Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jan 24, 2020 at 6:36 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Maybe I should document this for the good of TW
  2. Jan 24, 2020 at 7:31 PM
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
    Call these guys if you need mandrel bends but bring your wallet. http://www.hanksvillehotrods.com/
    GoldenBrew[QUOTED] likes this.
  3. Jan 24, 2020 at 10:08 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
  4. Jan 25, 2020 at 12:17 AM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    I see it!
    TacoBug likes this.
  5. Jan 25, 2020 at 10:28 AM
    10tacotrooper
    10tacotrooper Well-Known Member
    Andrew
    Thornton ,CO
    2010 Super White Tacoma dcsb offroad
    Can anyone with a 05-15 Tacoma double cab short bed measure the distance to the outside of their frame rails at the mounting point of the rear bumper?
  6. Jan 25, 2020 at 11:52 AM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    37 1/4”
    Given the frame dove tails inward
    10tacotrooper[QUOTED] likes this.
  7. Jan 25, 2020 at 2:05 PM
    johntoyota
    Down yonder in TN
    16 truck
    Winkle has to leave but I decided to stay and camp. If anybody wants to come out, I’ll be at these coordinates. Come on!
    CO MTN Steve likes this.
  8. Jan 26, 2020 at 4:05 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I use whatever works. Streamers and the trusty San Juan worm worked for me today. 10 fish landed.
  9. Jan 27, 2020 at 5:30 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    Those look beautiful Brett. Thanks for sharing
  10. Jan 27, 2020 at 6:36 AM
    bot102
    bot102 The guy who ask a lot of questions
    Alec
    Castle Rock, CO
    2017 DCOR
    Beat up armor and broken stuff
    Was out wheeling yesterday and took a decently hard hit to my front driver side tire. Started driving home after airing up and noticed my steering wheel skewed 45 degrees to the passenger side while wheel travel was straight.
    Pulled over and checked my alignment components and everything looked to still be in place. When I got an alignment at Toytec last month they put beads of red Loctite on my cam tabs/UCA/Tie rods so that I would know if anything ever got shifted. None of those beads were broken or anything. Not quite sure how my steering wheel could be so messed up if the alignment hasn't changed at all.
    @YamaDirtrider said it looked like one of my wheels was toed outward and mentioned something about my steering rack "jumping a tooth"
    Anyone able to offer any insight?
  11. Jan 27, 2020 at 6:43 AM
    Squeaky Penguin
    Brett
    Do you have spindle gussets? I bet you bent a spindle. Especially if only one side is messed up. If it was the rack, both sides would move evenly.
  12. Jan 27, 2020 at 6:47 AM
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    Yeah, I have spindle gussets. After seeing @Littles bend a couple it was one of the first mods I did
  13. Jan 27, 2020 at 6:47 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Steering wheel angle has more to do with the tie rods than the alignment cams.
    I've heard of steering racks jumping a tooth and I've experienced a bent spindle like Brett mentioned. :anonymous:
    Does it pull at all? Or just a crooked steering wheel?
    CO MTN Steve and Wulf like this.
  14. Jan 27, 2020 at 8:13 AM
    johntoyota
    Down yonder in TN
    16 truck
    Ive slammed mine into a few earthen banks and the wheel always gets jacked up. Alignments has always fixed it. Im with hypoxia, crooked wheel is usually tie rods.
  15. Jan 27, 2020 at 8:20 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    wats an alignment
    CO MTN Steve and CGoss like this.
  16. Jan 27, 2020 at 9:00 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Typically it's where you pay this guy to molest your truck with implements of destruction simply because the shop has an alignment rack and you don't.
  17. Jan 27, 2020 at 9:02 AM
    Wulf
    rock raisin
    Setting toe with a tape measure is good enough, right?
  18. Jan 27, 2020 at 9:07 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Depends....
    Actually, last time I talked to @Fatkid and he told me what position of the cams would create max caster (I've forgotten this of course).
    I then did toe myself with a tape measure (about 3 times of adjusting/driving) and when I took it in for an alignment, I discovered that I was actually fine. Camber was darn near 0 and my toe was perfect.
    Your results may vary depending on how closely you resemble my pic or your gif :rofl:
  19. Jan 27, 2020 at 9:31 AM
    Squeaky Penguin
    Brett
    Ties rods don't just go out of adjustment though. They may be able to 'fix' your problem, but it probably means something else bent or moved.
    Yes. At least with toe plates. I've been doing my own alignment for several years now with excellent results.
  20. Jan 27, 2020 at 9:44 AM
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    That's more what I was curious about. If the tie rods haven't moved at all, according to the beads of Loctite, and my spindles aren't bent( Unless I managed to bend a gusseted spindle) What did I break or move?
    @thefatkid got any ideas?
