Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jan 6, 2019 at 8:15 AM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    You building a trailer?
  2. Jan 6, 2019 at 8:16 AM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    For his dirtbike.
    :tumbleweed:
  3. Jan 6, 2019 at 8:29 AM
    Martyinco
    Martyinco Well-Known Member
    He should just by my aluminum bike trailer and call it a day, hell I can even weld on some funky shocks if it helps the sale :rofl:
  4. Jan 6, 2019 at 8:41 AM
    Stig
    Brandon
    Ta no mo
    Anyone know if there's a good outdoor gear tailor in the area?
    I have a jacket and maybe skiing overalls that I'd like to add vent zippers to.
  5. Jan 6, 2019 at 8:43 AM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    No
    still got the hitch carrier
    Don’t need another trailer...
    Just thinking about the way the shock is mounted in relation to travel. Instead of replacing my rear shocks for longer ones cound bring them up parallel with the frame and use the lever to get the long travel in the rear
    Stig[QUOTED] likes this.
  6. Jan 6, 2019 at 9:01 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I'm not an expert on the matter, there's a few people on here in the LT section with a cantilever rear. Might ask in there. I even think one of the LT companies (LSK maybe??) makes a kit for the 2nd gens.
    I wouldn't bother on a 2nd gen where you can get the shocks outside of the frame. Even if you go LT with shocks through the bed, you hardly loose any bed space. Cantilever is more complicated, harder to tune the shocks, and quicker to heat them up.
  7. Jan 6, 2019 at 10:00 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    A 4:1 and up motion ratio will work cantilever shocks twice as hard and need twice as much maintenance. IMO not work the trouble if your paying someone else to figure it out for you.
  8. Jan 6, 2019 at 11:06 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    @T-Rex266 (Formerly known as Sean around here) has good connections there.
    @Gramps I think does too.
    T-Rex266 likes this.
  9. Jan 6, 2019 at 1:20 PM
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    Bare Boulder in Lafayette fixed a dog harness for us, should be able to do that for you. Ripstop Repairs in Boulder as well.
  10. Jan 6, 2019 at 2:38 PM
    Stig
    Brandon
    Ta no mo
    Hung out in BV this weekend. Almost summited Yale. I started late, and only ~3miles in did i realize I didnt swap over all my food from my other pack. So I was running low and was getting a leg cramp as I scrambled up the last half a mile of steep snow. Made it to a false summit a few hundred feet and I was beat and facing likely -30 or less wind chill and called it.
    Swung out to Weston Pass on my way home since I wanted to find some moose! No moose, but found the light snow turned into a snow drift where someone got stuck earlier. I just put it in 4wd but had traction control crap on... killed all my momentum and I got stuck and was packed to the frame. :annoyed:
    A few minutes and the maxtrax got me back moving. I found the 2nd gen tacoma at a hiking trailhead, he was chained up. Didn't have any other issues after turning TC off. I made it up a few miles until the last tracks stopped in a large drift and turned around.
    CODOTUS, romafern, Greg3492 and 4 others like this.
  11. Jan 6, 2019 at 3:06 PM
    Stig
    Brandon
    Ta no mo
    Heres some Tacoma content! Speaking of playing in the snow, I got reminded that two years ago I was out goofing off as well. Imagine that shit! :rofl:
    This was exploring near the reservoir by the boy scout camp place near where Middle St Vrain or some other trails in that area dump out. I was sliding the corner while putting on gloves and decided the snow bank was better than into the reservoir.
    Threw the maxtrax behind the rear tire with locker on and backed out.
    Heading out of that road
    I then had second thoughts about driving Switzerland trail since there was clearly a ton of snow, it was late, I was alone, but... I figured I always do dumb things, bring it on!
    Got a half mile or so past the last house when coming from the west entrance and found a 2nd gen buried in the snow. At that point I realized there is no rear recovery point on a Tacoma if you dont have a hitch.
    So I snatched off trees in front to try to pull him to less snow and the ability to plow out. No dice with his tires. We repeated this a few times until it was wide enough for me to pass. Once I passed I pulled him into my tracks where he was able to then follow without a problem. Snow bashed the rest of the way out!
    CODOTUS, cshrum, xxTacocaTxx and 9 others like this.
  12. Jan 6, 2019 at 3:13 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Admit it. You miss your 2nd gen...:stirthepot:
    :D
  13. Jan 6, 2019 at 3:15 PM
    Stig
    Brandon
    Ta no mo
    I get the same shitty mpg and have more power with the tundy. But I'd rather have the Taco and $10k back for sure! Diesel swap!
  14. Jan 6, 2019 at 3:53 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    @Nazupag524 you see that the indoor range in Franktown is now open?
    Nazupag524 likes this.
  15. Jan 6, 2019 at 4:48 PM
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    I did not. Honestly I’ve never shot indoor so let’s go. My buddy and I went up to yankee last week after I talked to you. It was awesome. No one there. About 2-3 inches of fresh powder all the way to the shooting range.
    We gotta hook up anyway. I owe you $6 and a bag full of brass.
    YamaDirtrider[QUOTED] likes this.
  16. Jan 6, 2019 at 6:40 PM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    No I don't. Just really good friends and supporter of them. But if you call the main line tomorrow and dial ext. 103 you can speak with David and he will take of you. ;)
  17. Jan 6, 2019 at 7:35 PM
    Stig
    Brandon
    Ta no mo
    Where'd you take the Anus wheeling today? I thought the videos were Photoshopped since it doesn't look like Yankee Hill. :bananadead:
    I sure hope it's not Yankee Hill
  18. Jan 6, 2019 at 8:32 PM
    Stig
    Brandon
    Ta no mo
    He's in the garage breaking things and stuff
    :brianr:
  19. Jan 6, 2019 at 8:33 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    :luvya: Happy?
  20. Jan 6, 2019 at 8:34 PM
    Stig
    Brandon
    Ta no mo
    Too slow.
    Second place is the first loser
    :luvya:
