Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. May 11, 2019 at 11:55 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Too lazy to go to the store 30 is fine eh
    Deathbysnusnu likes this.
  2. May 11, 2019 at 12:28 PM
    steve2267
    steve2267 Small Mammal Fire Support Team
    Colorado
    04 Double Cab Tacoma 3.4L 4WD/TRD
    ETA: Yes, having stealership install OME suspension when they put Humpty Dumpty together again. Was not aware I should get new factory stocks & springs. I’ll ask. If I do, but only if I don’t provide a replacement suspension, might be worth having dealership install new factory suspension, then host a TW OME party the next weekend... then sell the new factory parts... to help defray costs —OR— get those custom Alcans.... Hmmm...
    You are the second person who has recommended the Alcans. While I am not opposed, they are more expensive at $710. But then, which shock? Can I still run the Nitrochargers? All I have read are “nitrocharger rear shocks are too short”? But their range of motion are around 9.3” — at least as long, as best I can tell, as the Bilstein 5125’s and Fox 2.0’s that All-Pro sells with their Expo springs, no? Or do Alcans with a 3-3.5” lift imply Bilstein 5125’s or Fox 2.0’s ($$)? @thefatkid told me Bilstein’s don’t well with heavy loads. @Squeaky Penguin is less than impressed with Bilstein’s...
    Kings or Foxes would be nice but... $$$
    BUT, the money saved by staying full OME will let me put LR UCA’s at this time. Research (lots of questions here on TW) revealed one fellow ran a pop up camper (1200 lbs) for a year and a half on full OME. I think he also ran Ride-Rite airbags, though not perhaps the entire time. The fellow with whom I spoke yesterday @Cruiseroutfitters in UT said the HD Dakars would support the weight, but sag of course while under load. @Box Rocket told me about using the All-Pro 1.5 shackles to gain an extra 0.75” of lift.
  3. May 11, 2019 at 1:20 PM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    2002 Double Cab TRD OR
    I think you’re running circles around yourself. If you’ve been surviving on the stock suspension up until now, then the OME stuff is going to be a big upgrade. 882’s and LR/SPC UCA’s in the front and Dakar’s with the AAL in the rear is a good set up.
    JasonLee likes this.
  4. May 11, 2019 at 1:38 PM
    steve2267
    Colorado
    I agree. Alcan’s might be nice, but I went back and re-looked at the Dakars. I think they’ll handle the weight... so that is where I’m headed. I started asking questions today just to make sure I’m not forgetting anything (e.g. extended brake lines, bump stops etc.)
  5. May 11, 2019 at 2:10 PM
    supralee
    supralee Well-Known Member
    Lee
    Boulder, CO
    2018 Sandshark Tacoma DCSB 6MT TRD OR
    Hahaha... Nice.
  6. May 11, 2019 at 2:25 PM
    supralee
    Lee
    Boulder, CO
    BYJOSHCOOK, cshrum and EnBoo like this.
  7. May 11, 2019 at 2:31 PM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    I am working on reconditioning a set of OEM LCAs for a second gen and need yalls help. I got the old ball joint and old bushings out no problem, but the damn sleeve w/flange that goes around the larger of the two bushings just will not come out of the eyelet of the LCA. Any tips from those that have gone through this ordeal?
  8. May 11, 2019 at 2:33 PM
    Wulf
    rock raisin
  9. May 11, 2019 at 2:37 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    When my frame was replaced in Pennsylvania I received new springs and lower control arms. I'd still have them install whichever pack you decide on. They should give you the springs they would normally put on. I got by for a little while by cutting down another set of factory springs and added two leaves to each side. Then used a adjustable shackle to achieve some lift. Probably not enough spring rate for 900#. I'd bottom them out often.
    Add the cost of airbags to the dakars and you may end up close to the cost of custum Alcans.
    Yes, you can still run the OME shocks. Honestly I don't think any of the low end upgrade shocks handle a lot of weight well. I think I had the lighter valving in my OME shocks and they didn't do much maybe the heavier valving would be up to par but I think there was a small sacrifice in length. If you want to push your rig to the limit and maximize travel, off the shelf shocks aren't the answer. It's a lot more money to make the most of your travel though.
    For what it's worth I think I got 40k out of the Nitro chargers, killed them both on miles of washboard roads. Replaced them temporarily with Toytecs BOSS offering and bent one if them within 10k. The fronts are somehow still holding up.
    I'd do a good bit of searching on the dakars. I think I recall many being unhappy with there load capacity.
    Short answer you'll probably be happy with what you have picked out.
    Littles likes this.
  10. May 11, 2019 at 2:38 PM
    Reh5108
    Idaho
    Hack saw blade and cut through it.
    JDM and mountainmonkey[QUOTED] like this.
  11. May 11, 2019 at 2:51 PM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    10tacotrooper, Wulf[QUOTED] and Beers like this.
  12. May 11, 2019 at 3:03 PM
    Wulf
    rock raisin
    Hahahahahaha
  13. May 11, 2019 at 3:03 PM
    Wulf
    rock raisin
  14. May 11, 2019 at 6:07 PM
    Wulf
    rock raisin
    She's a qt p2t
  15. May 11, 2019 at 6:18 PM
    Kappes03
    Kappes03 [OP] Legend of the UG
    Colorado
    2014 Tundra CM
    @Wulf banned?
  16. May 11, 2019 at 6:27 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    No.
    The word "banned" is struck through not his user name.
    He got you though :D:rofl:
  17. May 11, 2019 at 7:14 PM
    Daddy_Firebird
    Daddy_Firebird Well-Known Member
    Colorado
    2016 TRD Off Road DCSB MGM
    -Toytec Aluma 2.0 -SPC UCAs -Icon RXT Leaf Pack -Front & Rear Durobumps -Cooper ST Maxx Skinnies on Methods -RCI Skids -Leitner Rack -Custom Billet Shift Knob (7r41lbr34k3r) -Stromung "Tucker" Exhaust -Expedition Essentials TTM
    She shop at the carpet mill?
    Deathbysnusnu and Wulf like this.
  18. May 11, 2019 at 7:21 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    :ohsnap:
  19. May 11, 2019 at 8:10 PM
    Wulf
    rock raisin
    Oof
  20. May 11, 2019 at 8:29 PM
    Wulf
    rock raisin
    it's ok I stuck my hand in the fire
    CO MTN Steve likes this.
