Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jun 13, 2012 at 9:40 PM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    Yeah I was talking about Loren the guy on CL that Mike tried out. I kind of want bolt ons for some reason, and when I talked to Loren it didnt sound like he had made a set of bolt ons before. This guy Marshall makes badass stuff too, done a good job on Bobs truck
  2. Jun 14, 2012 at 7:11 AM
    csuviper
    csuviper Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    See moderators (mjp2, tigerfan00,etc), even those that condemned Arrrghhh are wanting him back.
  3. Jun 14, 2012 at 7:22 AM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I tried to get the MODs to lift the perm ban, but they refused.
  4. Jun 14, 2012 at 8:06 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    About to do some work with a chain saw today :$
  5. Jun 14, 2012 at 8:10 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
  6. Jun 14, 2012 at 8:21 AM
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
  7. Jun 14, 2012 at 8:28 AM
    RockyMtnTRD
    Noah
    Colorado
    '11 TRD OR
    hack job
    X2 holy shit they better be good for $585
  8. Jun 14, 2012 at 8:29 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    :jellydance:
  9. Jun 14, 2012 at 8:31 AM
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    Got my ammo box mounted up last night. If anyone here wants to do this mod let me know and i can get you the unistrut nuts and bolts i used here.
    Ill be putting the eye bolt on for a lockable box, and then painting it probably this weekend. Thoughts?
  10. Jun 14, 2012 at 8:33 AM
    Hoyal
    Devin
    2013 Tundra
    Nice mount of the ammo can I have some I want to mount In my runner.
    As for bolt on sliders I would go demello hybrid bolt ons those fuckers are stout! I loved mine on my taco.
  11. Jun 14, 2012 at 8:43 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    eye bolt to make it lockable? how are you doing that? is it a latch setup?
  12. Jun 14, 2012 at 8:55 AM
    PS78
    Rancher
    2011 DCSB TRD OR
    like this, but im going to use a plastic covered lock to stop the rattle trap in the bed of the truck. People were curious about the strength of the box with weight in it. The way mine is mounted i could stand on the thing and not have it move.
  13. Jun 14, 2012 at 9:07 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    I'm interested on where you got them but I want to try to use a button-top bolt so that you can't catch your skin on an edge accidental reaching into it. Yours looks much better than most I've seen that have giant bolts sticking out an inch or two but I still want as smooth & flat a surface as possible.
    You just drill another hole in the box itself through one of the slats in the lid clamp. Then run an eye-bolt through that so that it sticks out through the slat in the lid latch and you can then use a padlock to this eye-bolt to lock it when not in use. I suggest a combination lock so you don't have to locate keys to get into them. Same combo for all of them (assuming you have more than one) and you're set. They have ones that have a rubbery cover that will keep them from rattling against the can over bumps. Along the same lines you may want to cut/remove the handles to alleviate rattles since the handles are no longer needed and you may want to put a strip of foam tape across the top on the side that rests against your cab when opened to avoid damage to your cab from opening.
    Pro tip: if you insulate the inside you will have an inexpensive Faraday Cage to protect electronics (walkie talkies, CB, etc) in the event if an EMP.
  14. Jun 14, 2012 at 9:10 AM
    Hoyal
    Devin
    2013 Tundra
    Tanner gun show had ammo cans of all sizes for cheap. Or if you know someone In the army ask them. My brother snagged me a few last time they went to the range.
  15. Jun 14, 2012 at 9:16 AM
    PS78
    Rancher
    2011 DCSB TRD OR
    I went up to the Army Surplus store on Peco's and picked this one up. they call it the saw box, for 5.56mm I had a 50 cal box but its a bit smaller, i like this one much better. I did cut the top handle and front opening handle off to stop that from rattling, and when the box is open it rests against the rubber weather seal on the back window, not the cab. No need for the foam tape, it will never hit the cab of the truck.
    Im curious your thoughts about plastic in the box. Especially if you paint it like most people with black paint. These puppies will pull in a lot of heat from the sun so i would assume that things inside could get cookin hot
  16. Jun 14, 2012 at 9:20 AM
    RockyMtnTRD
    Noah
    Colorado
    '11 TRD OR
    hack job
    How much were they for you?
    Edit: $470 + shipping
  17. Jun 14, 2012 at 9:45 AM
    Ostrichsak
    Jer
    Depends on which boxes you use and how/where they are mounted. Not everyone is lucky enough to have them rest against the rubber window surround so be careful opening for the first time to see where it's going to hit and some foam tape may be necessary if comes into contact with the cab or window. Just a tip for those looking to do this mod but you lucked out.
    I wouldn't use plastic to insulate it. I would use a rubberized foam sheet and cut panels to fit or something similar. I thing having one of them (if I run two which will be likely) set up as a Faraday Cage could be useful and really wouldn't take too much effort to do. It would have the added bonus of cushioning contents inside from bumps and jolts as well as do away with rattling.
  18. Jun 14, 2012 at 9:56 AM
    csuviper
    Brian
    Broomfield, CO
    I am assuming the box is for tools and tie downs, not electronics. Electronics should probably stay in the cab (my opinion).
  19. Jun 14, 2012 at 9:57 AM
    DOT
    DOT Well-Known Member
    Jobin
    Littleton CO
    2007 FJ
    3'' toytec lift
  20. Jun 14, 2012 at 10:05 AM
    Ostrichsak
    Jer
    Right, and there's nothing to say you couldn't still use them for tools. That doesn't mean you can't keep some el cheap-o walkie talkies, weather radios or other such emergency electronics in it. I'm not saying to keep your expensive smart phone in them but for those who believe in being prepared for just about anything this is an inexpensive and simple step one can take to have a couple more bases covered. If they're bolted to the bed from inside and locked from the outside they're going to be pretty tough to get into and even if they are you're talking about losing a $10 set of walkie talkies & a $10 weather radio. Depending on what tools you own the tools inside will probably be worth more.
