.
  8. Sep 3, 2018 at 12:32 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    "Buy our certified used vehicles" on a sticker on the windshield. Eh, no gracias.
    CharlieCafe likes this.
  9. Sep 3, 2018 at 12:34 PM
    acidchylde
    Fort Collins, CO
    In that case if it's already there (the stuff on either side) it's up to you on how much the path sticks up or you want to dig down (do think about the ends - if the ground is already flush with a walk or driveway where this new path ties in, you can't exactly pile 3" of rock on top of that and have it work/look nice I've seen people forget about this, or run it up to a gate and then not realize the gate won't open or there's a 'step' at the gate or whatever just runs out under the gate and spreads all over). You can pound it into the ground without doing anything, but there's a reason I wanted no part of the edger install. :D I'd say 4" should be fine (and less hassle to install if you aren't digging in), but be sure to add some extra to your length calcs - when two pieces meet they should overlap 6-8". You'll also want to have a block of wood to pound on, because you can bend/dent the edge of the stuff and it's very easy to flatten or even cut pins if you pound them too much onto the edge directly as you're staking it in.
  10. Sep 3, 2018 at 3:24 PM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    Anyone interested in meeting for dinner tonight?
    My hotel is down near 470 and 85 in Littleton.
  11. Sep 3, 2018 at 3:58 PM
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    I would if I was still up there!
  12. Sep 3, 2018 at 5:49 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    @Coop68 didn't want me in his club so he stopped by and helped me hang the bumper.
  13. Sep 3, 2018 at 6:06 PM
    P51DeP
    P51DeP Well-Known Member
    Christopher
    San Jose, California
    2008 Single Cab Tacoma 4x4 Super White
    Fog Light Install, BFGK02's, Bilstein 5100's, 4x4 Armor Rear Bumper, Front and Back Light Housings(Euro Black) Sound Deadening Cabin, Tint all around.
    Looks so cool. Need to do that someday.
  14. Sep 3, 2018 at 6:15 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I always wanted to do the fenders but never wanted to spend the money.
    CO MTN Steve and w.adventures like this.
  15. Sep 3, 2018 at 6:35 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Connected the truck charging system to the Camper.
    I checked the RV connection on the Tundra, it shows no voltage with the key off.
    But with the engine running, it supplies power to what would normally be the power system to a camp trailer. Cool, the truck supplies it's own battery isolation when the key is off. :thumbsup:
    I already had this pigtail made several years ago, I used it to power a battery charger off the tail gate when I flew RC helicopters. Now it's used to charge the camper battery.
    Routed thru the bumper and out the side.
    Drilled a hole thru the battery box. Decided to drill the bottom as it wouldn't show and was easier to seal.Hit it with some spray bed liner to water proof it.
    Battery connection.
    encased in wire loom.
    Painted the inside of the battery box.
    Battery installed, and I replaced the plywood base with a nice thick rubber mat to cut down the vibrations to the battery.
    The wire with the inline fuse is for a trickle charger.
    Battery connection from the underside. It will push up and remain flush if necessary.
    the plastic wire loom made for a nice snug fit thru the hole, so I consider it sealed.
    plugged into the truck.
    engine off voltage from the camper battery. I didn't take a pic of the truck connection with the key off, but the line is dead with the key off.
    engine running, charging the camper battery.
    Now I can charge the battery with the truck while driving, from a 1.5 amp trickle charger when parked ( I'll just open the battery door for that connection since it'll most likely be parked in the driveway)
    and from solar power while in camp. That connection is up front of the camper and runs thru a solar controller.
    I'll still install a converter/charger soon so I can charge and run everything from shore power when needed. The converters usually supply 25-30 amps and have individual 12vdc circuits for the lights, heater, water pump etc.. with fused connections.
    :burp:
  16. Sep 3, 2018 at 7:14 PM
    SSSherwood
    SSSherwood Well-Known Member
    07 Blue dbl tacoma sport
    2.5 OME lift. 32in MT, Airflow Snorkel, 4xinnovations sliders
    Thought I'd post my finished rear high clearance bumper with tire carrier. Work was done by Ryan Ahls in colorado springs
  17. Sep 3, 2018 at 7:49 PM
    w.adventures
    Nowheresville, SC
    Gotta love RV living! Wish I would have skipped solar all together. Maybe I will get more use out of the solar 2nd part of the trip where The temps are cooling off and I don't need the AC. Still need a bigger battery or two.
    Deathbysnusnu[QUOTED] likes this.
  18. Sep 3, 2018 at 8:26 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Do you run a generator at all?
    And is your lighting led? That alone makes a huge difference in battery consumption.
    Either way, AC units are extremely power hungry.
    w.adventures[QUOTED] likes this.
  19. Sep 3, 2018 at 8:33 PM
    w.adventures
    Nowheresville, SC
    Yeah, we have a 2400w generator. Been running it to power the AC which in turn charges our battery for the night so the solar isn't needed. All LED lighting, it's the furnace that sucks the power at night. Wouldn't need the furnace as much but we have the 1 year old that acts as our low temp alarm at anything less than 68 degrees.
  20. Sep 3, 2018 at 9:12 PM
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    Had a good morning sighting in a new scope 18BE29BA-B486-4B2A-8624-6C160040C53F.jpgThen came home and rotated my tires with a little help7174C335-44CA-4CF4-96E8-4761741E7E14.jpg
