Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Apr 20, 2019 at 10:28 AM
    steve2267
    steve2267 Small Mammal Fire Support Team
    Colorado
    04 Double Cab Tacoma 3.4L 4WD/TRD
    Roof rack!? To be EAF... wouldn't such an angle iron bong need to be welded to a dual, swingout bumper?
  2. Apr 20, 2019 at 10:31 AM
    bot102
    bot102 The guy who ask a lot of questions
    Alec
    Castle Rock, CO
    2017 DCOR
    Beat up armor and broken stuff
    @kwolf9202 Didn't you get the Icon Stage 4? What we are installing next weekend?
  3. Apr 20, 2019 at 10:45 AM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    As luck would have it there is a group of us installing that very lift next weekend. You should come up and watch and/or help and maybe pick up a few pointers if you are unsure.
  4. Apr 20, 2019 at 11:34 AM
    Martyinco
    Martyinco Well-Known Member
    6 months, especially with the crack heads that built your house :annoyed:
  5. Apr 20, 2019 at 11:41 AM
    kwolf9202
    kwolf9202 Well-Known Member
    Kris
    Morrison, CO
    2018 TRDOR DCSB
    Yessir! Printed out that exact pdf you posted yesterday. Only cutting needed that I found was the rear shock mount. Says to use a barrel sander to clear the hose upload_2019-4-20_12-41-26.jpg
    eurowner likes this.
  6. Apr 20, 2019 at 11:53 AM
    johntoyota
    Down yonder in TN
    16 truck
    Boooo
  7. Apr 20, 2019 at 11:56 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Do this. I busted a hose off before. Rubber bushing at the top compresses on a hard hit and hose makes contact. Angle grinder works fine.
  8. Apr 20, 2019 at 11:59 AM
    johntoyota
    Down yonder in TN
    16 truck
    Don’t start sweating @kwolf9202. I have an angle grinder in my truck.
    kwolf9202[QUOTED] likes this.
  9. Apr 20, 2019 at 1:14 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    @thefatkid I was towing the camper yesterday with the sequoia and all of a sudden the traction control light lit up, VSC off light started flashing, check engine light lit up and 4lo light started flashing. Sequoia still drives fine, I tried unplugging the battery and reconnecting it only for the lights to come back on again after driving 5-10 miles down the road. Took it to car quest to read the codes and I have two codes. C1201 engine control system malfunction and p0717 turbine/input shaft speed sensor A circuit no signal. I then cleared the codes but they came back on after driving 5-10 miles. This is a 2011 sequoia with 5.7 any ideas?
    Thanks.
  10. Apr 20, 2019 at 2:07 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Until @thefatkid shows up..... I'm going to say that there's some sort of malfunction in your engine control system. Also, the "A" circuit from your input shaft speed sensor is not returning a signal. These two things may or may not be related.
    No need to thank me.
  11. Apr 20, 2019 at 2:56 PM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Follow the P0717, that is the source of your codes. If you have no turbine speed you wouldn't be moving so you have an electrical issue. I'd save you the hassle of trying anything like internet diagnosis and say you might as well burn it to the ground now before it has the chance to do it its self.
  12. Apr 20, 2019 at 3:19 PM
    w.adventures
    Nowheresville, SC
    Seems like some people have had success replacing the input sensor. Does that usually go bad or would it more likely be a wire issue? Looked under the sequoia and the wires look good from what little I can see of them.
  13. Apr 20, 2019 at 4:24 PM
    thefatkid
    Brian
    Colorado
    2004 thingy
    I haven't run into that code on a Tundra or Sequoia to say anything. If you were talking a FWD/AWD Toyota I'd say rodent damage to wiring. Perform an electrical inspection on the harness and the sensor. Shouldn't be to hard to find the open circuit with a DVOM
    w.adventures[QUOTED] likes this.
  14. Apr 20, 2019 at 4:41 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Rockies TuRDs
  15. Apr 20, 2019 at 5:01 PM
    steve2267
    Colorado
    In Arvada watching my son swim in the Jeffco Invitational... GO WARRIORS!
    Like a good dad... I locked the keys in my Taco so I couldn't leave before he swam.
    AAA FTW!
  16. Apr 20, 2019 at 5:08 PM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    Arapahoe warriors? Gross...
    Stig and Skywalker like this.
  17. Apr 20, 2019 at 5:27 PM
    johntoyota
    Down yonder in TN
    16 truck
    Easy meow. I think common etiquette prevents picking on someone’s kids.......
  18. Apr 20, 2019 at 5:39 PM
    mountainmonkey
    Colorado
    Never enough
    Not my intention to pick on the kid at all. My bad! If his kid does go to arapahoe he will know why I said what I did once he knows I graduated from Heritage.
    Just a bit of lighthearted ribbing
  19. Apr 20, 2019 at 5:42 PM
    Skywalker
    Skywalker Set the gear shift to the high gear of your soul
    Englewood
    2023 TRD Offroad Doublecab
    Stock
    Agreed! :thumbsup:
    Edit: Nevermind, heritage is just as bad!
  20. Apr 20, 2019 at 6:03 PM
    johntoyota
    Down yonder in TN
    16 truck
    I kid. I kid.
