Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jun 16, 2019 at 3:47 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Loosen your lower control arm cam bolts and it will go right in without that weird jack setup you have going on.
  2. Jun 16, 2019 at 4:09 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I don’t have time to mess with getting an alignment again before my trip. The weird jack setup was trying to compress the spring against the truck weight while my body weight was pushing down on the steering knuckle/LCA. I am NOT removing the LBJ due to paranoia of having ANOTHER thing go wrong before my trip in a few days and I have to run around looking for parts.
    I got the spring compressor to work well enough for one side. Moving onto the other.
    YamaDirtrider and johntoyota like this.
  3. Jun 16, 2019 at 4:28 PM
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    24 Tacoma TRD Offroad Premium 4x4
    Plethora of "useless" shit
  4. Jun 16, 2019 at 4:51 PM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    :cheers:
    RockiesTaco, BYJOSHCOOK, Wulf and 2 others like this.
  5. Jun 16, 2019 at 5:36 PM
    Comato$e
    Comato$e Well-Known Member
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    Never will I take a third gen up pikes peak holy let’s go places that sucked . Venting .......
    Wulf likes this.
  6. Jun 16, 2019 at 5:39 PM
    1997tacomav6
    Denver
    Was up there last week,
    Pikes peak road race is end of the month
  7. Jun 16, 2019 at 5:48 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Damn!!! I need to start charging more than a bottle of whiskey for this then....better make it two from here on out.
    WarFab Armor likes this.
  8. Jun 16, 2019 at 6:06 PM
    johntoyota
    Down yonder in TN
    16 truck
    Oh, come one! Somebody made it through that drift.....
    xxTacocaTxx likes this.
  9. Jun 16, 2019 at 7:18 PM
    Theetrentmeister
    Theetrentmeister Well-Known Member
    odomandr likes this.
  10. Jun 16, 2019 at 8:03 PM
    JasonLee
    15 TRD OffRoad
    Well, I'm not dead and the truck is back together. I HATE THOSE SPRING COMPRESSORS.
    Tightens unevenly, pinches the socket so you can't get it off. Loosen it a little, switch sides. Repeat 5,000,000 times. Realize that the pieces that hold onto the coil are too thick and have smashed and broken the plastic cover for the OME shock. F-it. remove broken plastic. Oh great, it slid around a little bit so now the shock is off-center. Push. Push harder. Push really hard and slip top hat on. S***. Not enough thread exposed. Tighten up more. Pinch socket again. Repeat. Get it together. Realize that the shock body rotated and now you can't get it into the truck without rotating against the 600lb coil. Can't do it by hand. Wrap a strap around it, twist it tight with a 19mm box wrench. Rotate too far. Go back (to far). F-it. Shove it in and tap the bolt back in with a screwdriver inserted in the other end to keep things aligned.
    Repeat on other side. Lose 6 hours of your life. Drive home, still hear noises (likely because the top hats were bored out from a missing washer) and immediately start browsing the threads to figure out which brand of coilovers to buy.
    ColoradoTJ and Red Baron like this.
  11. Jun 16, 2019 at 8:05 PM
    Martyinco
    Martyinco Well-Known Member
    Based on the width of the tracks, a side by side. Much lighter than me :rofl:
    johntoyota[QUOTED] likes this.
  12. Jun 16, 2019 at 9:50 PM
    MO Tacoma
    MO Tacoma Well-Known Member
    Castle Rock, CO
    2014 DCLB with a couple mods
    ADS extended travel, 14" 700 lb springs, Total Chaos UCA/LCA, Dakars. 37/12.50r17 Pitbull Radial Rocker. SCS 17" SR8. 4.56s with f&r ARB lockers. Relentless sliders, full skids, debadged. 35% tint on all windows. Katzkin leather w/ heated seats
    Did you get it figured out? I could throw some tips your way if needed.
  13. Jun 17, 2019 at 6:06 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Too bad you have a 1st Gen- If it was a 2nd or 3rd Gen. I have a set of fronts TRD OR (Shocks and OEM Coils) ready for a new home.
  14. Jun 17, 2019 at 6:11 AM
    GoldenBrew
    Golden, Colorado
    ??? constant shifting and lack of power? 33's or 35's ? Auto or Manual? There is a solution.
  15. Jun 17, 2019 at 6:28 AM
    Wulf
    rock raisin
    RockiesTaco, JDM, JasonLee and 2 others like this.
  16. Jun 17, 2019 at 6:35 AM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
    same story for me but when my wife said, "I think some bigger tires would look good, and maybe a lift too" I could have sworn I heard the angels choir go off. Picked up a lift kit from @Toytec Lifts there over the weekend, hard to say no to the discounts they were running. All you can do is hug them, say I love you, and then go hide before they can take it back!
    huzer and cshrum[QUOTED] like this.
  17. Jun 17, 2019 at 6:51 AM
    GoldenBrew
    Golden, Colorado
    I had a 2nd Gen Tacoma and a 1st and 3rd Gen 4rnr. Nature took the Tacoma to parts heaven after two massive hail storms. I sold the 4Runrs. and they were gutless. So far I would say my 3rd Gen Tacoma (AT) runs circles around my 2nd Gen Tacoma (6sd MT). Yes I had to re-gear (via Brian) and I added the Tune. Now has plenty of power, shifts great, pulls the camper fine, and gets way better (4 mpg city and 6mpg highway) than my 2nd Gen did. If there was an option for Turbo, SC, or Diesel for this truck it would outsell the F150 hands down - but obviously there are not those options, yet. Had two Silverado Z71's -they both shit the bed just after warranty went out - never again for Chevy. Never a Ford or Dodge fan and not interest in Nissan. Guess I'm almost out of options. :) :(
    johntoyota and Wulf[QUOTED] like this.
  18. Jun 17, 2019 at 7:06 AM
    Madjik_Man
    Colorado Front Range
    Need a Boy Toy?
    I could make myself available if it means living there.
    buffedout and Wulf like this.
  19. Jun 17, 2019 at 7:08 AM
    Martyinco
  20. Jun 17, 2019 at 7:30 AM
    huzer
    huzer Well-Known Member
    Tim
    CO
    2019 4Runner
    I wish I could have made it out there. Right as I pulled out, my dog had a seizure, so that killed those plans. He just started having them, and we're trying to figure out the right dosage to control them.
    But on a bright note, my wife gave me a father's day card and it had a little note in it. The note, "good for 1 lift kit of your choice". I had shown her a picture of a lifted 4Runner that was at our neighborhood rec center a week or so ago, and she said that looks good, you should do something like that. There must be something in the air!
