Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jan 27, 2020 at 9:52 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Did you look at both sides of all four cams? That would be my first guess, but I know you said you looked at them.
    Without cam tab gussets, a hard hit will flatten a tab and mess up your alignment.
    CO MTN Steve likes this.
  2. Jan 27, 2020 at 9:53 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    When I bought my last jeep the toe was so off you could hear the front tires scrub while driving straight. Tape fixed it
  3. Jan 27, 2020 at 9:57 AM
    bot102
    bot102 The guy who ask a lot of questions
    Alec
    Castle Rock, CO
    2017 DCOR
    Beat up armor and broken stuff
    Yeah I checked all 4 tabs. Don't have gussets for them yet. Was going to pick up some LCA skids this coming month and they would help cover.
  4. Jan 27, 2020 at 9:59 AM
    Squeaky Penguin
    Brett
    Tabs or cams? Cause there's 8 places you should be checking.
    50 amocaT, CO MTN Steve and Wulf like this.
  5. Jan 27, 2020 at 10:05 AM
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    Don't know which is which, but I checked the front and back on the bolt that runs through the LCA. Neither looked to be moved
    odomandr likes this.
  6. Jan 27, 2020 at 10:16 AM
    Squeaky Penguin
    Brett
    I'm still confused.
    There's 2 cams per LCA. Both sides of each cam has tabs to hold them in place. So 4 sets of tabs per side.
  7. Jan 27, 2020 at 10:25 AM
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    Oh. So then I only checked 2 on each side. The front and back side of both arms. Not in the in-between portion. I'll have to run out to the truck and check them
  8. Jan 27, 2020 at 10:40 AM
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    So it doesn't appear that they marked the inner tabs on either LCA. So I don't know if they moved or not.
  9. Jan 27, 2020 at 10:44 AM
    Squeaky Penguin
    Brett
    You're probably fine. Just wanted to make sure you checked both cams on each side.
    It's unlikely the inner tabs would be affected if the outers hadn't moved.
  10. Jan 27, 2020 at 11:03 AM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    I've seen 3 bent spindles post gusset. I've also seen racks shift.
  11. Jan 27, 2020 at 11:31 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
  12. Jan 27, 2020 at 11:43 AM
    Squeaky Penguin
    Brett
  13. Jan 27, 2020 at 11:50 AM
    Wulf
    rock raisin
    good call
    jubei likes this.
  14. Jan 27, 2020 at 12:03 PM
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    Might have to come for a visit then
  15. Jan 27, 2020 at 12:33 PM
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    I'll be pretty butthurt if I bent a gusseted spindle. I've seen how hard it is to find new/used one. Not for an arm and a leg
    Red Baron likes this.
  16. Jan 27, 2020 at 12:36 PM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    I will be impressed, because I am a seasoned spindle bender and I haven't bent my gusseted ones yet. Which side did you potentially hurt? I still have a good driver side.
  17. Jan 27, 2020 at 1:02 PM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    JasonLee[QUOTED] likes this.
  18. Jan 27, 2020 at 1:21 PM
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    Drivers side is where I took the hit
  19. Jan 27, 2020 at 1:25 PM
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    Well if you end up diagnosing a bent spindle to be the issue, I will only charge you an arm.
    johntoyota likes this.
  20. Jan 27, 2020 at 3:34 PM
    CGoss
    CGoss Well-Known Member
    Las vegas
    2006 rad red offroad
    My steering wheel changes positions every time I wheel. Goes from 45 degrees right, back to straight and now it's 45 degrees left. I'm sure it's just my rack jumping teeth but I'm too lazy to care. The truck drives fine but it'll pull to one side a little.
    WarFab Armor likes this.
