Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Mar 12, 2019 at 6:44 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Length is your fried when it comes to Breaker Bar's, it's all about leverage until it will not fit where you need it too.
  2. Mar 12, 2019 at 6:44 AM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
  3. Mar 12, 2019 at 7:01 AM
    Kappes03
    Kappes03 [OP] Legend of the UG
    Colorado
    2014 Tundra CM
    Sweet spare tire mount Bolted right to the bed
  4. Mar 12, 2019 at 7:04 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Looks like he pulled that off a liberty or some shit :boom:
  5. Mar 12, 2019 at 7:18 AM
    Wulf
    rock raisin
    That's pretty minor. Hit it with a wire brush then coat it with an enamel paint of your choice.
    Afterwards you can use something like fluid film to protect the frame from developing rust again
    nats likes this.
  6. Mar 12, 2019 at 7:19 AM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Correct me if I am wrong, but doesn't Fluid film go on after paint protection? Fluid Film needs to be applied yearly I thought.
    Edit: you make it seem to me like you can paint or fluid film it.
  7. Mar 12, 2019 at 7:20 AM
    Wulf
    rock raisin
    Yeah, that's correct. If everything is painted up then you want to apply fluid film.
    CO MTN Steve[QUOTED] likes this.
  8. Mar 12, 2019 at 7:25 AM
    Wulf
    rock raisin
    Kind of at a crossroads with my projects. I have the rusted out 85 4runner with a bubba 4 link rear suspension that I was planning on parting out and then picking up a clean 85 4runner from a buddy to build instead. I have a 1UZ for said 4 runner as well and would probably make more of a resto-mod cruiser out of it than anything serious.
    I'm not sure if I should ditch both and just focus on the taco or pull my CJ7 out of storage and fix that up instead. It's all just seeming kind of meh right now
    I know, first world problems :luvya:
  9. Mar 12, 2019 at 7:33 AM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Sounds like a Lexus is in your future. :brianr:
    w.adventures and Stig like this.
  10. Mar 12, 2019 at 7:36 AM
    Wulf
    rock raisin
    ehhhh I understand the appeal for something that serves DD duty and goes wheeling but I have a econobox for those commutes :luvya:
  11. Mar 12, 2019 at 7:38 AM
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Red Baron likes this.
  12. Mar 12, 2019 at 7:39 AM
    Wulf
    rock raisin
    what about a 4runner with a 1UZ lexus motor in it? does that count? :luvya:
  13. Mar 12, 2019 at 7:55 AM
    johntoyota
    Down yonder in TN
    16 truck
    Yes: 85 Runner build of any kind.
    No: CJ7 build of any kind.
  14. Mar 12, 2019 at 8:18 AM
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    I have a set of RCI skids in the garage waiting for installation. Went with steel for the engine, trans, and transfer case, and aluminum for the gas tank. Beefy for the driveline, and try to save a few pounds where I could. They all seem stout, and the work looks great.
    Still trying to figure out how I'll do bumpers when that time comes.
  15. Mar 12, 2019 at 8:32 AM
    xxTacocaTxx
    Best Slope CO
  16. Mar 12, 2019 at 8:54 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Same amount as I have in mine :notsure:
  17. Mar 12, 2019 at 10:17 AM
    steve2267
    steve2267 Small Mammal Fire Support Team
    Colorado
    04 Double Cab Tacoma 3.4L 4WD/TRD
    Wire brushing the rust and painting aside... is pressure washing the dirt off sufficient, or do I need to wire brush and/or sand the whole frame before applying paint and then fluid film?
    Perhaps a better way to phrase the question: Obviously, where there is dirt, it needs to be removed. Is pressure washing then letting it thoroughly dry sufficient in those areas where no surface rust exists? Or should the surface be further prepped for paint and/or fluid film by mechanical abrasion or "chemical etching/priming" ?
  18. Mar 12, 2019 at 10:46 AM
    steve2267
    Colorado
    Is this OBD2 scanner any good? Is it worth $31? Or are there better ones out there? Or less expensive ones?
    Generally, you get what you pay for... but I've also seen adverts float across Facebook for shit, that when you do some checking, you find is a knockoff or clone for twice as much as what a simple Google or Amazon search shows up.
    https://www.amazon.com/dp/B07MB8XH6Q
  19. Mar 12, 2019 at 11:37 AM
    bot102
    bot102 The guy who ask a lot of questions
    Alec
    Castle Rock, CO
    2017 DCOR
    Beat up armor and broken stuff
    Not trying to sound harsh but along with many things you have asked, it's all personal preference. I asked a shit ton of questions when I first got on the forums too and many here will say I still do, :luvya:, but eventually you are just going to have to send it on some stuff and figure out for yourself how it works for YOU.
    If all you are going to use it for is to read the occasional code, something cheap like that will suffice. I have one like it, paid $20 for it, read a code or 2 with it, other than that it sits in my glove box.
  20. Mar 12, 2019 at 11:44 AM
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    Get one that works with the app you'll be using. Its bluetooth vs wifi. Most readers are the same unless built for their own app. The app is usually where you'll spend the money depending on how much you want the scanner to tell you and control you'll have to disable/enable certain things.
    xxTacocaTxx likes this.
