Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jun 29, 2019 at 5:49 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    What chu get?
  2. Jun 29, 2019 at 9:14 AM
    bot102
    bot102 The guy who ask a lot of questions
    Alec
    Castle Rock, CO
    2017 DCOR
    Beat up armor and broken stuff
  3. Jun 29, 2019 at 9:15 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    What are you working
    Wulf likes this.
  4. Jun 29, 2019 at 9:47 AM
    Wulf
    rock raisin
    Any HVAC techs here want to pick up a side job? AC won't come on at my house and its already 80 deg inside :bananadead:
    I've been sucking it up but the dogs aren't too happy about it
  5. Jun 29, 2019 at 10:12 AM
    pop.tremuloides
    pop.tremuloides Well-Known Member
    Colorado
    2019 TRD OR DCSB
    DBACK HD, Armor, SP9100, lights...etc
    Hi Sub,
    Trying to wire up my Baja Design rock lights. I suck at wiring in vehicles.
    I have 14 ga automotive wire to run them (overkill I know) since I have that on hand. But the BD wires are 22 ga. I am assuming I can simply solder BD lights to the auto wires and run them to the switch pro.
    I have 22-18 but connectors but I think soldering and then heat shrink8ng the connection would be a better option. Thoughts?
    Ps I’m pretty good at soldering for my rc drone stuff and always thought that was the best approach.
  6. Jun 29, 2019 at 10:26 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    Does the furnace fan turn on but not the AC condenser outside? Could be a GFCI outlet somewhere that got tripped and needs to be reset.
    I found that out by accident at my old place. Stuck a night light on the outlet to let me know if it was tripped.
    CO MTN Steve and Wulf[QUOTED] like this.
  7. Jun 29, 2019 at 10:28 AM
    Wulf
    rock raisin
    Yes furnace fan does come on, I'll try resetting my GFCI breakers.
  8. Jun 29, 2019 at 10:53 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Condenser should be on it's own circuit. 220 with it's own disconnect. Shouldn't be gfi protected except maybe by a "whole house" gfci
    CO MTN Steve and mountainmonkey like this.
  9. Jun 29, 2019 at 10:54 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Check disconnect for condenser.
  10. Jun 29, 2019 at 10:54 AM
    Daddy_Firebird
    Daddy_Firebird Well-Known Member
    Colorado
    2016 TRD Off Road DCSB MGM
    -Toytec Aluma 2.0 -SPC UCAs -Icon RXT Leaf Pack -Front & Rear Durobumps -Cooper ST Maxx Skinnies on Methods -RCI Skids -Leitner Rack -Custom Billet Shift Knob (7r41lbr34k3r) -Stromung "Tucker" Exhaust -Expedition Essentials TTM
    current state of mind..
    COS_TACO, BYJOSHCOOK, cshrum and 5 others like this.
  11. Jun 29, 2019 at 11:01 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    :notsure:
    All I know is if I reset that one outlet then my AC came back
  12. Jun 29, 2019 at 11:34 AM
    Wulf
    rock raisin
    Got it running, thanks fellas. Turns out the bypass thing from Excel wasn't working, bypassed it and all is well :notsure:
  13. Jun 29, 2019 at 11:34 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    The upstairs here is 8-10degrees warmer until we drop it below 74. I gotta fix the ceiling fan upstairs
  14. Jun 29, 2019 at 11:36 AM
    Wulf
    rock raisin
    It was up to 87 deg inside before I got the AC on, would have broken 90 this afternoon lmao RIP
  15. Jun 29, 2019 at 1:41 PM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
  16. Jun 29, 2019 at 3:35 PM
    huzer
    huzer Well-Known Member
    Tim
    CO
    2019 4Runner
    Just finished installing the lift today. Fronts are 6112s set at 2”. Rears are 5160s with T13 Wheelers springs, which are 1.5” lift. TRD Pro wheels with BFG K02 275/70/17. I’m thrilled with how it turned out. Rides awesome. Had one clunk after install. Forget to tighten one of the sway bar endlinks.
  17. Jun 29, 2019 at 5:10 PM
    Beers
    Beers Well-Known Member
    Colorado
    12 TRD OR
    Twin Lakes?
  18. Jun 29, 2019 at 5:16 PM
    Fix14wd
    Fix14wd Well-Known Member
    Bill
    Woodland Park, CO
    2016 Sport DCSB
    I noticed my rockers are getting a lot of chips in the paint so I decided to put my stock side steps back on thinking they might protect it a little better.. As soon as I got in the truck I immediately wanted to take them back off. I can't stand them rubbing against my legs getting in and out. Not to mention they make the truck look even lower to the ground... So it got me thinking about maybe sliders. The stock junk sits 14" to the furthest edge from the frame. How far out do sliders generally sit??
  19. Jun 29, 2019 at 5:32 PM
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    Could also be the condensation drain pipe float sensor. If the pipe gets backed with water, the condensate pan will fill (If your handler has one), trip the senor and shut the air handler down.
    Edit: Oof, I was a few pages behind. Didn't see you fixed
  20. Jun 29, 2019 at 6:44 PM
    Madjik_Man
    Colorado Front Range
    Absolute shitty day from hell.
    I feel like drinking a beer, killing someone, masturbating then going to sleep.
