Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Mar 11, 2019 at 5:48 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Just gonna leave this here.
    xxTacocaTxx and Deathbysnusnu like this.
  2. Mar 11, 2019 at 5:48 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Lol
    Just saying soak all your suspension bolts everyday for a week or so before install.
    More is probably better being an 04
  3. Mar 11, 2019 at 5:49 PM
    steve2267
    steve2267 Small Mammal Fire Support Team
    Colorado
    04 Double Cab Tacoma 3.4L 4WD/TRD
    Am looking into acquiring a 1/2" cordless impact driver. (18v or higher) I am already semi-invested in Bosch 18v tools. Bosch has an 18v 1/2" impact driver that is spec'd @ 500 ft-lbs. Should that do... or is it worth getting a Milwaukee or Dewalt that may go as high as 700-800ft-lb (and maybe up to "1200ft-lb" breakaway torque) and buy into a new battery system as well?
  4. Mar 11, 2019 at 5:50 PM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Whats your intended use? Be very very careful of those things. They will get you in a world of hurt in a hurry.
    xxTacocaTxx and 303tacoma like this.
  5. Mar 11, 2019 at 5:54 PM
    steve2267
    Colorado
    PB Blaster good enough? (I've seen some comparisons to Kroil that suggest Kroil is not worth the extra expen$se.)
    Or is that homebrew 50-50 ATF/Acetone mixture really the magic elixir several web pages and forum discussions make it out to be? Are there any downsides to an ATF/Aceotone nut sauce? Like dissolves any and all rubber? Or makes you go blind? Or will corrode all metal within 6 months?
  6. Mar 11, 2019 at 5:56 PM
    303tacoma
    Rebecca
    I use PB Blaster
    It works fine..
    If it doesn’t you can always:sawzall::D
    Red Baron likes this.
  7. Mar 11, 2019 at 5:57 PM
    steve2267
    Colorado
    Intended use is to break loose old, rusted / corroded bolts that haven't been touched since the dawn of time, well... since Fremont birthed my truck.
    For tightening shit... figured I'd either use a speed ratchet, or maybe a 1/4" driver, then torque to spec.
  8. Mar 11, 2019 at 5:59 PM
    johntoyota
    Down yonder in TN
    16 truck
    Thats the problem with a 1/2" impact that goes to 800ftlbs. You blow spec away by the time you touch the trigger. You can use a 3/8" impact that doesnt have nearly the max torque that will get you close more safely.
    If you have bolts that need that much torque to break loose, then, um, well, you see, uh, so, good luck.
  9. Mar 11, 2019 at 6:05 PM
    steve2267
    Colorado
    So, reading between your lines, it sounds like a 1/2" that does 500ft-lb is more than enough... and if it's not enough, then I have other issues (e.g. reach for the BFing breaker bar, or the oxyacetylene torch etc)?
    Or are you saying 500ft-lb is still too much... and I should "be happy" with (I dunno) 250ft-lb or 180ft-lb?
    johntoyota[QUOTED] likes this.
  10. Mar 11, 2019 at 6:07 PM
    johntoyota
    Down yonder in TN
    16 truck
    You have a keen eye for words that werent there. :thumbsup:
  11. Mar 11, 2019 at 6:09 PM
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    24 Tacoma TRD Offroad Premium 4x4
    Plethora of "useless" shit
  12. Mar 11, 2019 at 6:10 PM
    johntoyota
    Down yonder in TN
    16 truck
    I see two beers in this picture. What does that say about me?
  13. Mar 11, 2019 at 6:14 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    My ryobi is great @300ftlb
    I knew a guy that has the high end desalt. Thec1200 breakaway is nice though.
    CO MTN Steve likes this.
  14. Mar 11, 2019 at 6:16 PM
    CharlieCafe
    Charles
    It says you need to learn to drink with both hands
  15. Mar 11, 2019 at 6:17 PM
    johntoyota
    Down yonder in TN
    16 truck
    Better?
  16. Mar 11, 2019 at 6:20 PM
    CharlieCafe
    Charles
    :cheers:
  17. Mar 11, 2019 at 6:22 PM
    steve2267
    Colorado
    Bear with me JohnT...
    Should I be happy with option 1, or go for door #2?
    1. Bosch IDH182B 1/2" impact driver (137.5 ft-lbs)
    2. Bosch 18-Volt High Torque Impact Wrench Kit with Friction Ring IWHT180-01 (500 ft-lbs)
    If tightening sheeitt... I totally get using a tool that only goes up to 140ft-lbs or so. But if trying to get rusted suspension bolts off... why not hit it with the BFH to start with (i.e. the 500ft-lb impact driver)?
    Or am I over-thinking this, and my inexperience is getting in the way... several days of PB Blastering and then use a big breaker bar?
    (Thanks for putting up with this noob's questions...)
  18. Mar 11, 2019 at 6:26 PM
    johntoyota
    Down yonder in TN
    16 truck
    Several days of fill-in-the-blank solvent and a breaker should do the trick on anything you need to break loose. Do I own a 1/2" impact? Yes. Is it always with me on the trails? Yes. Do I use it? Rarely. But, they are great tools to have available.
    If you use discretion and understand the trouble it can get you in and use its power wisely, by all means, go get one and enjoy it. But be careful. Use it for loosening and loosening only. Make sure to get one with selectable power. That will keep you in the safe house most of the time.
    303tacoma likes this.
  19. Mar 11, 2019 at 7:03 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Here’s a insurance question for you Colorado peeps. Original autobody shop estimated $4150 for repairs which I received a check from my insurance company. Took it to another autobody shop to get repaired but only the sheet metal work. Not the front bumper, wheels and running boards which were all in the original estimate. Ended up costing me $2800. The estimate that the shop is sending to insurance is for $4900. Insurance company will be sending them a check for the extra $750 which is for work they never did, so basically free money for doing nothing. Do I A) do nothing and let the shop keep the money for the repairs they didn’t do, B) call my insurance company and tell them what is going on or C) ????
    johntoyota likes this.
  20. Mar 11, 2019 at 7:18 PM
    johntoyota
    Down yonder in TN
    16 truck
    C) drink a cold beer and wait on the people that know what they’re talking about to chime in.
