Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. May 11, 2019 at 6:29 AM
    steve2267
    steve2267 Small Mammal Fire Support Team
    Colorado
    04 Double Cab Tacoma 3.4L 4WD/TRD
    You said, and I quote, "Wimpy foot man!!" Implying one is wimpy for using a foot purchase, hence they are not needed. "Sorry, babe... the taco lady said so! Here, let me help you wipe that round tubular imprint off your ***." :D
    303tacoma[QUOTED] likes this.
  2. May 11, 2019 at 6:32 AM
    steve2267
    Colorado
    This is true... but the rotation angle is going to determine how much distance there is between the center of the tube and the side of the truck below the door and whether or not somone needs climbing shoes to wedge a toe in there, or whether the ball of the foot can get a decent purchase on the slippery round object.
    Reh5108[QUOTED] likes this.
  3. May 11, 2019 at 6:34 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Lol ok
    You sure read a lot into my posto_O
    SilverGhost and johntoyota like this.
  4. May 11, 2019 at 6:37 AM
    steve2267
    Colorado
    Damn engineering degree. Sorry. :rofl:
  5. May 11, 2019 at 6:37 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    :popcorn: Over thinking sliders......
  6. May 11, 2019 at 6:39 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    I went with DOM. I did sacrifice a few lattes though, for $70 more why not. Gotta be able brag about them at the local Starbucks.
    CO MTN Steve, JesseB, Gramps and 2 others like this.
  7. May 11, 2019 at 6:40 AM
    303tacoma
    Rebecca
    True
    If I going overthink sliders it would be the eating kind:D:burp:
    rando451 and SilverGhost[QUOTED] like this.
  8. May 11, 2019 at 6:56 AM
    steve2267
    Colorado
    Another lift question...
    Aiming for 3" lift front / rear (loaded -- maybe), similar to what @Box Rocket did on his '03 DC with a full OME kit with 882s & OME AAL (D6XL or D43XL) and All-Pro 1.5 shackles. Planning on LR UCA's up front. If my daily surveying load proves too heavy, fall back plan is Firestone RideRite airbags over Daystar cradles.
    What other "extras" or little items should I be ordering? E.g. will I need / should I get extended brake lines? New bumpstops? If so, which ones? Wheeler Superbumps? What else?
    ETA: Is a Diff Drop Kit required? I have read, though, that a diff drop kit only changes the angle (slightly) of the front differential, and really doesn't drop it down much at all, so it really doesn't help. That poster recommended against a diff drop kit.
  9. May 11, 2019 at 7:12 AM
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    24 Tacoma TRD Offroad Premium 4x4
    Plethora of "useless" shit
    Who needs sliders when you can jump over everything? :bikewhoops:
  10. May 11, 2019 at 7:12 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I don't think you'll need the lift shackle if you're going with lifted springs.
    My take on the diff drop is if your boot fins don't touch after the lift it's not needed. It does drop the diff about a 1/2" which is usually enough to avoid rubbing the fins. The "oil starvation" issue people site is bs.
    You'll need new ubolts and likely the spring eye bolts as the old ones will most likely need to be cut.
    jubei likes this.
  11. May 11, 2019 at 7:31 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Davis.....
    Hasn't had a beer yet. But he had a donut and started pulling the wrong bolts. We'll see how this goes.
  12. May 11, 2019 at 7:40 AM
    steve2267
    Colorado
    Appreciate the advice. New Ubolts are part of my list already. I'll double check on the spring eye bolts.
    Should new bumpstops be on the list? With a 3" lift (loaded) - 3.5" lift (unloaded), should extended brake lines be installed? This brake valve (re-)proportioning valve doohickey I've read about... does that apply to 1st gens?
    @Reh5108, I am unsure if you have seen my postings in the past. My frame qualified for free replacement and is presently @ a Boulder stealership awaiting the replacement frame. Installation of new suspension is free, so I want to ensure all the parts necessary are on hand for the mechanic when he puts Humpty Dumpty together again. When I took all my land survey gear & equipment out of the truck, it totalled 900lbs, give or take. With that much weight, the back end is going to sag, even with Dakars + OME AAL. I am largely modelling my build off what @Box Rocket had done with his '03 TRD DC. (I'm bothering him via PM.) He ran the All-Pro 1.5" shackle which gave him 3.5" lift unloaded and 3" loaded with ~500lbs. Even if I trim down my daily load, I'm pretty sure I will not be any lighter than he was, so I'm thinking go with the same shackle setup he ran.
    A diff drop kit is only $27 from @Wheeler's Off-Road Inc... Does it hurt anything to put it on anyway, even if not needed? Or have it on hand for the mechanic to decide as he is doing the suspension (re-)install?
  13. May 11, 2019 at 8:07 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    :popcorn:
  14. May 11, 2019 at 8:14 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Oh this is going to end well.
  15. May 11, 2019 at 8:23 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Give us your best cv removal trick.
    Everything was real easy up until now.
  16. May 11, 2019 at 8:31 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Nevermind
    Wulf likes this.
  17. May 11, 2019 at 8:54 AM
    Wulf
    rock raisin
    glad we could help
  18. May 11, 2019 at 8:55 AM
    Wulf
    rock raisin
    cut cut cut cut cut
  19. May 11, 2019 at 9:05 AM
    Wulf
    rock raisin
    more to cut
    CharlieCafe and jubei like this.
  20. May 11, 2019 at 9:12 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Now the new CV is in but won't turn.
    Since it's not my truck, my idea is to reassemble and use the wheel to turn it and everything will magically fix itself.
